Maximum speed of an object after a spring
The discussion focuses on calculating the maximum speed and acceleration of a mass connected to a spring on a frictionless track. The mass is 534 g, the spring constant is 6 N/m, and the initial displacement is 2 cm. Participants discuss the relevant formulas, including potential energy in the spring, PE=(1/2)(k)(x²), and the need for proper calculations to determine maximum speed and acceleration. One user initially calculated a maximum speed of 0.037 m/s, which was questioned as being too low, prompting requests for detailed calculations. Accurate application of the formulas is essential for determining the correct values.
liamtcarroll
A 534 g mass is connected to a light spring of
force constant 6 N/m that is free to oscillate
on a horizontal, frictionless track. The mass
is displaced 2 cm from the equilibrium point
and released from rest.
What is the maximum speed of the mass?
What is the maximum acceleration of the mass?
I found the period to be 1.87
Now I don't know what formula to use for the maximum speed, or to find the maximum acceleration.
Do you know the formula for the energy stored in a spring? What will the stored energy be when the mass is at max speed?
is it Hooke's law?
wait is it PE=(1/2)(k)(x²)?
i got .037 m/s for my speed, does that sound right?
Sounds too low. Pls post your working.
