PeterDonis
Mentor
- 49,059
- 25,147
No. There is no interaction between branches. The branches are the outcome of the interaction.DrChinese said:There is an interaction I presume between each possible individual MWI branch when an observed particle interacts with the observer environment.
For example, consider a single electron passing through a Stern-Gerlach device. Say the electron starts in the z-spin up state, and the Stern-Gerlach device is oriented in the x direction. Then the state before the interaction is
\ket{z+} \ket{\text{input beam}}
and the state after the interaction is
\frac{1}{\sqrt{2}} \left( \ket{x+} \ket{\text{x-spin up beam}} + \ket{x-} \ket{\text{x-spin down beam}} \right)
The former state is a product state, but the latter state is an entangled state; the entanglement is produced by the interaction between the electron and the Stern-Gerlach apparatus.
This interaction by itself does not necessarily produce decoherence, since the beams can in principle be recombined; to complete a spin measurement one needs to put detectors in each output beam and observe which one fires. But the entangled state produced by that further interaction looks simliar to the above, just with an additional ket for the detector system.
In the Stern-Gerlach case, the entanglement is between the spin and the momentum of the electron. The specific degrees of freedom that are entangled will depend on the particular interaction.DrChinese said:I don't know what you would say is the entangled attribute/observable though.
I'm not sure why a conserved quantity would be relevant.DrChinese said:Or what the conserved quantity is.
