Magnetism, Credit-Card magnetic strips
Experiments on Mythbusters revealed that a magnetic field of 1000 gauss is necessary to corrupt credit card magnetic strips. The discussion revolves around calculating how close a credit card can be held to a straight wire carrying a current of 2.5 A without damage. Participants clarify that the magnetic field equation for a solenoid is not applicable to a straight wire. One user emphasizes the importance of showing work in problem-solving to facilitate better assistance. The conversation highlights the need for proper methodology in physics calculations.
Nnk
Experiments carried out on the television show Mythbusters determined that a magnetic field of 1000 gauss is needed to corrupt the information on a credit card's magnetic strip. (They also busted the myth that a credit card can be demagnetized by an electric eel or an eelskin wallet.) Suppose a long, straight wire carries a current of 2.5 A. How close can a credit card be held to this wire without damaging its magnetic strip?
I'm not quite sure how to go about this problem, could anyone please explain it?
Magnetic field of a solenoid:
Where n=N/L
Answer: 5.0µm
Hi Nn,
Your relevant equation isn't for a simple straight wire. Look e.g. here
Oh, and: next time use the template as it's intended (I.e. show some work under 3, not the answer from the back of the book) :)
BvU said:
Hi Nn,
Thanks for pointing that out! I didn't know how to calculate it, so I put the correct answer there for those who could help
