Kinetic Energy and Work Homework Help
The discussion revolves around a physics homework problem involving a 50 kg mass being pulled up a 20° incline. Participants emphasize the importance of using a free body diagram (FBD) to identify forces such as tension, friction, and gravity. Key equations for calculating work, including W = Fd x cosθ, are mentioned, but confusion persists regarding their application. The normal force and frictional force calculations are clarified, with participants confirming that the frictional force opposes the direction of motion. Overall, the conversation focuses on understanding the setup and application of physics concepts to solve the problem effectively.
KTiaam
A 50 kg mass is pulled at a constant speed up a 20° incline which is 12m long and 4.1m high.
μk = 0.32
a) find the work done by tension, T.
b) find the work done by friction.
c) find the work done against gravity.
W = F x D
Work = force x Distance
W = Fd x cosθ
I still confused on the concept of this.
i know that you have to use Fd x cosθ, but i am confused on how to set it up.
μk = 0.32
W = F x D
W = Fd x cosθ
Always start this kind of problem with a free body diagram (FBD). Can you sketch one and post it as an attachment? And use the FBD to show the forces that you are being asked about in the problem...
Frictional force is the constant of friction multiplied by the normal force, which is the force equal and opposite to the gravitational force.
This is my FBD
KTiaam said:
This is my FBD
Good, so now you can start writing equations for each of the works that you are asked to find...
Im still confused on how to do that, all i know is that:
f// = mgsinθ
fn = mgcosθ
What specifically is confusing you about applying the formula? You have three quantities, F, d, and θ. What do these variables represent?
KTiaam - remember to put the frictional force in your free-body diagram.
So i know how to find F of gravity and force perpendicular how do i find force friction?
Since i know F perpendicular would it be just the opposite?
F perpendicular is equal to 46.045
i got that by:
mass x gravity x cos 20°
= 5 kg x 9.8 x cos 20°
=46.045
would force normal be negative then?
or is force of gravity negative?
i know that Force of friction is:
coefficient of friction x force normal
am i on the right track?
Yes.
For the direction of the frictional force - remember that it always opposes the motion.
  • · Replies 16 ·
  • · Replies 20 ·
