Kinetic Energy including a pulley
The discussion revolves around calculating the total kinetic energy of a two-block-pulley system and the rotational kinetic energy of the pulley after the blocks have fallen a distance of 0.090 m. Participants express confusion over how to relate forces, accelerations, and energies in their calculations, emphasizing the need to consider both translational and rotational kinetic energy. Key equations are provided, but there is uncertainty about the correct application of the spring constant and the inclusion of potential energy changes. The conversation highlights the importance of understanding energy conservation principles in solving the problem. Overall, the thread serves as a collaborative effort to clarify the approach to this physics problem.
Lydia22
Two blocks, of masses M = 2.0 kg and 2M are connected to a spring of spring constant k = 200 N/m that has one end fixed, as shown in the figure below. The horizontal surface and the pulley are frictionless, and the pulley has a moment of inertia I=0.005 kg.m^2 with radius R=0.050 m. The blocks are released from rest with the spring relaxed.i.e in its equilibrium position).
(a) What is the combined(total) kinetic energy of the two blocks when the hanging two-block-pulley system has fallen a distance of 0.090 m?
J
(b) What is the rotational kinetic energy of the pulley when the hanging blockhas fallen 0.090 m?
http://www.webassign.net/hrw/W0155-N.jpg]2. Homework Equations [/b]
Mass 1
Fnet(X)= [T[/1] -[F][/sp] =[M][/1][a][/x]= [T][/1] -KΔs
Pulley
[T][/net] =[T][/1]R -[T][/2]R= -IΩ
Hanging Mass
[F][/net]=[M][/2]-[T][/2]=[M][/2]
Three equations Four unknowns ,I do not know how to proceed from this point.
Hi Lydia! :smile:
Why forces? :confused:
Just call the speed "v", and calculate all the energies. :wink:
I was trying to get the acceleration the lead to velocity
i know! :smile:
you don't need to
If the velocity is final 'v'
K =0.5M[V][/2] + 0.5I[ω][/2] + 0.5{2M}[V][/2] + mgh
=0.5M[V][/2] + 0.5(0.5M[R][/2])[V][/2][R][/2] + 0.5{2M}[V][/2] - 2Mgh
But how do I know i don't need to? won't this be in terms of unknowns ?? #swimming in the pool of confused (EXAM in a few hours) :cry:
(try using the X2 button just above the Reply box :wink:)
=0.5M[V]2 + 0.5(0.5M[R]2)[V]2/[R]2 + 0.5{2M}[V]2 - 2Mgh
Yes, but
i] I is given in the question
ii] you've left out the springy part! :wink:
=0.5M[V][/2] + 0.5(0.005[V][/2][0.050][/2] + 0.5{2M}[V][/2] - 2(9.8)(0.090) + 0.5(200)(ΔS)
a bit difficult to read :redface:
i think it's ok, except that the spring KE should be 1/2 k h2 :wink:
Sorry i cannot use those fancy buttons.Thank you for the little light
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 40 ·
