Micromass' big August challenge
In summary, this thread contains challenges for both high school and college freshmen, as well as for more advanced individuals. Previous unsolved challenges have been omitted. Participants must provide a full derivation or proof for their solution to count. It is allowed to use nontrivial results, but they must be cited and considered common knowledge to all mathematicians. The challenges can be found in the provided link.
  • #106
Let me also give the nonstandard analysis proof I mentioned. To follow it, the reader needs some knowledge about nonstandard analysis, for which I refer to the literature.
We work in a nonstandard extension of some superstructure over ##\mathbb R##. Every number, set, function etc. ##x## in this superstructure has a ##*##-transform ##^*x## in the extended superstructure.
Let ##\{x_n\}_{n\in \mathbb Z_+}## be a bounded sequence in ##\mathbb R##. Its ##*##-transform ##^*\{x_n\}_{n\in \mathbb Z_+}##is a bounded hypersequence ##\{x_n\}_{n\in \,^*\mathbb Z_+}## in ##^*\mathbb R##.
Pick an infinite positive hyperinteger ##H\in\, ^*\mathbb Z_+\setminus\mathbb Z_+##.
For each bounded real sequence ##\{x_n\}_{n\in \mathbb Z_+}##, put ##F(\{x_n\}_{n\in \mathbb Z_+})=st(x_H)##, i.e. the standard part of ##x_H## (in the corresponding hypersequence). It is easy to verify that ##F## is a real linear functional on the space ##\mathcal B## of all bounded real sequences.
It is also so that ##\overline\lim x_n=\max_{K\in\, ^*\mathbb Z_+-\mathbb Z_+}st(x_K)## and ##\underline\lim x_n=\min_{K\in \,^*\mathbb Z_+-\mathbb Z_+}st(x_K)##, so ##\underline\lim x_n\le F(\{x_n\}_{n\in \mathbb Z_+})\le \overline\lim x_n##.
Now, define ##G: \mathcal B\to\mathcal B## by ##G(\{x_n\}_{n\in \mathbb Z_+}=\{y_n\}_{n\in \mathbb Z_+}##, where ##y_n=\frac1n\sum_{k=1}^n x_n## for all ##n\in \mathbb Z_+##. Let ##H_1=\,^*\lfloor \,^*\sqrt{H}\rfloor##. Then ##H_1## is an infinite positive hyperinteger such that ##H_1/H## is infinitesimal.
There is a real ##M## such that ##|x_n|\le M## for all ##n\in \mathbb Z_+##, and the same holds for all ##n\in ^*\mathbb Z_+##, with the same ##M##. It follows that ##\frac1H\,^*\sum_{k=1}^{H_1}x_k## is infinitesimal and that ##y_H=\frac1H\,^*\sum_{k=1}^{H}x_k## is finite, and ##F(\{x_n\}_{n\in \mathbb Z_+})=st(y_H)=st(\frac1H\,^*\sum_{k=H_1+1}^{H}x_k)##. By the characterizations of ##\overline\lim x_n## and ##\underline\lim x_n## above, this implies that ##\underline\lim x_n\le F(\{y_n\}_{n\in \mathbb Z_+})\le \overline \lim x_n ##.
With these ##\{x_n\}_{n\in \mathbb Z_+}## and ##\{y_n\}_{n\in \mathbb Z_+}##, define ##\{u_n\}_{n\in \mathbb Z_+}## by ##u_n=x_{n+1}##, for all ##n\in \mathbb Z_+##, and put ##\{z_n\}_{n\in \mathbb Z_+}=G(\{u_n\}_{n\in \mathbb Z_+})##. Then ##F(\{z_n\}_{n\in \mathbb Z_+})-F(\{y_n\}_{n\in \mathbb Z_+})=st((x_{H+1}-x_1)/H)=0##.
So, if we put ##L=G\circ F:\mathcal B\to\mathbb R##, then ##L## is linear, ##\underline\lim x_n\le L(\{x_n\}_{n\in \mathbb Z_+})\le \overline \lim x_n ##,
since ##G(\{x_n\}_{n\in \mathbb Z_+})=\{y_n\}_{n\in \mathbb Z_+}##, and ##L(\{u_n\}_{n\in \mathbb Z_+})=L(\{x_n\}_{n\in \mathbb Z_+})##, since ##F(\{z_n\}_{n\in \mathbb Z_+})=F(\{y_n\}_{n\in \mathbb Z_+})##.
This means that ##L## satisfies 1, 2, 3, and 5, and hence 4 and 6, in the definition of generalized limit, so ##L## is a generalized limit.
If one tries to convert this proof to a "standard" proof, the result is something like my previous proof. So we see that nonstandard proofs are often considerably shorter!
  • Math Proof Training and Practice
11K
10K
11K
