Loop-and-allied QG bibliography
In summary, Rovelli's program for loop gravity involves coupling the standard model to quantized QG loops, allowing for interactions between eigenvalues of length and momentum. This approach allows for non-perturbative calculations without infinity problems and does not require a continuum limit. The main difference in loop gravity is that the excitations of space are represented by polymers, or ball-and-stick models, that can be labeled with numbers to determine the volume and area of any region or surface. This allows for a more intuitive understanding of the geometry of the universe.
  • #1,786
http://arxiv.org/abs/1208.1463
Loop quantum gravity as an effective theory
Martin Bojowald
(Submitted on 7 Aug 2012)
As a canonical and generally covariant gauge theory, loop quantum gravity requires special techniques to derive effective actions or equations. If the proper constructions are taken into account, the theory, in spite of considerable ambiguities at the dynamical level, allows for a meaningful phenomenology to be developed, by which it becomes falsifiable. The traditional problems plaguing canonical quantum-gravity theories, such as the anomaly issue or the problem of time, can be overcome or are irrelevant at the effective level, resulting in consistent means of physical evaluations. This contribution presents aspects of canonical equations and related notions of (deformed) space-time structures and discusses implications in loop quantum gravity, such as signature change at high density from holonomy corrections, and falsifiability thanks to inverse-triad corrections.
30 pages, lecture series at Sixth International School on Field Theory and Gravitation 2012 (Petropolis, Brazil)
http://arxiv.org/abs/1208.1502
A cosmological solution of Regge calculus
Adrian P. Gentle
We revisit the Regge calculus model of the Kasner cosmology first considered by S. Lewis. One of the most highly symmetric applications of lattice gravity in the literature, Lewis' discrete model closely matched the degrees of freedom of the Kasner cosmology. As such, it was surprising that Lewis was unable to obtain the full set of Kasner-Einstein equations in the continuum limit. Indeed, an averaging procedure was required to ensure that the lattice equations were even consistent with the exact solution in this limit. We correct Lewis' calculations and show that the resulting Regge model converges quickly to the full set of Kasner-Einstein equations in the limit of very fine discretization. Numerical solutions to the discrete and continuous-time lattice equations are also considered.
12 pages, 3 figures
http://arxiv.org/abs/1208.1375
Structural Aspects Of Gravitational Dynamics And The Emergent Perspective Of Gravity
T. Padmanabhan
I describe several conceptual aspects of a particular paradigm which treats the field equations of gravity as emergent. These aspects are related to the features of classical gravitational theories which defy explanation within the conventional perspective. The alternative interpretation throws light on these features and could provide better insights into possible description of quantum structure of spacetime. This review complements the discussion in arXiv:1207.0505, which describes space itself as emergent in the cosmological context.
29 pages. Updated version of talks given at: (a) Petropolis, Brazil, 2012 (b) Institute of Astrophysics, Paris, 2012 and (c) International Centre for Theoretical Sciences, Bangalore, 2012
brief mention:
http://arxiv.org/abs/1208.1428
Perturbative algebraic quantum field theory
Klaus Fredenhagen, Katarzyna Rejzner
These notes are based on the course given by Klaus Fredenhagen at the Les Houches Winter School in Mathematical Physics (January 29 - February 3, 2012) and the course "QFT for mathematicians" given by Katarzyna Rejzner in Hamburg for the Research Training Group 1670 (February 6 -11, 2012). Both courses were meant as an introduction to modern approach to perturbative quantum field theory and are aimed both at mathematicians and physicists.
41 pages, 1 figure
  • #1,787
http://arxiv.org/abs/1208.1514
Combinatorial Dark Energy
Aaron Trout
(Submitted on 8 Aug 2012)
In this paper, we give a conceptual explanation of dark energy as a small negative residual scalar curvature present even in empty spacetime. This curvature ultimately results from postulating a discrete spacetime geometry, very closely related to that used in the dynamical triangulations approach to quantum gravity. In this model, there are no states which have total scalar curvature exactly zero. Moreover, numerical evidence in dimension three suggests that, at a fixed volume, the number of discrete-spacetime microstates strongly increases with decreasing curvature. Because of the resulting entropic force, any dynamics which push empty spacetime strongly toward zero scalar curvature would instead produce typically observed states with a small negative curvature. This provides a natural explanation for the empirically observed small positive value for the cosmological constant (Lambda is about 10^(-121) in Planck units.) In fact, we derive the very rough estimate Lambda=6x10^(-118) from a simple model containing only the two (highly-degenerate) quantum states with total scalar-curvature closest to zero.
20 pages, 2 tables
  • #1,788
http://arxiv.org/abs/1208.2228
Bohr-Sommerfeld Quantization of Space
Eugenio Bianchi, Hal M. Haggard
(Submitted on 10 Aug 2012)
We introduce semiclassical methods into the study of the volume spectrum in loop gravity. The classical system behind a 4-valent spinnetwork node is a Euclidean tetrahedron. We investigate the tetrahedral volume dynamics on phase space and apply Bohr-Sommerfeld quantization to find the volume spectrum. The analysis shows a remarkable quantitative agreement with the volume spectrum computed in loop gravity. Moreover, it provides new geometrical insights into the degeneracy of this spectrum and the maximum and minimum eigenvalues of the volume on intertwiner space.
32 pages, 10 figures
http://arxiv.org/abs/1208.2038
Fixed-Functionals of three-dimensional Quantum Einstein Gravity
Maximilian Demmel, Frank Saueressig, Omar Zanusso
(Submitted on 9 Aug 2012)
We study the non-perturbative renormalization group flow of f(R)-gravity in three-dimensional Asymptotically Safe Quantum Einstein Gravity. Within the conformally reduced approximation, we derive an exact partial differential equation governing the RG-scale dependence of the function f(R). This equation is shown to possesses two isolated and one continuous one-parameter family of scale-independent, regular solutions which constitute the natural generalization of RG fixed points to the realm of infinite-dimensional theory spaces. All solutions are bounded from below and give rise to positive definite kinetic terms. Moreover, they admit either one or two UV-relevant deformations, indicating that the corresponding UV-critical hypersurfaces remain finite dimensional despite the inclusion of an infinite number of coupling constants. The impact of our findings on the gravitational Asymptotic Safety program and its connection to new massive gravity is briefly discussed.
34 pages, 14 figures
of possible interest:
http://arxiv.org/abs/1208.2168
Emergent gravity in two dimensions
D. Sexty, C. Wetterich
We explore models with emergent gravity and metric by means of numerical simulations. A particular type of two-dimensional non-linear sigma-model is regularized and discretized on a quadratic lattice. It is characterized by lattice diffeomorphism invariance which ensures in the continuum limit the symmetry of general coordinate transformations. We observe a collective order parameter with properties of a metric, showing Minkowski or euclidean signature. The correlation functions of the metric reveal an interesting long-distance behavior with power-like decay. This universal critical behavior occurs without tuning of parameters and thus constitutes an example of "self-tuned criticality" for this type of sigma-models. We also find a non-vanishing expectation value of a "zweibein" related to the "internal" degrees of freedom of the scalar field, again with long-range correlations. The metric is well described as a composite of the zweibein. A scalar condensate breaks euclidean rotation symmetry.
