Kinetic Energy & Megaton Calculation HELP
The discussion revolves around calculating the kinetic energy of a comet impacting Earth and converting that energy into megatons of TNT. The kinetic energy formula used is KE = 1/2MV^2, leading to a calculated energy of approximately 2.4276 x 10^21 joules for the comet. This value is then converted to megatons of TNT by dividing by 4.2 x 10^15 joules per megaton, indicating a significant potential for devastation. The impact of such a comet, if it struck a populated area, could result in catastrophic consequences due to the immense energy release. The calculations highlight the serious implications of celestial impacts on Earth.
lloyd_lex
A) A relatively small impact crater 20 kilometers in diameter could be made by a comet 2 kilometers in diameter traveling at 34.0 (3.40×104 ).
Assume that the comet has a total mass of kilograms. What is its total kinetic energy?
(B) Convert your answer from part A to an equivalent in megatons of TNT, the unit used for nuclear bombs. Comment on the degree of devastation the impact of such a comet could cause if it struck a populated region on Earth. (Hint: One megaton of TNT releases joules of energy.)
Kinetic energy = 1/2MV^2
my attempt:
=1/2*[4.2*10^12]*[3.4*10^4]^2
=2.4276*10^21 joules
For B
i divided my answer from A by 4.2*10^15 since One megaton of TNT releases 4.2*10^15joules of energy
The formating seems to have removed some numbers - so we can't check it.
But your method is correct
