Lagrangian Problem (Find Relation between Amplitude and Momentum)
The discussion revolves around finding a relationship between amplitude and momentum using a specific Lagrangian. The momentum is calculated as p = dot{q}/sqrt{1-dot{q}^2}, but the connection to the amplitude of oscillations remains unclear. The Hamiltonian is derived as H = sqrt{1+p^2} + q^2/2, with the amplitude defined as A = q_max, occurring when p = 0. Clarifications are made regarding the dimensions of q and the concept of amplitude in this context. Ultimately, the correct answer from the provided options is identified as (a), although the method to derive it is still uncertain.
Wannabe Physicist
Consider the Lagrangian $$L = 1-\sqrt{1-\dot{q}^2}-\frac{q^2}{2}$$ of a particle executing oscillations whose amplitude is ##A## . If ##p## denotes the momentum of
the particle, then ##4p^2## is
a) ##(A^2-q^2)(4+A^2-q^2)##
b) ##(A^2+q^2)(4+A^2-q^2)##
c) ##(A^2-q^2)(4+A^2+q^2)##
d) ##(A^2+q^2)(4+A^2+q^2)##
1) ##p = \frac{\partial L}{\partial \dot{q}}##
2) [not sure if this is relevant] ##H = \left(\Sigma_{i} p_i \dot{q}_i\right) - L##
The given lagrangian doesn't seem to correspond to any of the basic systems (like simple/ coupled harmonic oscillators, etc). So I calculated the momentum ##p## which is the partial derivative of ##L## with respect to generalized velocity ##\dot{q}##. Doing so I obtain
$$p = \frac{\dot{q}}{\sqrt{1-\dot{q}^2}}$$
Now, I am facing this problem: I do not know how to relate this to the amplitude of the oscillations.
In the hopes of getting a direction or line of thought to follow, I tried writing the Hamiltonian of this system, which is obtained by rewriting the above equation for ##p=p(\dot{q})## in the form ##\dot{q} = \dot{q}(p) = \displaystyle{\frac{p^2}{1+p^2}}## and substituting it in the equation (2) in the "relevant equations" listed above. I found
$$H = \sqrt{1+p^2} +\frac{q^2}{2}$$
But I am still not sure how to proceed.
After trying all of the above I looked up the answer key and the correct option is (a). But I am not sure how to get the answer.
Wannabe Physicist said:
Homework Statement:: Consider the Lagrangian $$L = 1-\sqrt{1-\dot{q}^2}-\frac{q^2}{2}$$ of a particle executing oscillations whose amplitude is ##A## . If ##p## denotes the momentum of
Relevant Equations:: 1) ##p = \frac{\partial L}{\partial \dot{q}}##
I think you're almost there. You have an expression for ##H## in terms of ##p## and ##q##. The definition of "amplitude" here is that ##A = q_{max}##, the maximum value of ##q##, which occurs when ##p = 0##. So you can relate ##A## to ##H##, which allows you to relate ##A##, ##p## and ##q##.
Likes Wannabe Physicist and Delta2
Yes! I had thought of that! But then am I not presuming that ##q## has dimensions of position?
I see it now. I was assuming the amplitude itself has dimensions of position. Thanks for helping @stevendaryl !
I don't think it matters what the units of ##q## are. It only matters that ##A## means the maximum value of ##q##. I actually had never heard of the word "amplitude" applied to situations other than sines and cosines, but I suppose it makes sense for more complicated functions, as well.
Homework Statement: Consider the Lagrangian $$L = 1-\sqrt{1-\dot{q}^2}-\frac{q^2}{2}$$ of a particle executing oscillations whose amplitude is ##A## . If ##p## denotes the momentum of
Relevant Equations: 1) ##p = \frac{\partial L}{\partial \dot{q}}##
It is not said that the momentum is canonical therefore you can not use the canonical momentum formula
It may be worth noting that the thread is well over 2 years old!
Likes jim mcnamara