22 pages, 17 figures
  • #1,789
of possible general interest, though not QG-related:
http://arxiv.org/abs/1208.2660
A Numerical Simulation of Chern-Simons Inflation
Annie Preston, David Garrison, Stephon Alexander
(Submitted on 13 Aug 2012)
In this work, we present results of numerical simulations of the Chern-Simons Inflation Model proposed by Alexander, Marciano and Spergel. According to this model, inflation begins with a fermion condensate interacting with a gauge field. Crucial to the success of this mechanism is the assumption that the Chern-Simons interaction would drive energy from the initial random spectrum into a narrow band of frequencies at superhorizon scales. In this work we numerically confirm this expectation. These gauge fields, when combined with the Friedmann equations, were broken into a system of hyperbolic equations and numerically simulated with a novel relativistic MHD code. We show that the amplification of horizon sized gauge fields produces the conditions to cause cosmological inflation and that the onset of inflation are robust against certain fine tunings in the initial conditions.
10 pages, 2 figures
http://arxiv.org/abs/1208.2611
Space time and the passage of time
George F. R. Ellis, Rituparno Goswami
This paper examines the various arguments that have been put forward suggesting either that time does not exist, or that it exists but its flow is not real. I argue that (i) time both exists and flows; (ii) an Evolving Block Universe (`EBU') model of spacetime adequately captures this feature, emphasizing the key differences between the past, present, and future; (iii) the associated surfaces of constant time are uniquely geometrically and physically determined in any realistic spacetime model based in General Relativity Theory; (iv) such a model is needed in order to capture the essential aspects of what is happening in circumstances where initial data does not uniquely determine the evolution of spacetime structure because quantum uncertainty plays a key role in that development. Assuming that the functioning of the mind is based in the physical brain, evidence from the way that the mind apprehends the flow of time is prefers this evolving time model over those where there is no flow of time.
25 pages, 2 figures. For Springer Handbook of Spacetime.
  • #1,790
http://arxiv.org/abs/1208.3186
A Reasonable Ab Initio Cosmological Constant Without Holography
Aaron D. Trout
(Submitted on 15 Aug 2012)
We give a well-motivated explanation for the origin of dark energy, claiming that it arises from a small residual negative scalar-curvature present even in empty spacetime. The vacuum has this residual curvature because spacetime is fundamentally discrete and there are more ways for a discrete geometry to have negative curvature than positive. We explicitly compute this effect in the well-known {\em dynamical triangulations} (DT) model for quantum gravity and the predicted cosmological constant $\Lambda$ agrees with observation.
We begin by almost completely characterizing the DT-model's vacuum energies in dimension three. Remarkably, the energy gap between states comes in increments of [\Delta\mathcal{A} =\frac{\ell}{8\mathcal{V}}] in natural units, where $\ell$ is the "Planck length" in the model and $\mathcal{V}$ is the volume of the universe. Then, using only vacua in the $N$ energy levels nearest zero, where $N$ is the universe's radius in units of $\ell$, we apply our model to the current co-moving spatial volume to get $|\Lambda| \approx 10^{-123}$.
This result comes with a rigorous proof and does not depend on any holographic principle or carefully tuned parameters. Our only unknown is the relative entropy of the low-energy states, which sets the sign of $\Lambda$. Numerical evidence strongly suggests that spacetime entropy in the DT-model is a decreasing function of scalar-curvature, so the model also predicts the correct sign for $\Lambda$.
  • #1,791
http://arxiv.org/abs/1208.3388
Holonomy Spin Foam Models: Definition and Coarse Graining
Benjamin Bahr, Bianca Dittrich, Frank Hellmann, Wojciech Kaminski
(Submitted on 16 Aug 2012)
We propose a new holonomy formulation for spin foams, which naturally extends the theory space of lattice gauge theories. This allows current spin foam models to be defined on arbitrary two-complexes as well as to generalize current spin foam models to arbitrary, in particular finite groups. The similarity with standard lattice gauge theories allows to apply standard coarse graining methods, which for finite groups can now be easily considered numerically. We will summarize other holonomy and spin network formulations of spin foams and group field theories and explain how the different representations arise through variable transformations in the partition function. A companion paper will provide a description of boundary Hilbert spaces as well as a canonical dynamic encoded in transfer operators.
36 pages, 12 figures
http://arxiv.org/abs/1208.3335
Quantum Hall Effect and Black Hole Entropy in Loop Quantum Gravity
Deepak Vaid
In LQG, black hole horizons are described by 2+1 dimensional boundaries of a bulk 3+1 dimensional spacetime. The horizon is endowed with area by lines of gravitational flux which pierce the surface. As is well known, counting of the possible states associated with a given set of punctures allows us to recover the famous Bekenstein-Hawking area law according to which the entropy of a black hole is proportional to the area of the associated horizon SBH AHor. It is also known that the dynamics of the horizon degrees of freedom is described by the Chern-Simons action of a su(2) (or u(1) after a certain gauge fixing) valued gauge field Aμi. Recent numerical work which performs the state-counting for punctures, from first-principles, reveals a step-like structure in the entropy-area relation. We argue that both the presence of the Chern-Simons action and the step-like structure in the entropy-area curve are indicative of the fact that the effective theory which describes the dynamics of punctures on the horizon is that of the Quantum Hall Effect.
24 pages, 7 figures; comments welcome
brief mention, not QG but conceivably of interest:
http://arxiv.org/abs/1208.3373
The cosmology of the Fab-Four
Edmund J. Copeland, Antonio Padilla, Paul M. Saffin
We have recently proposed a novel self tuning mechanism to alleviate the famous cosmological constant problem, based on the general scalar tensor theory proposed by Horndeski. The self-tuning model ends up consisting of four geometric terms in the action, with each term containing a free potential function of the scalar field; the four together being labeled as the Fab-Four. ...
22 pages, 6 figures
  • #1,792
general interest:
http://arxiv.org/abs/1208.3662
Astrophysical and cosmological probes of dark matter
Matts Roos
(Submitted on 17 Aug 2012)
Dark matter has been introduced to explain mass deficits noted at different astronomical scales, in galaxies, groups of galaxies, clusters, superclusters and even across the full horizon. Dark matter makes itself felt only through its gravitational effects. This review summarizes phenomenologically all the astrophysical and cosmological probes that have been used to give evidence for its existence.
39 pages, 24 figures. Accepted by J. of Modern Physics and will be released as Special Issue in September, 2012
http://arxiv.org/abs/1208.3841
Constraints on Chronologies
Alfred Shapere, Frank Wilczek
(Submitted on 19 Aug 2012)
The time ordering of two spacelike separated events is arbitrary, when all inertial frames are taken into account, but for three or more events it is not generally so. We determine the structure of possible time orderings, or chronologies, for multiple events in any number of dimensions, analytically and exhaustively for three events in four space-time dimensions, algorithmically in other cases. We also formulate an alternative criterion, based on convexity, for determining the allowed chronologies of a set of events. We show how the metric of a Lorentz invariant spacetime can be partially reconstructed from a knowledge of the chronologies it supports. Finally, we propose a different but related criterion for allowed chronologies in curved spacetimes.
22 pages, 4 figures
brief mention:
http://arxiv.org/abs/1208.3703
Quantum Geometry and Interferometry
Craig Hogan
10 pages
  • #1,793
http://arxiv.org/abs/1112.1961
Spin Foams and Canonical Quantization
Authors: Sergei Alexandrov, Marc Geiller, Karim Noui
(Submitted on 8 Dec 2011 (v1), last revised 19 Aug 2012 (this version, v3))
Abstract: This review is devoted to the analysis of the mutual consistency of the spin foam and canonical loop quantizations in three and four spacetime dimensions. In the three-dimensional context, where the two approaches are in good agreement, we show how the canonical quantization \`a la Witten of Riemannian gravity with a positive cosmological constant is related to the Turaev-Viro spin foam model, and how the Ponzano-Regge amplitudes are related to the physical scalar product of Riemannian loop quantum gravity without cosmological constant. In the four-dimensional case, we recall a Lorentz-covariant formulation of loop quantum gravity using projected spin networks, compare it with the new spin foam models, and identify interesting relations and their pitfalls. Finally, we discuss the properties which a spin foam model is expected to possesses in order to be consistent with the canonical quantization, and suggest a new model illustrating these results.
