Micromass' big high school challenge thread
In summary, this conversation is discussing a thread of challenges for high school and first-year university students that involve different mathematical concepts. The challenges can be solved using algebra, trigonometry, analytic geometry, precalculus, and single-variable calculus. Additionally, there are summer challenges available for non-high schoolers. The conversation also includes rules for participating in the challenges, such as providing a full derivation or proof for solutions to count. The conversation also includes solved problems and unsolved problems, which cover topics such as genetics, series and limits, means, rational numbers, parabolas, circles, and geometry. In conclusion, the conversation provides a variety of challenging mathematical problems for students to solve.
micromass
Staff Emeritus
Insights Author
22,183
3,322
Here is a thread of challenges made especially for high school students and first year university students. All the following problems can be solved with algebra, trigonometry, analytic geometry, precalculus and single-variable calculus. That does not mean that the question are all easy.
For non-high schoolers, there is my summer challenges: https://www.physicsforums.com/threads/micromass-big-summer-challenge.879072/
RULES:
  1. In order for a solution to count, a full derivation or proof must be given. Answers with no proof will be ignored.
  2. It is fine to use nontrivial results without proof as long as you cite them and as long as it is "common knowledge to all mathematicians". Whether the latter is satisfied will be decided on a case-by-case basis.
  3. If you have seen the problem before and remember the solution, you cannot participate in the solution to that problem.
  4. You are allowed to use google, wolframalpha or any other resource. However, you are not allowed to search the question directly. So if the question was to solve an integral, you are allowed to obtain numerical answers from software, you are allowed to search for useful integration techniques, but you cannot type in the integral in wolframalpha to see its solution.
1. Suppose that in each individual of a large population there is a pair of genes, each of which can either ##x## or ##X##, that controls eye color: those with ##xx## have blue eyes, while heterzygotes (those with ##Xx## or ##xX##) and those with ##XX## have brown eyes. The proportion of blue eyed individuals is ##p^2## and of heterzygotes is ##2p(1-p)## where ##0<p<1##. Each parent transmits one of its own genes to the child; if the parent is a heterozygote, the probability that it transmiths the gene of type ##X## is ##1/2##.
a) SOLVED BY ProfuselyQuarky Assuming random mating, find the expected proportion of heterzygotes in brown-eyed children of brown-eyed parents. Otherwise stated: consider the population of all brown-eyed people whose two parents are brown-eyed. Find the proportion of heterzygotes in that population.
b) SOLVED BY ProfuselyQuarky Suppose Judy, a brown-eyed child of brown-eyed parents marries a heterozygote, and they have ##n## children, all brown eyed. Find the probability that Judy is a heterzygote and the probability that her first grandchild has blue eyes.
2. a) SOLVED BY MAGNIBORO Prove that
[tex]1 + \frac{1}{2} + \frac{1}{3} + ... + \frac{1}{1000000} < 20[/tex]
b) SOLVED BY MAGNIBORO Find an explicit ##n## such that
[tex]1+ \frac{1}{2}+ \frac{1}{3} + ... + \frac{1}{n} > 20[/tex]
3. Let ##p\neq 0## be a real number. Let ##x_1,...,x_n## be positive real numbers, we define the ##p##-mean as
[tex]M_p(x_1,...,x_n) = \sqrt[p]{\frac{1}{n}\sum_{i=1}^n x_i^p}[/tex]
Note that ##M_1(x_1,...,x_n)## is the usual mean. Prove:
a) SOLVED BY Math_QED ##\lim_{p\rightarrow -\infty} M_p(x_1,...,x_n) = \min\{x_1,...,x_n\}##. We define this as ##M_{-\infty}(x_1,...,x_n)##.
b) SOLVED BY Math_QED ##\lim_{p\rightarrow 0} M_p(x_1,...,x_n) = \sqrt[n]{x_1\cdot ... \cdot x_n}##, the geometric mean. We define this as ##M_0(x_1,...,x_n)##.
c) SOLVED BY Math_QED ##\lim_{p\rightarrow +\infty} M_p(x_1,...,x_n) = \max\{x_1,...,x_n\}##. We define this as ##M_{+\infty}(x_1,...,x_n)##.
d) Prove that for all ##p,q\in \mathbb{R}\cup \{- \infty,+\infty\}## has that ##p\leq q## implies ##M_p(x_1,...,x_n)\leq M_q(x_1,...,x_n)##.
4. Take rational numbers ##\frac{a}{c}<\frac{b}{d}## with ##a,b,c,d\in \mathbb{N}##.
a) SOLVED BY Mastermind01 Prove
[tex]\frac{a}{c} < \frac{a+b}{c+d} < \frac{b}{d}[/tex]
b) Prove that if ##bc - ad = 1##, then ##\frac{a+b}{c+d}## is the simplest fraction in ##\left(\frac{a}{c},\frac{b}{d}\right)## in the sense of having the smallest denominator.
5. SOLVED BY Mastermind01 A light ray falling on a straight line is reflected in the following picture:
To find the reflected line, we use that ##\theta_1 = \theta_2##.
