- #176
jim hardy
Dearly Missed
- 9,832
- 4,896
There's a description here of what the 'detectives' did with the pings...
http://www.pprune.org/rumours-news/535538-malaysian-airlines-mh370-contact-lost-403.html#post8399949
more at that link.
The famous "Arcs" i believe came from angle measurements off the vertical, probably they are circles centered about the satellite's location over earth.
Refined analysis from inmarsat
in recent days inmarsat developed a second innovative technique which considers the velocity of the aircraft relative to the satellite. Depending on this relative movement, the frequency received and transmitted will differ from its normal value, in much the same way that the sound of a passing car changes as it approaches and passes by. This is called the doppler effect. The inmarsat technique analyses the difference between the frequency that the ground station expects to receive and that actually measured. This difference is the result of the doppler effect and is known as the burst frequency offset.
The burst frequency offset changes depending on the location of the aircraft on an arc of possible positions, its direction of travel, and its speed. In order to establish confidence in its theory, inmarsat checked its predictions using information obtained from six other b777 aircraft flying on the same day in various directions. There was good agreement.
While on the ground at kuala lumpur airport, and during the early stage of the flight, mh370 transmitted several messages. At this stage the location of the aircraft and the satellite were known, so it was possible to calculate system characteristics for the aircraft, satellite, and ground station.
During the flight the ground station logged the transmitted and received pulse frequencies at each handshake. Knowing the system characteristics and position of the satellite it was possible, considering aircraft performance, to determine where on each arc the calculated burst frequency offset fit best.
The analysis showed poor correlation with the northern corridor, but good correlation with the southern corridor, and depending on the ground speed of the aircraft it was then possible to estimate positions at 0011 utc, at which the last complete handshake took place. I must emphasise that this is not the final position of the aircraft.
more at that link.