  • #1,794
something different.
http://fqxi.org/data/essay-contest-files/AsselmeyerMalu_FQXIessay201_1.pdf
A chicken-and-egg problem: Which came first, the quantum state or spacetime? by Torsten Asselmeyer-Maluga
Essay Abstract
In this essay I will discuss the question: Is spacetime quantized, as in quantum geometry, or is it possible to derive the quantization procedure from the structure of spacetime? All proposals of quantum gravity try to quantize spacetime or derive it as an emergent phenomenon. In this essay, all major approaches are analyzed to find an alternative to a discrete structure on spacetime or to the emergence of spacetime. Here I will present the idea that spacetime defines the quantum state by using new developments in the differential topology of 3- and 4-manifolds. In particular the plethora of exotic smoothness structures in dimension 4 could be the corner stone of quantum gravity.
  • #1,795
http://arxiv.org/abs/1208.5023
Asymptotic safety, hypergeometric functions, and the Higgs mass in spectral action models
Christopher Estrada, Matilde Marcolli
(Submitted on 24 Aug 2012)
We study the renormalization group flow for the Higgs self coupling in the presence of gravitational correction terms. We show that the resulting equation is equivalent to a singular linear ODE, which has explicit solutions in terms of hypergeometric functions. We discuss the implications of this model with gravitational corrections on the Higgs mass estimates in particle physics models based on the spectral action functional.
25 pages
possible interest, briefly mentioned:
http://arxiv.org/abs/1208.5038
Free fermi and bose fields in TQFT and GBF
Robert Oeckl (UNAM)
We present a rigorous and functorial quantization scheme for linear fermionic and bosonic field theory targeting the topological quantum field theory (TQFT) that is part of the general boundary formulation (GBF). Motivated by geometric quantization, we generalize a previous axiomatic characterization of classical linear bosonic field theory to include the fermionic case. We proceed to describe the quantization scheme, combining a Fock space quantization for state spaces with the Feynman path integral for amplitudes. We show rigorously that the resulting quantum theory satisfies the axioms of the TQFT, in a version generalized to include fermionic theories. In the bosonic case we show the equivalence to a previously developed holomorphic quantization scheme. Remarkably, it turns out that consistency in the fermionic case requires state spaces to be Krein spaces rather than Hilbert spaces. This is also supported by arguments from geometric quantization and by the explicit example of the Dirac field theory. Contrary to intuition from standard quantum theory, we show that this is compatible with a consistent probability interpretation in the GBF. Another surprise in the fermionic case is the emergence of an algebraic notion of time, already in the classical theory, but inherited by the quantum theory. As in earlier work we need to impose an integrability condition in the bosonic case for all TQFT axioms to hold, due to the gluing anomaly. In contrast, we are able to renormalize this gluing anomaly in the fermionic case.
59 pages
  • #1,796
not Loop-and-allied QG but possibly of general interest:
http://arxiv.org/abs/1208.5481
Gamma Ray Signals from Dark Matter: Concepts, Status and Prospects
Torsten Bringmann, Christoph Weniger
(Submitted on 27 Aug 2012)
Weakly interacting massive particles (WIMPs) remain a prime candidate for the cosmological dark matter (DM), even in the absence of current collider signals that would unambiguously point to new physics below the TeV scale. The self-annihilation of these particles in astronomical targets may leave observable imprints in cosmic rays of various kinds. In this review, we focus on gamma rays which we argue to play a pronounced role among the various possible messengers. We discuss the most promising spectral and spatial signatures to look for, give an update on the current state of gamma-ray searches for DM and an outlook concerning future prospects. We also assess in some detail the implications of a potential signal identification for particle DM models as well as for our understanding of structure formation. Special emphasis is put on the possible evidence for a 130 GeV line-like signal that was recently identified in the data of the Fermi gamma-ray space telescope.
43 pages, 6 figures, 2 tables; invited contribution to special issue `The next decade in Dark Matter and Dark Energy' in 'Physics of the Dark Universe'.
http://arxiv.org/abs/1208.5715
The Top 10500 Reasons Not to Believe in the Landscape
T. Banks
(Submitted on 28 Aug 2012)
The String Landscape is a fantasy. We actually have a plausible landscape of minimally supersymmetric AdS4 solutions of supergravity modified by an exponential superpotential. None of these solutions is accessible to world sheet perturbation theory. If they exist as models of quantum gravity, they are defined by conformal field theories, and each is an independent quantum system, which makes no transitions to any of the others. This landscape has nothing to do with CDL tunneling or eternal inflation.
A proper understanding of CDL transitions in QFT on a fixed background dS space, shows that the EI picture of this system is not justified within the approximation of low energy effective field theory. The cutoff independent physics, defined by the Euclidean functional integral over the 4-sphere admits only a finite number of instantons. Plausible extensions of these ideas to a quantum theory of gravity obeying the holographic principle explain all of the actual facts about CDL transitions in dS space, and lead to a picture radically different from eternal inflation.
Theories of Eternal Inflation (EI) have to rely too heavily on the anthropic principle to be consistent with experiment. Given the vast array of effective low energy field theories that could be produced by the conventional picture of the string landscape one is forced to conclude that the most numerous anthropically allowed theories will disagree with experiment violently.
38 pages
  • #1,797
An up-to-date formulation of Loop, and Loop BH developments can be found in Rovelli's July 2012 Stockholm slides:
http://www.cpt.univ-mrs.fr/~rovelli/RovelliStockholmSpinFoam.pdf
Covariant Loop Quantum Gravity: Recent developments and open problems.
http://www.cpt.univ-mrs.fr/~rovelli/RovelliStockholmTermo.pdf
Horizon Entropy and LQG
http://arxiv.org/abs/1208.5874
A possibility to solve the problems with quantizing gravity
S. Hossenfelder
(Submitted on 29 Aug 2012)
It is generally believed that quantum gravity is necessary to resolve the known tensions between general relativity and the quantum field theories of the standard model. Since perturbatively quantized gravity is non-renormalizable, the problem how to unify all interactions in a common framework has been open since the 1930s. Here, I propose a possibility to circumvent the known problems with quantizing gravity, as well as the known problems with leaving it unquantized: By changing the prescription for second quantization, a perturbative quantization of gravity is sufficient as an effective theory because matter becomes classical before the perturbative expansion breaks down. This is achieved by considering the vanishing commutator between a field and its conjugated momentum as a symmetry that is broken at low temperatures, and by this generates the quantum phase that we currently live in, while at high temperatures Planck's constant goes to zero.
4 pages, 1 figure
  • #1,798
two interesting FQXI essays
http://fqxi.org/community/forum/topic/1442
Against Spacetime by Giovanni Amelino-Camelia
The notion of ``location" physics really needs is exclusively the one of ``detection at a given detector" and the time for each such detection is most primitively assessed as the readout of some specific material clock. The redundant abstraction of a macroscopic spacetime organizing all our particle detections is unproblematic and extremely useful in the classical-mechanics regime. But I here observe that in some of the contexts where quantum mechanics is most significant, such as quantum tunneling through a barrier, the spacetime abstraction proves to be cumbersome. And I argue that in quantum-gravity research we might limit our opportunities for discovery if we insist on the availability of a spacetime picture.
http://fqxi.org/community/forum/topic/1443
What if Natural Numbers Are Not Constant? by Jerzy Krol
Mathematics, via model theory, gives us the possibility that natural numbers could be understood as varying objects. We analyze this from the point of view of physics were standard models of natural and real numbers are not always absolute or fixed. The extended equivalence principle appears covering the changes of the numbers. As the consequence strange exotic geometry emerges with which a kind of gravity is assigned. Taking such perspective, from the foundations of mathematics, sheds completely new light on the nature and construction of a theory of quantum gravity.