If a light ray falls on a curve, then it is reflected on the tangent line of the curve:
Given the parabola ##y = ax^2 + bx + c##. A light ray comes from ##(h,+\infty)## and follows the vertical line ##x = h##. All such light rays are reflected on the parabola and give rise to reflected light rays. Show that the paths of all the reflected light rays are all concurrent (i.e. they all have a point in common). Find the common point.
6. Find
[tex]\sqrt{1 + 2\sqrt{1 + 3\sqrt{1 + 4\sqrt{1 + ...}}}}[/tex]
7. Let ##C## be the unit circle as defined by ##x^2 + y^2 = 1##. Let ##L_\alpha## be the line through ##(-1,0)## with slope ##\alpha##. A point ##(x,y)\in C## is called rational if both ##x## and ##y## are rational.
a) SOLVED BY Mastermind01 Show that ##L_\alpha## intersects ##C## in a rational point (except for ##(-1,0)##) if and only if ##\alpha## is rational.
b) SOLVED BY MAGNIBORO Find all rational points on the circle. In particular, show there are infinitely such points.
c) SOLVED BY MAGNIBORO Find all positive integers ##a##, ##b## and ##c## such that they can be combined to form a right-angled triangle.
8. SOLVED BY ProfuselyQuarky In a certain school there are ##15## girls. It is desired to make a seven-day schedule such that each day the girls can walk in the garden in five groups of three in such a way that each girl will be in the same group with each other girl just once in the week. How should the groups be formed each day?
9. SOLVED BY MAGNIBORO A donkey is attached by a rope to a point on the perimeter of a circular field. How long should the rope be in terms of the radius of the field so that the donkey can reach exactly half the field and eat half the grass.
10. The same donkey is now tied with a ##50m## long rope. The rope is tied to the corner of a ##20m## by ##10m## barn. What is the total area that the donkey is capable of grazing?
Likes MAGNIBORO, Charles Link, Greg Bernhardt and 4 others
i try the 2.
a)
if we try to delimit the sum 1/n we can see that
so
b)
so
micromass said:
4. Take rational numbers ##\frac{a}{b}<\frac{b}{d}## with ##a,b,c,d\in \mathbb{N}##.
There is no c in the given condition?
Let me try #7a
The equation of [itex]L_\alpha[/itex] is [itex] y = \alpha x + \alpha [/itex] . To satisfy the circle [itex]x^2 + (\alpha x + \alpha)^2 = 1[/itex] Solving gives us [tex] x = \frac{1-\alpha^2}{1+\alpha^2} , y = \frac{2\alpha}{1+\alpha^2} [/tex]
While [itex] x [/itex] may be rational even if [itex] \alpha [/itex] be not an irational number y can be rational only if [itex] \alpha [/itex] is rational because of the [itex]2\alpha[/itex] term.
Am I correct?
Likes micromass
Let me try #7a
Am I correct?
I agree that it follows that if ##\alpha## is rational, then so are ##x## and ##y##. But if both ##x## and ##y## are rational, how exactly do you find that ##\alpha## is rational?
Well combining the equations we get [itex] x/y = \frac{1-\alpha^2}{2\alpha} [/itex] Solving for [itex] \alpha [/itex] gives a rational value.
Likes micromass
Sorry, but it's not quite obvious to me how any solution to that equation must be rational.
micromass said:
Why is this?
Why?
if we compare the 2 sums
a) 1+1/2+1/3+1/4+1/5+1/6+1/7+1/8+1/9...
b) 1+1/2+1/2+1/4+1/4+1/4+1/4+1/8+1/8...
We note that a<b , and We stopped at a 2^k-1 term in b we get k
example: 1+1/2+1/2+1/4+1/4+1/4+1/4 = 3 (we stop in 7 term and we get 3)
so 1+1/2+1/3+...+1/(2^k-1) < k or https://www.physicsforums.com/attachments/103320/and the other
b) 1+1/2+1/4+1/4+1/8+1/8+1/8+1/8+1/16...
We note that a>b , and We stopped at a 2^k term in b we get k/2 + 1
example: 1+1/2+1/4+1/4+1/8+1/8+1/8+1/8 = 3/2 +1 (we stop in 8 term and we get 3/2 + 1)
so so 1+1/2+1/3+...+1/(2^k) > k/2 + 1 or https://www.physicsforums.com/attachments/103322/
Likes micromass
[tex] 2\alpha x = y - y\alpha^2 [/tex] Using the quadratic formula [tex] \alpha = \frac{2x +- sqrt(4x^2 + 4y^2)}{2y} [/tex] which is \alpha = \frac{2x +- 2}{2y} [/tex] since [itex] x^2 + y^2 = 1 [/itex] . This is rational if x and y are rational.
Likes micromass
Alright thank you. I'll credit you with the solution as soon as the other parts are solved.
Sorry for my bad Latex in the previous post.
