Magnitude of gravitational acceleration at distance r
The discussion focuses on deriving the ratio of gravitational acceleration at a distance r from the Earth's center to that at the Earth's surface. The key equation used is g(r) = -GM/r^2, with g(RE) = -GM/RE^2, leading to the ratio g(r)/g(RE) = RE^2/r^2. Participants clarify that the formula F = mg is only applicable near the Earth's surface and should be set aside for this problem. The final expression indicates that gravitational acceleration decreases with the square of the distance from the Earth's center, confirming the inverse square law of gravity.
shyguy79
Find an expression for the ratio g(r)/g(RE) of the magnitude of the gravitational acceleration at a distance r from the centre of the Earth to that at the surface of the Earth, for r > RE, i.e. for points above the surface of the Earth.
F(grav) = -Gm1m2 / r^2
I was thinking about making r the subject of the equation and hence becoming R(E) and then substituting into the original equation but it doesn't seem to show anything.
I've been looking at this for a while but nothing is clicking any pointers would be very much appreciated as always.
At the surface of the Earth the force between a mass m and the Earth is
F = mg = ma but that is also equal to GmM/R^2 where R is the radius of the Earth. If the mass m is not near the surface of the Earth R will be different as will the acceleration.
Can you put it together?
I'm kinda confused.. but it makes sense! Was looking at Fgrav = mg at the surface of the Earth and yet above the surface of the Earth Fgrav = -Gm1m2 / r^2. I have substituted F=mg into F= -Gm1m2 / r^2 to become mg=-Gm1m2 / r^2 and then g =-Gm/r^2 but don't see how this helps
Doesn't this essentially say that the force of gravity on a body above the surface of the Earth is equal to the mass of the planet x gravitational constant x the inverse square of the radius? Or am I barking up the wrong tree?
Should I be looking at dividing F= -Gm1m2 / r^2 by F=mg?
You should lay aside the formula f = mg for this problem; it's only applicable for motions that occur very close to the Earth's surface, and is in fact an approximation derived from the general formula, g(r) = G*M/r2 for r equal to the radius of the Earth ± small amounts. The particular value of g(r) obtained with r = RE is assigned to the constant 'g'.
Why not begin by writing the general formula for the acceleration twice, one for each of the radii: r and RE. Then form the ratio of the two expressions, cancelling common terms.
Ok, here's what I've done..
Taken g(r) = -GM/r^2 and g(Re) = -GM/Re^2 so putting and cancelling out G and M then g(r)/g(Re) = Re^2/r^2
Does this look plausible? I've put in a few figures and when both g(re) and g(r) = 6x10^6m then the ratio is 1... The shape of the graph is also an inverse exponential...
Yes, that's fine.
Thank you very much for your help!
  • · Replies 23 ·