  • #1,799
To get to the discussion of Hossenfelder's essay when it is submitted to FQXI, go to http://fqxi.org/community/forum/category/31418
and choose alphabetical ordering by author's surname, and scroll down to H. that's one way anyway. It apparently has not been turned in yet.
http://arxiv.org/abs/1208.6217
A complete hybrid quantization in inhomogeneous cosmology
Mikel Fernández-Méndez, Guillermo A. Mena Marugán, Javier Olmedo
(Submitted on 30 Aug 2012)
A complete quantization of a homogeneous and isotropic spacetime with closed spatial sections coupled to a massive scalar field is provided, within the framework of Loop Quantum Cosmology. We identify solutions with their initial data on the minimum volume section, and from this we construct the physical Hilbert space. Moreover, a perturbative study allows us to introduce small inhomogeneities. After gauge fixing, the inhomogeneous part of the system is reduced to a linear field theory. We then adopt a standard Fock representation to quantize these degrees of freedom. For the considered case of compact spatial topology, the requirements of: i) invariance under the spatial isometries, and ii) unitary implementation of the quantum dynamics, pick up a unique Fock representation and a particular set of canonical fields (up to unitary equivalence).
6 pages
http://arxiv.org/abs/arXiv:1208.5456
Numerical loop quantum cosmology: an overview
Parampreet Singh
A brief review of various numerical techniques used in loop quantum cosmology and results is presented. These include the way extensive numerical simulations shed insights on the resolution of classical singularities, resulting in the key prediction of the bounce at the Planck scale in different models, and the numerical methods used to analyze the properties of the quantum difference operator and the von Neumann stability issues. Using the quantization of a massless scalar field in an isotropic spacetime as a template, an attempt is made to highlight the complementarity of different methods to gain understanding of the new physics emerging from the quantum theory. Open directions which need to be explored with more refined numerical methods are discussed.
33 Pages, 4 figures. Invited contribution to appear in a special issue of Classical and Quantum Gravity devoted to numerical methods
  • #1,800
http://arxiv.org/abs/1209.0065
General relativistic statistical mechanics
Carlo Rovelli
(Submitted on 1 Sep 2012)
Understanding thermodynamics and statistical mechanics in the full general relativistic context is an open problem. I give tentative definitions of equilibrium state, mean values, mean geometry, entropy and temperature, which reduce to the conventional ones in the non-relativistic limit, but remain valid for a general covariant theory. The formalism extends to quantum theory. The construction builds on the idea of thermal time, on a notion of locality for this time, and on the distinction between global and local temperature. The last is the temperature measured by a local thermometer, and is given by kT = [STRIKE]h[/STRIKE] dτ/ds, with k the Boltzmann constant, [STRIKE]h[/STRIKE] the Planck constant, ds proper time and dτ the equilibrium thermal time.
9 pages. A tentative second step in the thermal time direction, 10 years after the paper with Connes. The aim is the full thermodynamics of gravity. The language of the paper is a bit technical: look at the Appendix first
http://arxiv.org/abs/1209.0396
Lorentz-covariant Hamiltonian analysis of BF gravity with the Immirzi parameter
Mariano Celada, Merced Montesinos
(Submitted on 3 Sep 2012)
We perform the Lorentz-covariant Hamiltonian analysis of two Lagrangian action principles that describe general relativity as a constrained BF theory and that include the Immirzi parameter. The relation between these two Lagrangian actions has been already studied through a map among the fields involved. The main difference between these is the way the Immirzi parameter is included, since in one of them the Immirzi parameter is included explicitly in the BF terms, whereas in the other (the CMPR action) it is in the constraint on the B fields. In this work we continue the analysis of their relationship but at the Hamiltonian level. Particularly, we are interested in seeing how the above difference appears in the constraint structure of both action principles. We find that they both possesses the same number of first-class and second-class constraints and satisfy a very similar (off-shell) Poisson-bracket algebra on account of the type of canonical variables employed. The two algebras can be transformed into each other by making a suitable change of variables
16 pages
  • #1,801
http://arxiv.org/abs/1209.0473
Observational effects from quantum cosmology
Gianluca Calcagni
The status of quantum cosmologies as testable models of the early universe is assessed in the context of inflation. While traditional Wheeler-DeWitt quantization is unable to produce sizable effects in the cosmic microwave background, the more recent loop quantum cosmology can generate potentially detectable departures from the standard cosmic spectrum. Thus, present observations constrain the parameter space of the model, which could be made falsifiable by near-future experiments.
14 pages, 3 figures. Invited review article also containing original material
brief mention:
http://arxiv.org/abs/1209.0480
Beyond H0 and q0: Cosmology is no longer just two numbers
Abraham R. Neben, Michael S. Turner
For decades, H0 and q0 were the quest of cosmology, as they promised to characterize our "world model" in a model-independent way. Using simulated data, we show that q0 cannot be both accurately and precisely determined using distance indicators. While H0 can be both accurately and precisely determined, to avoid a small bias in its direct measurements (of order -5 %) we demonstrate that H0M (assuming flatness and w=-1) is a better choice of two parameters, even if our world model is not precisely Lambda CDM. We illustrate with the analysis of the Constitution set of supernovae and indirectly infer q0 = -0.57 +/- 0.04. Finally, we show that it may be possible to directly determine q0 using the time dependence of redshifts, a method far less susceptible to the biases that plague measurements using distance indicators.
8 pages, 9 figures
  • #1,802
Three new FQXI essays
http://fqxi.org/community/forum/topic/1495
http://fqxi.org/data/essay-contest-files/Barbour_Reductionism.pdf
Reductionist Doubts by Julian Barbour
According to reductionism, every complex phenomenon can and should be explained in terms of the simplest possible entities and mechanisms. The parts determine the whole. This approach has been an outstanding success in science, but this essay will point out ways in which it could nevertheless be giving us wrong ideas and holding back progress. For example, it may be impossible to understand key features of the universe such as its pervasive arrow of time and remarkably high degree of isotropy and homogeneity unless we study it holistically -- as a true whole. A satisfactory interpretation of quantum mechanics is also likely to be profoundly holistic, involving the entire universe. The phenomenon of entanglement already hints at such a possibility.
http://fqxi.org/community/forum/topic/1504
http://fqxi.org/data/essay-contest-files/Dreyer_fqxi2012.pdf
Not on but of. by Olaf Dreyer
In physics we encounter particles in one of two ways. Either as fundamental constituents of the theory or as emergent excitations. These two ways differ by how the particle relates to the background. It either sits \emph{on} the background, or it is an excitation \emph{of} the background. We argue that by choosing the former to construct our fundamental theories we have made a costly mistake. Instead we should think of particles as excitations of a background. We show that this point of view sheds new light on the cosmological constant problem and even leads to observable consequences by giving a natural explanation for the appearance of MOND-like behavior. In this context it also becomes clear why there are numerical coincidences between the MOND acceleration parameter $a_0$, the cosmological constant $\Lambda$ and the Hubble parameter $H_0$.
