Landau Quantization: Classical Particle Motion in a Uniform Magnetic Field
The discussion revolves around the classical motion of a charged particle in a uniform magnetic field, specifically addressing the trajectory, action, and magnetic flux. The particle's trajectory is determined by the Lorentz force law, resulting in a circular path, with the radius dependent on the particle's speed and energy. The participants explore the Hamiltonian and Lagrangian formulations to derive equations of motion, ultimately confirming that the motion is periodic and governed by the cyclotron frequency. The challenge lies in integrating the Lagrangian to calculate the classical action along the trajectory, with emphasis on correctly applying the vector potential in the Landau gauge. The conversation highlights the importance of gauge invariance and the need for careful integration to derive the action accurately.
  • #51
(Again, you kept an extra \omega in the second term.) I see you corrected that.
Also:
<br /> \int_{0}^{t}{\sin{(2 \omega t)} \, dt} = -\left.\frac{1}{2 \omega} \, \cos{(\omega t)}\right|^{t}_{0} = \frac{1}{2\omega} \, \left[1 - \cos{(2 \omega t)}\right]<br />
Finally, what will be the change in S during one period (take t = 2\pi/\omega in the above formula)?
  • #52
1 - cos (2 \omega \frac{(2\pi}{\omega}) = 0, so it is appropriately periodic.
  • #53
No, the first term is proportional to t and is not periodic.
  • #54
Assuming that's satisfactory, may I ask you one last quick question (you are a saint, by the way. I have been unbelievably useless throughout this.) How would I go about evaluating the magnetic flux through the classical trajectory as a function of the energy?
In case you're wondering about my remarkable ignorance, I'm a math student who never took classical mechanics and is in a quantum course, so all the classical mechanics stuff is new to me. Thanks again.
  • #55
What does the trajectory look like? What are its dimensions in terms of the quantities we have already defined? What is the magnetic flux from a homogeneous magnetic field perpendicular through a contour?
  • #56
In my notes, I have that it is given by \frac{1}{2\pi}\oint A dx, and the baby E&M book I am looking at says that it can be given by the Area of the surface dotted with the B field times cos(theta), for theta the angle between the B field and the surface.
But since the B field is homogeneous in the z-direction, \theta = \frac{\pi}{2} and cos=0, so something must be really flawed in my reasoning.
  • #57
Yes, they are both equal due to Stokes' Theorem:
<br /> \phi_{m} = \int_{S}{\left(\mathbf{B} \cdot \hat{\mathbf{n}}\right) \, da} = \oint{\mathbf{A} \cdot d\mathbf{l}}<br />
So, there is no factor of 1/(2\pi) if you use the circulation of the vector potential.
  • #58
So there is nothing wrong in my reasoning and the flux actually is zero? It seems odd to ask me to evaluate it "as a function of the energy" then.
  • #59
No, it is not zero. I didn't see the part where you say it's zero. Since \mathbf{A} has only a zero component, you need to evaluate:
<br /> \oint{\mathbf{A} \cdot d\mathbf{l}} = \oint{A_{y} \, dy} = B \int_{0}^{T}{x(t) \, v_{y}(t)}<br />
where T = 2\pi/\omega is the period of the trajectory and i used A_{y} = B \, x.
  • #60
B\int x(t) v_{y} (t) = B \frac{-(v_{0})^2}{\omega} \int (sin(\omega t)^2)
Using (sin(\omega t)^2) = \frac{1 - cos (2\omega t)}{2} and doing the integral, I get
\Phi = B\pi(- \frac{v_{0}}{\omega})^2
  • #61
yes. the minus sign is redundant.
  • #62
I can't thank you enough for all your help.
  • #63
no problem. nice username ;)
  • #64
Btw, I don't think I understand why the magnetic flux is a function of the energy here.
