Mass of Water Increasing with Heating
In summary: The thing to look up is the four momentum, which is a four vector comprised of the energy and momentum of the particle. The modulus of the four momentum is the mass of the particle. You can, of course, add vectors, so if you have a system of two or more particles you can write the total four momentum of the system as the sum of the four momenta of the particles. The modulus of that sum of vectors is the mass of the system - but the modulus of a sum of vectors is not in general equal to the sum of their moduli. So the mass of a system is not the sum of the individual masses of its constituent particles.
Ebi Rogha
24
TL;DR Summary
Mass-energy relation
Suppose we heat up a sealed container of water (no vapour escape), will it mass increase according to E=m.c^2 ?
Likes Delta2
Yes.
Likes Orodruin, vanhees71 and Ebi Rogha
If by mass you mean weight due to gravity, then yes.
E=mc2 is really referring to the rest mass of whatever, water molecules in your case. The more general version is E2 = m2c4 + p2c2, where p is momentum. When you heat water, you increase the momentum of the molecules, which in turn increases the energy content, which creates more gravitational force. But in this version the mass doesn't change.
This is mostly a semantic issue, I think. Older texts will describe the mass as increasing with velocity (relativistic mass).
Likes Delta2
It is true that the water's weight will increase, but that's not a separate thing from the increase in its invariant mass. See below.
No, this is not correct. The correct statement is that heating the water increases the average kinetic energy of the molecules and their average momentum (in the center of mass frame). One does not cause the other; they are both part of the same thing.
The increase in the kinetic energy of the molecules, in the center of mass frame, increases the invariant mass of the water as an overall system.
Gravity is not a force in relativity. The weight of the water increases (assuming it is at rest in a constant gravitational field) because its invariant mass increases. If we want to talk about the effect on the water as a source of gravity, that's a whole other issue that I don't think is part of the OP's question and probably deserves a separate thread of its own.
This is not correct. See above.
  • Love
Likes docnet, FactChecker, Ebi Rogha and 2 others
It can also refer to the invariant mass of the water as an overall system (and to be strictly correct we would also include the container in the overall system). That is what I took the OP to be asking about. Invariant mass is not additive, so the invariant mass of the overall system is not the same as the sum of invariant masses of all the individual constituents (the molecules).
Likes Ebi Rogha and DaveE
Could you pleass explain this?
Imagine a system of two particles of equal mass ##m##. If the particles are relatively at rest, then the mass of the system is ##2m##.
If, however, the particles have equal and opposite non-zero momenta, then the mass of the system is greater than ##2m##.
Are you able to do the calculation?
Likes Ebi Rogha
Let's stick to special relativity and look at the water in global thermal equilibrium. Then there's a reference frame, where the water is at rest as a whole and it has an energy content dependent on the temperature. Heating up the water means the energy of the water in this refernce frame changes by ##\Delta q## (where ##\Delta q## is the added heat energy). Thus the invariant mass of the water changes by ##\Delta m=\Delta q/c^2## since by definition the invariant of a system is the total energy of this system in its center-of-momentum (NOT center-of-mass!) frame of reference.
Likes DaveE and Ebi Rogha
Thanks for the explanation.
I am not sure how to the calculation, if you could please help, that will also help to understand the concept.
If you are serious about this you should post questions like this under homework.
Likes Ebi Rogha
The thing to look up is the four momentum, which is a four vector comprised of the energy and momentum of the particle. The modulus of the four momentum is the mass of the particle. You can, of course, add vectors, so if you have a system of two or more particles you can write the total four momentum of the system as the sum of the four momenta of the particles. The modulus of that sum of vectors is the mass of the system - but the modulus of a sum of vectors is not in general equal to the sum of their moduli. So the mass of a system is not the sum of the masses of its components in relativity.
Likes DaveE
FAQ: Mass of Water Increasing with Heating
How does the mass of water change when it is heated?
When water is heated, the mass increases due to the addition of thermal energy. This causes the water molecules to move faster and spread out, resulting in a higher mass per unit volume.
Why does water have a higher mass when heated?
Water has a higher mass when heated because heat energy is added to the system, causing the water molecules to move faster and take up more space. This increased movement and expansion of the molecules results in a higher mass per unit volume.
Does the mass of water always increase when heated?
Yes, the mass of water always increases when heated. This is because the added thermal energy causes the water molecules to move faster and take up more space, resulting in a higher mass per unit volume.
How does the mass of water relate to its temperature?
The mass of water and its temperature are directly related. As the temperature of water increases, its mass also increases due to the addition of thermal energy. Conversely, as the temperature decreases, the mass of water also decreases.
Can the mass of water decrease with heating?
No, the mass of water cannot decrease with heating. This is because the addition of thermal energy always causes the water molecules to move faster and take up more space, resulting in a higher mass per unit volume.