http://fqxi.org/community/forum/topic/1506
http://fqxi.org/data/essay-contest-files/DAriano_FQXi_1.pdf
Quantum-Informational Principles for Physics by Giacomo Mauro D'Ariano
t is time to to take a pause of reflection on the general foundations of physics, re-examining the solidity of the most basic principles, as the relativity and the equivalence principles that are currently under dispute for violations at the Planck scale. A constructive criticism engages us in seeking new general principles, which reduce to the old ones as approximations holding in the physical domain already explored. At the very basis of physics are epistemological and operational rules for the same formulability of the physical law and for the computability of its theoretical predictions, rules that give rise to new solid principles. These rules lead us to a quantum-information theoretic formulation, hinging on a logical identification of the experimental protocol with the quantum algorithm
  • #1,803
http://arxiv.org/abs/1209.0881
The Physics of Events: A Potential Foundation for Emergent Space-Time
Kevin H. Knuth, Newshaw Bahreyni
Comments: 42 pages, 16 figures
Subjects: Mathematical Physics (math-ph); General Relativity and Quantum Cosmology (gr-qc); High Energy Physics - Theory (hep-th); Quantum Physics (quant-ph)
Everything that is detected or measured is the direct result of something influencing something else. This is the essence of the concept of force, which has become central to physics. By considering both the act of influencing and the response to such influence as a pair of events, we can describe a universe of interactions as a partially-ordered set of events. In this paper, we take the partially-ordered set of events as a fundamental picture of influence and aim to determine what interesting physics can be recovered. This is accomplished by identifying a means by which events in a partially-ordered set can be aptly and consistently quantified. Since, in general, a partially-ordered set lacks symmetries to constraint any quantification, we propose to distinguish a chain of events, which represents an observer, and quantify some subset of events with respect to the observer chain. We demonstrate that consistent quantification with respect to pairs of observer chains exhibiting a constant relationship with one another results in a metric analogous to the Minkowski metric and that transformation of the quantification with respect to one pair of chains to quantification with respect to another pair of chains results in the Bondi k-calculus, which represents a Lorentz transformation under a simple change of variables. We further demonstrate that chain projection induces geometric structure in the partially-ordered set, which itself is inherently both non-geometric and non-dimensional. Collectively, these results suggest that the concept of space-time geometry may emerge as a unique way for an embedded observer to aptly and consistently quantify a partially-ordered set of events. In addition to having potential implications for space-time physics, this also may serve as a foundation for understanding analogous space-time in condensed matter systems.
  • #1,804
http://arxiv.org/abs/1209.1344
Point particles in 2+1 dimensions: toward a semiclassical loop gravity formulation
Jonathan Ziprick
(Submitted on 6 Sep 2012)
We study point particles in 2+1 dimensional first order gravity using a triangulation to fix the connection and frame-field. The Hamiltonian is reduced to a boundary term which yields the total mass. The triangulation is dynamical with non-trivial transitions occurring when a particle meets an edge. This framework facilitates a description in terms of the loop gravity phase space.
3 pages, for Theory Canada 7 conference proceedings in Canadian Journal of Physics
http://arxiv.org/abs/1209.1110
Introduction to multifractional spacetimes
Gianluca Calcagni
(Submitted on 5 Sep 2012)
We informally review the construction of spacetime geometries with multifractal and, more generally, multiscale properties. Based on fractional calculus, these continuous spacetimes have their dimension changing with the scale; they display discrete symmetries in the ultraviolet and ordinary Poincar\'e symmetries in the infrared. Under certain reasonable assumptions, field theories (including gravity) on multifractional geometries are generally argued to be perturbatively renormalizable. We also sketch the relation with other field theories of quantum gravity based on the renormalization group.
27 pages, 6 figures. Lectures given at Sixth International School on Field Theory and Gravitation 2012 (Petropolis, Brazil). To appear in PoS
  • #1,805
http://arxiv.org/abs/1209.1266
Machian Time Is To Be Abstracted From What Change?
Edward Anderson
"It is utterly beyond our power to measure the changes of things by time. Quite the contrary, time is an abstraction at which we arrive through the changes of things." Ernst Mach [1].
What change? Three answers to this are `any change' (Rovelli), 'all change' (Barbour) and my argument here for the middle ground of a `sufficient totality of locally relevant change' (STLRC) giving a generalization of the astronomers' ephemeris time. I then use STLRC as a selection principle on existing and new approaches to the Problem of Time in Quantum Gravity. Emergent Jacobi-Barbour-Bertotti time can be interpreted as arising from a STLRC, resolves the classical Problem of Time and has an emergent semiclassical counterpart as regards facing the QM Problem of Time.
  • #1,806
Frank Hellmann's 4 September online seminar talk
http://relativity.phys.lsu.edu/ilqgs/hellmann090412.pdf
http://relativity.phys.lsu.edu/ilqgs/hellmann090412.wav
To follow, download the slides PDF first and have them ready when you turn on the audio.
It is about 3 papers, one of which has already appeared on Arxiv, the other two soon to appear.
Papers:
* B. Bahr, B. Dittrich, FH, W. Kaminski:
Holonomy Spin Foam Models: Definition and coarse graining.
(arxiv:1208:3388),
Holonomy Spin Foam Models: Boundary Hilbert spaces and canonical dynamics. (arxiv:soon)
* FH, W. Kaminski:
Holonomy Spin Foam Models: Asymptotic Dynamics of EPRL type
models.
(arxiv: soon+ε)
The authors are at Perimeter, MPI-Potsdam (Albert Einstein Institute), and Cambridge DAMPT. The abstract for the first of the three papers is:
==quote==
We propose a new holonomy formulation for spin foams, which naturally extends the theory space of lattice gauge theories. This allows current spin foam models to be defined on arbitrary two–complexes as well as to generalize current spin foam models to arbitrary, in particular finite groups. The similarity with standard lattice gauge theories allows to apply standard coarse graining methods , which for finite groups can now be easily considered numerically. We will summarize other holonomy and spin network formulations of spin foams and group field theories and explain how the different representations arise through variable transformations in the partition function. A companion paper will provide a description of boundary Hilbert spaces as well as a canonical dynamic encoded in transfer operators.
==endquote==
For more information about the ILQGS series of talks:
http://relativity.phys.lsu.edu/ilqgs/schedulefa12.html
  • #1,807
http://arxiv.org/abs/1209.1609
A Quantum Gravity Extension of the Inflationary Scenario
Ivan Agullo, Abhay Ashtekar, William Nelson
(Submitted on 7 Sep 2012)
Since the standard inflationary paradigm is based on quantum field theory on classical space-times, it excludes the Planck era. Using techniques from loop quantum gravity, the paradigm is extended to a self-consistent theory from the Planck scale to the onset of slow roll inflation, covering some 11 orders of magnitude in energy density and curvature. This pre-inflationary dynamics also opens a small window for novel effects, e.g. a source for non-Gaussianities, which could extend the reach of cosmological observations to the deep Planck regime of the early universe.
4 pages, 2 figures
  • #1,808
http://arxiv.org/abs/1209.2752
On the choice of time in the continuum limit of polymeric effective theories
Alejandro Corichi, Tatjana Vukasinac
(Submitted on 12 Sep 2012)
In polymeric quantum theories, a natural question pertains to the so called continuum limit, corresponding to the limit where the 'discreteness parameter' λ approaches zero. In particular one might ask whether the limit exists and, in that case, what the limiting theory is. Here we review recent results on the classical formulation of the problem for a soluble model in loop quantum cosmology. We show that it is only through the introduction of a particular λ-dependent internal time function that the limit λ→0 can be well defined. We then compare this result with the existing analysis in the quantum theory, where the dynamics was cast in terms of an internal (λ-independent) parameter for which the limit does not exist. We briefly comment on the steps needed to define the corresponding time parameter in the quantum theory for which the limit was shown to exist classically.
