Math modelling diffrential equation question?
Eveflutter
So there's this question I've to do. I got through until a certain point and now I'm stuck. >->
1&2The question:
The rate of deterioration of a product in a container is proportional to the amount of product present. At time t, the amount of product is x.
(i) State the diffrential equation relating x and t and solve the general solution to show that x=Ae-kt where A is an arbitrary contant and k is the contant of proportionality.
(ii) Before t=0, no product was present in the container. At t=0, P amount of the product was added to the container. When t=1, the amount of product in the container was Pq, where q is a constant such that 0<q<1. Show that x=Pqt.
(iii) When t=1 and again when t=2, another P amount of x was added to the container. Show that the amount of product in the container immediately after t=2 was P(q2+q+1)
3I got through with the first two parts:
(i) dx/dt=-kx
-> x=e-kt+c
-> x=Ae-kt , A=ec
(ii)when t=0, x=P
-> A=P
-> x= Pe-kt
when t=1, x=Pq
-> Pq=Pe-kt
-> q=e-kt
-> x=Pqt
I'm stuck at part (iii)
I tried reasoning it out but I don't know. Would the equation x=Pqt change since the intials are now changing twice (at t=1 and t=2)? But if so, how would I get the new ones from tha information?
Alright so as t approahes 1, x tends to Pq. At t=1 the amount of product changes to Pq+P. Then as t approaches 2, x deteriorates from Pq+P. But by how much?? Let's say it deteriorates till an amount B? Now at t=2, the amount of product goes to B+P.
I guess the P part of the required result (P(q2+q+1)) is that P in B+P. How do i get B?
I would really appreciate any help on this question, thank you!
1&2The question:
(i) dx/dt=-kx
-> x=e-kt+c
-> x=Ae-kt , A=ec
(ii)when t=0, x=P
-> A=P
-> x= Pe-kt
when t=1, x=Pq
-> Pq=Pe-kt
-> q=e-kt
-> x=Pqt
Think of it this way. The amount ##P## at ##t=0## decreases according to ##Pq^t##. The amount ##P## added at ##t=1## decreases like ##Pq^{t-1}## (it's just 1 second delayed from the first). Then at ##t=2## you add ##Pq^{t-2}##. So the total after ##t=2## is ##Pq^t+Pq^{t-1}+Pq^{t-2}##. Correct?
Ooooh! I understood what you were doing but not why you were doing it but it took me a couple minutes to completely get it. Thank you so much! I really appreicate your answer :)
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
