Measuring Angular Velocity of a Hinged Iron Bar
To measure the angular velocity of a 35 cm hinged iron bar rotating 45 degrees in approximately 20 ms, a video can be recorded with a protractor in the background for reference. The video should be taken at 30 frames per second to calculate angular velocity by measuring the angle change between frames. Clarification is needed regarding the source of angular motion and any potential friction affecting the bar's movement. Understanding these factors will enhance the accuracy of the angular velocity measurement. Detailed explanations and visuals will lead to more precise assistance.
Cesare
Good morning,
I have an iron bar (35 cm long) hinged on an axis. The path of this bar is limited to 45 degrees.
I have to measure the angular velocity of the bar when it rotates 45 degrees. I need to get a graph of variation of the angular velocity along the 45 degree paths. The time taken to cover 45 degrees, is about 20ms
Can You help me?
Cesar
Ave Cesar, :welcome:
This is still rather ambiguous. Can you explain a bit clearer and post a picture ?
I have attached a photo.
I would put a protractor in the background, then take a video. From the video you can see change in angle frame-by-frame.
Likes Bandit127
I need angular velocity and not only angle.
And what is it that causes the anglar motion ? Where does the angular motion starr ?
Where is the 45 degrees limitation you mentioned in your post #1 ?
Is there any source of friction at all ?
If your video takes 30 frames per second, and if you measure a difference A in the angle from one frame to the next frame, then angular velocity is 30A degrees per second.
The angular motion is caused from a click of a spring that I can not known.
If you want a better answer, you have to explain more about what you're doing.