12 pages
http://arxiv.org/abs/1209.2766
Anomaly freedom of the vector modes with holonomy corrections in perturbative Euclidean loop quantum gravity
Jian-Pin Wu, Yongge Ma
(Submitted on 13 Sep 2012)
We study the perturbation of the effective Hamiltonian constraint with holonomy correction from Euclidean loop quantum gravity. The Poisson bracket between the corrected Hamiltonian constraint and the diffeomorphism constraint is derived for vector modes. Some specific form of the holonomy correction function ficd is found, which satisfies that the constraint algebra is anomaly-free. This result confirms the possibility of non-trivial holonomy corrections from full theory while preserving anomaly-free constraint algebra in the perturbation framework. It also gives valuable hints on the possible form of holonomy corrections in effective loop quantum gravity.
16 pages, no figures
  • #1,809
http://arxiv.org/abs/1209.3087
Entropy and entanglement in polymer quantization
Tommaso F. Demarie, Daniel R. Terno
(Submitted on 14 Sep 2012)
Polymer quantization is as a useful toy model for the mathematical aspects of loop quantum gravity and is interesting in its own right. Analyzing entropies in the standard Hilbert space and the polymer Hilbert space we show that they converge in the limit of vanishing polymer scale. We derive a general bound that relates entropies of physically equivalent states in unitarily inequivalent representations.
5 pages
http://arxiv.org/abs/1209.3252
A review of the 1/N expansion in random tensor models
Razvan Gurau
Matrix models are a highly successful framework for the analytic study of random two dimensional surfaces with applications to quantum gravity in two dimensions, string theory, conformal field theory, statistical physics in random geometry, etc. Their success relies crucially on the so called 1/N expansion introduced by 't Hooft.
In higher dimensions matrix models generalize to tensor models. In the absence of a viable 1/N expansion tensor models have for a long time been less successful in providing an analytically controlled theory of random higher dimensional topological spaces. This situation has drastically changed recently. Models for a generic complex tensor have been shown to admit a 1/N expansion dominated by graphs of spherical topology in arbitrary dimensions and to undergo a phase transition to a continuum theory.
11 pages. Proceedings of the International Congress on Mathematical Physics 2012 - Topical Section: Quantum Field Theory
  • #1,810
http://arxiv.org/abs/1209.3403
Quantum Cosmology: Effective Theory
Martin Bojowald
(Submitted on 15 Sep 2012)
Quantum cosmology has traditionally been studied at the level of symmetry-reduced minisuperspace models, analyzing the behavior of wave functions. However, in the absence of a complete full setting of quantum gravity and detailed knowledge of specific properties of quantum states, it remained difficult to make testable predictions. For quantum cosmology to be part of empirical science, it must allow for a systematic framework in which corrections to well-tested classical equations can be derived, with any ambiguities and ignorance sufficiently parameterized. As in particle and condensed-matter physics, a successful viewpoint is one of effective theories, adapted to specific issues one encounters in quantum cosmology. This review presents such an effective framework of quantum cosmology, taking into account, among other things, space-time structures, covariance, the problem of time and the anomaly issue.
75 pages, 3 figures, Invited Topical Review for Class. Quantum Grav. 29 (2012) 213001
http://arxiv.org/abs/1209.3623
An Approach to Loop Quantum Cosmology Through Integrable Discrete Heisenberg Spin Chains
Christine C. Dantas
(Submitted on 17 Sep 2012)
The quantum evolution equation of Loop Quantum Cosmology (LQC) -- the quantum Hamiltonian constraint -- is a difference equation. We relate the LQC constraint equation in vacuum Bianchi I separable (locally rotationally symmetric) models with an integrable differential-difference nonlinear Schrödinger type equation, which in turn is known to be associated with integrable, discrete Heisenberg spin chain models in condensed matter physics. We illustrate the similarity between both systems with a simple constraint in the linear regime.
6 pages, submitted to Foundations of Physics
http://arxiv.org/abs/1209.3649
Functional renormalization with fermions and tetrads
Pietro Donà, Roberto Percacci
We investigate some aspects of the renormalization group flow of gravity in the presence of fermions, which have remained somewhat puzzling so far. The first is the sign of the fermionic contribution to the running of Newton's constant, which depends on details of the cutoff. We argue that only one of the previously used schemes correctly implements the cutoff on eigenvalues of the Dirac operator, and it acts in the sense of screening Newton's constant. We also show that Kähler fermions give the same contribution to the running of the cosmological and Newton constant as four Dirac spinors. We then calculate the graviton contributions to the beta functions by imposing the cutoffs on the irreducible spin components of the tetrad. In this way we can probe the gauge dependence of the off-shell flow. The results resemble closely those of the metric formalism, except for an increased scheme-- and (off shell) gauge--dependence.
28 pages, 4 figures
brief mention:
http://arxiv.org/abs/1209.3511
The effective field theory treatment of quantum gravity
John F. Donoghue
(Submitted on 16 Sep 2012)
This is a pedagogical introduction to the treatment of quantum general relativity as an effective field theory...
22 pages, 3 figures. Presented at the Sixth International School on Field Theory and Gravitation, Petropolis, Brazil, April 2012, to be published in the proceedings.
http://arxiv.org/abs/1209.3339
Annual Modulation of Dark Matter: A Review
Katherine Freese, Mariangela Lisanti, Christopher Savage
Direct detection experiments, which are designed to detect the scattering of dark matter off nuclei in detectors, are a critical component in the search for the Universe's missing matter. The count rate in these experiments should experience an annual modulation due to the relative motion of the Earth around the Sun...
37 pages, 7 figures. To appear in Review of Modern Physics
  • #1,811
http://arxiv.org/abs/1209.4038
Fixed points and infrared completion of quantum gravity
Nicolai Christiansen, Daniel F. Litim, Jan M. Pawlowski, Andreas Rodigast
(Submitted on 18 Sep 2012)
The phase diagram of four-dimensional Einstein-Hilbert gravity is studied using Wilson's renormalization group. Smooth trajectories connecting the ultraviolet fixed point at short distances with attractive infrared fixed points at long distances are derived from the non-perturbative graviton propagator. Implications for the asymptotic safety conjecture and further results are discussed.
4 pages, 4 figures
  • #1,812
http://arxiv.org/abs/1209.4295
A review of the large N limit of tensor models
Razvan Gurau
(Submitted on 19 Sep 2012)
Random matrix models encode a theory of random two dimensional surfaces with applications to string theory, conformal field theory, statistical physics in random geometry and quantum gravity in two dimensions. The key to their success lies in the 1/N expansion introduced by 't Hooft. Random tensor models generalize random matrices to theories of random higher dimensional spaces. For a long time, no viable 1/N expansion for tensors was known and their success was limited.
A series of recent results has changed this situation and the extension of the 1/N expansion to tensors has been achieved. We review these results in this paper.
12 pages. Proceedings of The XXIX International Colloquium on Group-Theoretical Methods in Physics, August 20-26 2012, Chern Institute of Mathematics, Nankai University, Tianjin, China
  • #1,813
http://arxiv.org/abs/1209.4374
On the Uniqueness of Kinematics of Loop Quantum Cosmology
Abhay Ashtekar, Miguel Campiglia
The holonomy-flux algebra A of loop quantum gravity is known to admit a natural representation that is uniquely singled out by the requirement of covariance under spatial diffeomorphisms. In the cosmological context, the requirement of spatial homogeneity naturally reduces A to a much smaller algebra, ARed, used in loop quantum cosmology. In Bianchi I models, it is shown that the requirement of covariance under residual diffeomorphism symmetries again uniquely selects the representation of ARed that has been commonly used. We discuss the close parallel between the two uniqueness results and also point out a difference.
