I Magnet through Pipe Experiment, continued
The discussion centers on how a falling magnet induces currents in a pipe, which slows its descent due to the changing magnetic field. Participants explore the momentum of these induced currents and question how it dissipates after the magnet exits the pipe. There is a debate on whether the system behaves similarly to an LC circuit and whether quantum mechanics is relevant to understanding the electron momentum involved. Some contributors assert that classical electrodynamics sufficiently explains the phenomenon without invoking quantum physics. The conversation highlights the interplay between induced currents and external forces affecting the system's momentum.
Samson4
The changing magnetic field of a falling magnet induces currents in the pipe that slows it's fall through the pipe.
Question:
If the induced currents are decreasing the magnets descent then they must themselves have momentum. How is it dissipated once the magnet has passed through the end of the pipe? Does it simply oscillate similar to an lc circuit?
The pipe in which current take place undertakes force downward. One should apply upward force from outside so that it does not move.
That applied force increases the momentum that is carried in the currents induced by the magnet. If they were both free falling then technically it would be the same as them being stationary. I'm asking if the magnet exciting the pipe is similar to interrupting dc current.
I think we're in the realm of quantum physics when we deal with electron momentum.
There's no quantum mechanics required for this problem - we're working with bulk currents and properties of matter that are adequately described by classical electrodynamics.
Quoting the OP: "That applied force increases the momentum that is carried in the currents induced by the magnet."
Clearly he was referring to the momentum carried by the electrons, not the magnet. It's a subject for quantum physics.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
