Amar.alchemy
- 78
A thin uniform rod 50.0 cm long with mass 0.320 kg is bent at its center into a V shape, with a 70.0 0 angle at its vertex. Find the moment of inertia of this V-shaped object about an axis perpendicular to the plane of the V at its vertex.
Moment of Inertia of slender rod
In solution manual, he has considered these V-shaped object has two slender rods and he has applied formula I= 1/3 ML^2 for both rods. He has also given that moment of Inertia is independent of the angle between the two sides of the V
But I tried to solve the problem using Centre of mass concept. First, i found the moment of inertia about its centre of mass and and then applied parallel axis theorem. I think it certainly depends on the angle between the rods because the Moment of inertia depends on the distribution of mass.
So i am little bit confused... kindly help...