#4a
Since [itex]a,b,c,d\in \mathbb{N}, bc > ad \implies bc + bd > ad + bd \implies \frac{b}{d} > \frac{a+b}{c+d}[/itex]
Similarly [itex] bc > ad \implies bc + ac > ad + ac \implies \frac{a}{c} < \frac{a+b}{c+d} . [/itex]
Combining the two gives us
[tex] \frac{a}{c} < \frac{a+b}{c+d} < \frac{b}{d} [/tex]
Likes micromass
#4b
Trying this one:
[itex] bc = ad + 1 \implies b = d \frac{a+b}{c+d} + \frac{1}{c+d} [/itex] and [itex] c \frac{a+b}{c+d} = a + \frac{1}{c+d} [/itex] Combining the two we get [itex] \frac{b}{d} - \frac{a}{c} = 1 \implies bc - ad = cd \implies cd = 1 \implies c = d = 1 (\because
a,b,c,d\in \mathbb{N}) \therefore c + d = 2 [/itex] which is the smallest possible sum of two natural numbers. Hence the denominator in the fraction is the smallest.
Mastermind01 said:
#4b
Trying this one:
This can't possibly be correct. Take ##a=4, b=3, c = 3, d = 2##. Then ##bc - ad = 9 - 8 = 1##. But ##c+d = 5\neq 2##.
Likes Mastermind01
I found my mistake.
For 9, are numerical methods allowed?
You might want to go in detail as in how the last big limit is ##1##.
Each invidual term under the root except for the +1 term goes to zero because (xi/xs)^p with xs>xi goes to zero as p goes to infinity.
But the root goes to infnity too. So you have ##0^{1/\infty} = 0^0## which is an undetermined form.
micromass said:
8. In a certain school there are ##15## girls. It is desired to make a seven-day schedule such that each day the girls can walk in the garden in five groups of three in such a way that each girl will be in the same group with each other girl just once in the week. How should the groups be formed each day?
So if there are three girls ##1##, ##2##, ##3## in one group once a week, does that mean that girl ##1## can't be in the same group as ##2## or ##3## (with another third girl) or both ##2## and ##3##?
Like, can there be ##1##, ##2##, ##3## and then on another day within the same week ##1##, ##2##, ##4##?
##1,2,3## cannot happen in the same week as ##1,2,4## since then ##1## and ##2## walked twice with each other. The idea is that ##1## walks with every girl once.
Likes ProfuselyQuarky
It looks like problems 2, 6, 8, 9 and 10 are slightly easier problems at first glance.
I think those are typical textbook style exercises.
I think the other problems looked quite tough because I'm quite bad and inexperienced
at proofs.
I think that personally 1, 3, and 5 look really toughsimply because there is so many instructions. Like a wall of text. :D
Ive done number 10 type of problems earlier. They seem to be a somewhat common geometry textbook exercise.
for problem 6, this same type of problem was recently talked about in the pre-calculus subforum for math homework.
micromass said:
You can't have ##p## outside the limit if that is your limit variable.
Even if I would solve the limit and show it's equal to 1, there is still another problem. What if there are 2 elements a = b = max{x1,x2, ..., xn}. I suppose that can't happen because {x1, x2, ..., xn} is a set.
Math_QED said:
It's right, except the thing you noticed earlier: that there might be multiple ##x_i## such that ##\frac{x_i}{x_s} = 1##. In that case, you'll end up with something like ##\lim_{p\rightarrow +\infty} \frac{1}{p} \log(n)##. But this doesn't change the answer of course.
Also, since you're going to study math at university, I just want to warn you that ##\text{ln}## to denote basis ##e## is a very high school thing to do. Real mathematicians use ##\log## to denote basis ##e##. Nobody cares about base ##10## anyway.
Alright, I will use the common notation then in the future. Thanks for the remark. For 3a) I have the following: https://3.bp.blogspot.com/-buAaztZp...ZB3aAtuWU8X17DgCLcB/s1600/20160717_201042.jpg . The limit is calculated in the same way as in 3c
  • #32
Don't know how to make tables here so I'm going to steal Math_QED's brilliant idea. Here's a starter attempt at #8.
https://65.media.tumblr.com/ae02036e5e43220c38cd1de6c9173ce6/tumblr_oah2a4DrfM1vag9ebo1_1280.jpg
After step 3, it was more of a trial and error sort of process. Perhaps there's a set of rules that can be followed, but I haven't figured it out yet. I look forward to (hopefully) seeing somebody's more rigorous solution since I'm sure that's what micro wants :oldsmile:.
Likes micromass
  • #33
a goes with c both on friday and saturday :frown:
  • #34
Oops...The c in that row for Saturday was supposed to be uppercase :/
  • #35
micromass said:
Again: you probably want to say ##x_i\geq x_s## at the end and not the strict inequality. But this is ok!
Note too that I wrote: xi ∈ {x1, ..., xn} \ {xs}. So I think the strict inequality holds? Or am I missing something?
  • Math Proof Training and Practice
11K
12K
10K
9K
9K
11K