9 pages
http://arxiv.org/abs/1209.4539
Holonomy Spin Foam Models: Boundary Hilbert spaces and Time Evolution Operators
(Submitted on 20 Sep 2012)
In this and the companion paper a novel holonomy formulation of so called Spin Foam models of lattice gauge gravity are explored. After giving a natural basis for the space of simplicity constraints we define a universal boundary Hilbert space, on which the imposition of different forms of the simplicity constraints can be studied. We detail under which conditions this Hilbert space can be mapped to a Hilbert space of projected spin networks or an ordinary spin network space.
These considerations allow to derive the general form of the transfer operators which generates discrete time evolution. We will describe the transfer operators for some current models on the different boundary Hilbert spaces and highlight the role of the simplicity constraints determining the concrete form of the time evolution operators.
51 pages, 18 figures
http://arxiv.org/abs/1209.4376
Multi-fractional spacetimes, asymptotic safety and Hořava-Lifgarbagez gravity
Gianluca Calcagni
We compare the recently formulated multi-fractional spacetimes with field theories of quantum gravity based on the renormalization group (RG), such as asymptotic safety and Horava-Lifgarbagez gravity. The change of spacetime dimensionality with the probed scale is realized in both cases by an adaptation of the measurement tools (`rods') to the scale, but in different ways. In the multi-fractional case, by an adaptation of the position-space measure, roughly corresponding to a scale dependence of the coordinates. In the case of RG-based theories, by an adaptation of the momenta. The two pictures are mapped into each other, thus presenting the fractal structure of spacetime in RG-based theories under an alternative perspective.
17 pages, 1 table
http://arxiv.org/abs/1209.4606
Addendum to "A Renormalizable 4-Dimensional Tensor Field Theory"
Joseph Ben Geloun, Vincent Rivasseau
This note fills a gap in the article with title above [1]. We provide the proof of Equation (82) of Lemma 5 in [1] and thereby complete its power counting analysis with a more precise next-to-leading-order estimate.
10 pages, 4 figures
  • #1,814
http://arxiv.org/abs/1209.4892
On the role of the Barbero-Immirzi parameter in discrete quantum gravity
Bianca Dittrich, James P. Ryan
(Submitted on 21 Sep 2012)
The 1-parameter family of transformations identified by Barbero and Immirzi plays a significant role in non-perturbative approaches to quantum gravity, among them Loop Quantum Gravity and Spin Foams. It facilitates the loop quantization programme and subsequently the Barbero-Immirzi parameter (gamma) arises in both the spectra of geometrical operators and in the dynamics provided by Spin Foams. However, the debate continues as to whether quantum physics should be Barbero-Immirzi parameter dependent. Starting from a discrete SO(4)-BF theory phase space, we find two possible reductions with respect to a discrete form of the simplicity constraints. The first reduces to a phase space with gamma-dependent symplectic structure and more generally in agreement with the phase space underlying Loop Quantum Gravity restricted to a single graph - a.k.a. Twisted Geometries. The second, fuller reduction leads to a gamma-independent symplectic structure on the phase space of piecewise-flat-linear geometries - a.k.a. Regge geometries. Thus, the gamma-dependence of physical predictions is related to the choice of phase space underlying the quantization.
16 + 12 pages
brief mention:
http://arxiv.org/abs/1209.4786
Spectral dimension flow on continuum random multigraph
Georgios Giasemidis, John F. Wheater, Stefan Zohren
We review a recently introduced effective graph approximation of causal dynamical triangulations (CDT), the multigraph ensemble. We argue that it is well suited for analytical computations and that it captures the physical degrees of freedom which are important for the reduction of the spectral dimension as observed in numerical simulations of CDT. ...
6 pages, 1 figure, to appear in the Proceedings of Sixth International School on Field Theory and Gravitation 2012 (Petropolis, Brazil)
http://arxiv.org/abs/1209.4798
Aspects of dynamical dimensional reduction in multigraph ensembles of CDT
We study the continuum limit of a "radially reduced" approximation of Causal Dynamical Triangulations (CDT), so-called multigraph ensembles, and explain why they serve as realistic toy models to study the dimensional reduction observed in numerical simulations of four-dimensional CDT...
4 pages, 1 figure, Presented at "Gravity, Quantum, and Black Holes" session of IC-MSQUARE 2012, Budapest
  • #1,815
http://arxiv.org/abs/1209.5284
The Tensor Track: an Update
Vincent Rivasseau
(Submitted on 24 Sep 2012)
The tensor track approach to quantum gravity is based on a new class of quantum field theories, called tensor group field theories (TGFTs). We provide a brief review of recent progress and list some desirable properties of TGFTs. In order to narrow the search for interesting models, we also propose a set of guidelines for TGFT's loosely inspired by the Osterwalder-Schrader axioms of ordinary Euclidean QFT.
http://arxiv.org/abs/1209.5060
C*-algebras of Holonomy-Diffeomorphisms & Quantum Gravity I
Johannes Aastrup, Jesper M. Grimstrup
(Submitted on 23 Sep 2012)
A new approach to a unified theory of quantum gravity based on noncommutative geometry and canonical quantum gravity is presented. The approach is built around a *-algebra generated by local holonomy-diffeomorphisms on a 3-manifold and a quantized Dirac type operator; the two capturing the kinematics of quantum gravity formulated in terms of Ashtekar variables. We prove that the separable part of the spectrum of the algebra is contained in the space of measurable connections modulo gauge transformations and we give limitations to the non-separable part. The construction of the Dirac type operator -- and thus the application of noncommutative geometry -- is motivated by the requirement of diffeomorphism invariance. We conjecture that a semi-finite spectral triple, which is invariant under volume-preserving diffeomorphisms, arise from a GNS construction of a semi-classical state. Key elements of quantum field theory emerge from the construction in a semi-classical limit, as does an almost commutative algebra. Finally, we note that the spectrum of loop quantum gravity emerges from a discretization of our construction. Certain convergence issues are left unresolved. This paper is the first of two where the second paper is concerned with mathematical details and proofs concerning the spectrum of the holonomy-diffeomorphism algebra.
http://arxiv.org/abs/1209.5057
C*-algebras of Holonomy-Diffeomorphisms & Quantum Gravity II
We introduce the holonomy-diffeomorphism algebra, a C*-algebra generated by flows of vectorfields and the compactly supported smooth functions on a manifold. We show that the separable representations of the holonomy-diffeomorphism algebra are given by measurable connections, and that the unitary equivalence of the representations corresponds to measured gauge equivalence of the measurable connections. We compare the setup to Loop Quantum Gravity and show that the generalized connections found there are not contained in the spectrum of the holonomy-diffeomorphism algebra in dimensions higher than one. This is the second paper of two, where the prequel gives an exposition of a framework of quantum gravity based on the holonomy-diffeomorphism algebra.
http://arxiv.org/abs/1209.4948
Processing quantum information with relativistic motion of atoms
Eduardo Martin-Martinez, David Aasen, Achim Kempf
(Submitted on 22 Sep 2012)
We show that particle detectors, such as 2-level atoms, in non-inertial motion (or in gravitational fields) could be used to build quantum gates for the processing of quantum information. Concretely, we show that through suitably chosen non-inertial trajectories of the detectors the interaction Hamiltonian's time dependence can be modulated to yield arbitrary rotations in the Bloch sphere due to relativistic quantum effects.
