Masses on incline plane and pulley.
The discussion centers on a physics problem involving a system of three masses connected by pulleys, with one mass moving up and two moving down an incline with friction. The user sets up a force equation to find the system's acceleration, incorporating gravitational forces and friction. After calculating, they find the acceleration to be 3.43 m/s². The user realizes they initially overlooked the parallel force component in their calculations. Ultimately, they confirm their solution is correct and express satisfaction with resolving the issue.
i<3physics
A suspended 2.87 kg mass is moving up, a 1.5 kg mass slides down the ramp, a suspended 8.4 kg mass on the left is moving down. There is friction between the block and the ramp. The acceleration of gravity is 9.8 m/s2 . The pulleys are massless and frictionless.
Find the acceleration of the 3 block system.
Here is a diagram
http://img8.yfrog.com/i/capturexki.jpg/
F=ma
Friction=μN
F parallel: mgsinφ
F perpendicular: mgcosineφ
Sumation equation I set up (mass 1= 8.4kg, mass 2=1.5kg, mass 3=2.87kg mt=total mass)
m1g-m2g(sinφ)-friction-m3g=mtg
after the numbers are plugged in:
(8.4)(9.8)-(1.5)(9.8)sin36-(0.14)(1.5)(9.8)cos36-2.87(9.8)=12.77a
acceleration would equal=3.43 m/s2
is this correct?
i think your attempt is exactly what the question required
I figured it out...
I was forgetting to add the parallel force to the driving force.
All is well now, thanks!
  • · Replies 68 ·
13K
  • · Replies 23 ·
