Low pressure, high velocity flow vs static pressure
The discussion centers on the feasibility of releasing a compressible flow at 0.99 barA and 300 m/s into a 1 barA environment. It highlights that while the static pressure of the flow may be lower than the release pressure, the dynamic pressure significantly contributes to the total pressure, allowing for successful release. The conversation raises questions about the measurement of pressures and the conditions necessary for such a scenario, including the potential need for a divergent nozzle. Participants debate the establishment of lower pressure upstream and the implications of using a De Laval nozzle for achieving high velocity flow. Overall, the consensus suggests that if the total pressure exceeds the release pressure, the flow can be released effectively.
T C
TL;DR Summary
I want to discuss an imaginary scenario here where we have a compressible flow flowing through a tube at 0.99 barA pressure and at 300 m/s velocity and that flow is released into 1 barA pressure. Is it possible or not.
In this scenario, we have a compressible flow at 0.99 barA pressure and flowing at 300 m/s velocity and is released into 1 barA pressure. Point is, whether the flow can be released at 1 barA or not at the release pressure is higher than the pressure of the compressible fluid inside the tube. And here is my thought in this regards. The static pressure of the flow may be lower than the release pressure, but it has another pressure and that's the dynamic pressure. At 300 m/s velocity, the dynamic pressure is around 0.7 barA and when that's added to the existing static pressure of the compressible fluid, the total pressure far exceeds the release pressure and the flow can be easily released. For the sake of simplicity, it has been assumed that the tube is frictionless and the static fluid at 1 barA pressure, where this flow is released, is the same and density difference is negligible.
How are you measuring each of those pressures?
Is this supposed to be a steady state flow? How was the flow at the lower pressure established on the upstream side?
I don't see how your situation can exist unless there is a divergent nozzle at the tube exit.
Likes russ_watters
Static pressures are chosen and dynamic velocity calculators available on net. Let's consider the both the fluids at standard temperature. The density can be calculated easily and just put those values into the calculator and you can get the results.
Can't understand what you want to mean.
Why a divergent section would be necessary?
In case of De Laval nozzle, the release pressure (mentioned as ambient pressure in the page) can be 2-3 times higher than the pressure at the exit of the nozzle. If that's true, that simply means a high velocity flow of lower pressure can easily enter at higher pressure if the gross i.e. total sum of static and dynamic is higher than the release pressure.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
