- #71
Studiot
- 5,440
- 9
Since I have done all the work for you in the votlage analysis, you could also perform a similar analysis with current instead of voltage.
Allow a current I to flow from A to B through your network and calculate the currents in each resistor in terms of I. (no voltage assumptions are required in this case)
Assemble a total power equation as before using power = (curent in each resistor)2 time the resistance.
Solve for I using the term with the largest coefficient.
Back substitute I to get the total power.
This was my original suggestion about current. I have emboldened the important point.
Just as when working in terms of voltage, current did not appear anywhere
When working in terms of current voltage will not appear at all.
Here is a start
Let a current I enter the network at A and leave at B.
It is usual to work in terms of conductance (=reciprocal of resistance) for current.
So at the first branch the branch conductances are 0.02 through the 50 ohm and 0.025
Through the other leg.
The current I divides in proportion to the ratio of the conductance of each leg to the total.
So the current in the 50 ohm resistor is
[tex]I\left( {\frac{{0.02}}{{0.02 + 0.025}}} \right)[/tex]
And the current in the other leg is
[tex]I\left( {\frac{{0.025}}{{0.02 + 0.025}}} \right)[/tex]
further subdivision of this leg will yield the other currents
To assemble the power equation we use P = I2R (as we used P = V2/R before).
Can you take it from here?