http://arxiv.org/abs/1209.5196
Evidence for Bohmian velocities from conditional Schrodinger equation
H. Nikolic
It is often argued that measurable predictions of Bohmian mechanics cannot be distinguished from those of a theory with arbitrarily modified particle velocities satisfying the same equivariance equation. By considering the wave function of a closed system in a state with definite total energy, we argue that a distinction in measurable predictions is possible. Even though such a wave function is time-independent, the conditional wave function for a subsystem depends on time through the time-dependent particle trajectories not belonging to the subsystem. If these trajectories can be approximated by classical trajectories, then the conditional wave function can be approximated by a wave function which satisfies Schrodinger equation in a classical time-dependent potential, which is in good agreement with observations. However, such an approximation cannot be justified for particle velocities significantly deviating from the Bohmian ones, implying that Bohmian velocities are observationally preferred.
http://arxiv.org/abs/1209.5271
Using Newton's Law for Dark Energy
Paul Frampton
A model is introduced in which Newton's law is modified between matter and dark energy corpuscles (DECs). The model predicts that the DEC component is presently decelerating in its expansion at 14% of the magnitude of the matter expansion acceleration. In the future, expansion of the DEC universe will continue to decelerate.
  • #1,816
This paper is very beautiful. Clear writing makes it broadly understandable (partly John Baez influence on Derek I imagine):
http://arxiv.org/abs/1210.0019
Lifting General Relativity to Observer Space
Steffen Gielen, Derek K. Wise
(Submitted on 28 Sep 2012)
The 'observer space' of a Lorentzian spacetime is the space of future-timelike unit tangent vectors. Using Cartan geometry, we first study the structure a given spacetime induces on its observer space, then use this to define abstract observer space geometries for which no underlying spacetime is assumed. We propose taking observer space as fundamental in general relativity, and prove integrability conditions under which spacetime can be reconstructed as a quotient of observer space. Additional field equations on observer space then descend to Einstein's equations on the reconstructed spacetime. We also consider the case where no such reconstruction is possible, and spacetime becomes an observer-dependent, relative concept. Finally, we discuss applications of observer space, including a geometric link between covariant and canonical approaches to gravity.
34 pages
http://arxiv.org/abs/1210.0418
Interpretation of the triad orientations in loop quantum cosmology
Claus Kiefer, Christian Schell
(Submitted on 1 Oct 2012)
Loop quantum cosmology allows for arbitrary superpositions of the triad variable. We show here how these superpositions can become indistinguishable from a classical mixture by the interaction with fermions. We calculate the reduced density matrix for a locally rotationally symmetric Bianchi I model and show that the purity factor for the triads decreases by decoherence. In this way, the Universe assumes a definite orientation.
12 pages, 1 figure
Late addition, somehow overlooked in July when it came out:
http://arxiv.org/abs/1207.6734
Renormalization of Tensorial Group Field Theories: Abelian U(1) Models in Four Dimensions
Sylvain Carrozza, Daniele Oriti, Vincent Rivasseau
(Submitted on 28 Jul 2012)
We tackle the issue of renormalizability for Tensorial Group Field Theories (TGFT) including gauge invariance conditions, with the rigorous tool of multi-scale analysis, to prepare the ground for applications to quantum gravity models. In the process, we define the appropriate generalization of some key QFT notions, including: connectedness, locality and contraction of (high) subgraphs. We also define a new notion of Wick ordering, corresponding to the subtraction of (maximal) melonic tadpoles. We then consider the simplest examples of dynamical 4-dimensional TGFT with gauge invariance conditions for the Abelian U(1) case. We prove that they are super-renormalizable for any polynomial interaction.
33 pages, 8 figures
EDIT: I now see that this was added to the bibliography when it came out, in post #1781,
https://www.physicsforums.com/showthread.php?p=4016291#post4016291
but I overlooked it when sifting thru the quarter's papers to assemble a list for the poll.
EDIT: Tom, interesting comment about Kiefer! I had a vague notion of him as an independent, able to do research in LQG and make a significant contribution, but apt equally well three months later to post an article in some other branch of QG. I will look more carefully now.
  • #1,817
Claus Kiefer is joining the LQC community ...
  • #1,818
http://arxiv.org/abs/1210.0849
The polymer quantization in LQG: massless scalar field
Marcin Domagala, Michal Dziendzikowski, Jerzy Lewandowski
(Submitted on 2 Oct 2012)
The polymer quantization of matter fields is a diffeomorphism invariant framework compatible with Loop Quantum Gravity. Whereas studied by itself, it is not explicitly used in the known completely quantizable models of matter coupled to LQG. In the current paper we apply the polymer quantization to the model of massless scalar field coupled to LQG. We show that the polymer Hilbert space of the field degrees of freedom times the LQG Hilbert space of the geometry degrees of freedom admit the quantum constraints of GR and accommodate their explicit solutions. In this way the quantization can be completed. That explicit way of solving the quantum constraints suggests interesting new ideas.
19 pages, no figures, Contribution to the Proceedings of the 3rd Quantum Geometry and Quantum Gravity School in Zakopane (2011)
briefly noted, possibly of general interest:
http://arxiv.org/abs/1210.0544
Dark matter and cosmic structure
Carlos S. Frenk, Simon D. M. White
We review the current standard model for the evolution of cosmic structure, tracing its development over the last forty years and focusing specifically on the role played by numerical simulations and on aspects related to the nature of dark matter.
27 pages. Invited review in Annalen der Physik - www.ann-phys.org
  • #1,819
briefly noted:
http://arxiv.org/abs/1210.0944
Reverse Engineering Quantum Field Theory
Robert Oeckl (CCM-UNAM)
An approach to the foundations of quantum theory is advertised that proceeds by "reverse engineering" quantum field theory. As a concrete instance of this approach, the general boundary formulation of quantum theory is outlined.
5 pages,
  • #1,820
http://arxiv.org/abs/1210.1485
Loop Quantum Gravity Phenomenology: Linking Loops to Physics
Florian Girelli, Franz Hinterleitner, Seth Major
(Submitted on 4 Oct 2012)
Research during the last decade demonstrates that effects originating on the Planck scale are currently being tested in multiple observational contexts. In this review we discuss quantum gravity phenomenological models and their possible links to loop quantum gravity. Particle frameworks, including kinematic models, broken and deformed Poincaré symmetry, non-commutative geometry, relative locality and generalized uncertainty principle, and field theory frameworks, including Lorentz violating operators in effective field theory and non-commutative field theory, are discussed. The arguments relating loop quantum gravity to models with modified dispersion relations are reviewed, as well as, arguments supporting the preservation of local Lorentz invariance. The phenomenology related to loop quantum cosmology is briefly reviewed, with a focus on possible effects that might be tested in the near future. As the discussion makes clear, there remains much interesting work to do in establishing the connection, or lack thereof, between the fundamental theory of loop quantum gravity and these specific phenomenological models, in determining observational consequences of the characteristic aspects of loop quantum gravity, and in further refining current observations. Open problems related to these developments are highlighted.
75 pages. 2 figures. Invited review for SIGMA Special Issue "Loop Quantum Gravity and Cosmology"
http://arxiv.org/abs/1210.1528
Experimentally testing asymptotically safe quantum gravity with photon-photon scattering
Astrid Eichhorn
Matter-quantum gravity interactions can be used for direct and also indirect experimental tests of quantum gravity. We focus on photon-photon scattering in asymptotically safe gravity as a direct test of the small-scale structure of spacetime, and discuss how near-future experiments can probe asymptotic safety in a setting with large extra dimensions.
3 pages. Prepared for the proceedings of the 13th Marcel Grossmann meeting
