Light incident on a sphere, focused at a distance ##2R##
The discussion focuses on the application of the refraction equation for a spherical surface to determine the index of refraction of a glass sphere. The equation used is ##\frac{n_1}{p}+\frac{n_2}{q}=\frac{n_2-n_1}{R}##, with the assumption that the object distance ##p## is infinite and the image distance ##q## is set to ##2R##. By substituting these values, the calculation yields an index of refraction ##n_2=2## for the sphere. The reasoning presented is confirmed to be sound, indicating a clear understanding of the refraction principles involved. Overall, the calculations and assumptions align with optical physics concepts.
lorenz0
A solid sphere with index of refraction ##n## and radius ##R##, placed in air, is illuminated by a beam of light coming from a source at a great distance, which is focused on the bottom surface of the sphere. Determine the value of ##n##.
I used the equation for the refraction on a spherical surface: ##\frac{n_1}{p}+\frac{n_2}{q}=\frac{n_2-n_1}{R}##, where ##n_1=1## is the index of refraction of air, ##n_2## the index of refraction of the sphere, ##R## is the radius of the glass sphere, ##p## is the object distance which, since the rays are parallel I assumed to be infinite, ##p=\infty##, and ##q## is the image distance, which should be ##q=2R##. Substituting and solving for ##n_2## I get ##n_2=2##.
Does my reasoning make sense? Thanks.
Looks good to me.
Full size image.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
