Mastering Physics: 'weighing lunch': spring oscillation
The problem involves a plate with turkey slices dropped onto it, causing vertical simple harmonic motion (SHM) due to an inelastic collision. The initial equilibrium position is calculated using the plate's mass and spring constant, leading to a displacement of 0.0196 m. After determining the velocity of the turkey upon impact and applying conservation of momentum, the final amplitude of oscillation is derived. The calculated amplitude is approximately 0.029462 m, with a suggestion to carry values to extra digits to minimize rounding errors. The final answer is noted as 0.027 m, indicating a minor discrepancy that may arise from initial displacement calculations.
louza8
For lunch you and your friends decide to stop at the nearest deli and have a sandwich made fresh for you with 0.100 {\rm kg}of turkey. The slices of turkey are weighed on a plate of mass 0.400 {\rm kg} placed atop a vertical spring of negligible mass and force constant of 200 {\rm N/m}. The slices of turkey are dropped on the plate all at the same time from a height of 0.250 {\rm m}. They make a totally inelastic collision with the plate and set the scale into vertical simple harmonic motion (SHM). You may assume that the collision time is extremely small.
What is the amplitude of oscillations A of the scale after the slices of turkey land on the plate?
Express your answer numerically in meters and take free-fall acceleration to be g = 9.80{\rm m/s}^2.
F=-kx
deltaW=0.5kx^2
deltaW=0.5mv^2
mv+mv=(m+m)vf (inelastic)
m=0.1kg
m2=0.4k
k=200N/m
h=0.25
Initial equilibrium with 0.4kg plate:
ma=kx
(0.4*9.81)/200 = x
x=0.0196m
New equilibrium position with turkey
Need velocity of turkey+plate
v^2=u^2 + 2ash
=sqrt(2*9.81*0.25)
v=2.21472m/s
momentum after inelastic collision
mv=(m+m)v_f
(0.1*2.215)/0.5=0.442m/s
equate energies
0.5(m+m)v^2 + 0.5kx^2 = 0.5kA^2
sqrt([0.5(0.5)0.442^2 + 0.5(200)(0.0196^2)]/100)
A=0.029462m
so this says kinetic energy of turkey+plate + energy in initial displacement = final energy
answer is 0.027 I'm not sure where I stuffed up, i think in the initial displacement maybe?
no turkies were harmed in writing this question
With out going through it step by step, it looks right and your answer is close enough to reason that, try carrying the values to an extra digit to remove possible rounding errors.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
