More rotating toilet bowl insanity
  • Thread starter DaveC426913
  • Tags
    Rotating
In summary: Coriolis force is not very strong?In summary, the video is making the rounds of the internet and apparently, you need to go 10m to either side of the equator in order to negate the Coriolis force. It is easy to demonstrate this with a small funnel under your kitchen faucet.
  • #36
sophiecentaur said:
But what were you testing?
That water spirals down a drain in opposite directions in the northern and southern hemisphere was a well spoken about 'phenomenon' as far back as I can remember. I'm not saying it's a fact as if it is not a fact and this is upheld by proper science then I'm of course fully prepared to accept that. If it's taken this long to be debunked then I'm even more amazed. However to answer your question I was testing if I could force it to reverse and what would happen. And in fact what happened always was what I mentioned. If this is some phenomenon caused by the drain itself, then I'm happy to accept that too!. That's all I'm saying.
So from what I now gather, the direction it spirals is either a product of the drain design or in the case of the two huge pools of water, just a coincidence that they swirled in opposite directions. As the two pools appear to by symmetrical with merely a small hole for a drain, am I to understand that if they were both repeated say 50 times each that we'd find the resultant vortex direction to be of equivalent probability as tossing a coin?
  • #37
It hasn't taken "all this time". When I was at Uni, (pre-history) the discussion was rife and the sums were done. They showed (as they always would) that the forces involved are too small to be significant.
Fact is, it's just one of those things which have the same appeal as conspiracy theories and they keep being brought up. People love magic. Proper Science is not easy or attractive enough.
  • #38
DaveC426913 said:
Any news on those stats? How significant were they?
No. Sorry it took me so long to respond. I tracked down the passage I read, it's on page 133 of Teaching Introductory Physics by Clifford E. Swartz and Thomas Miner, AIP Press, 1997. There's no specific reference given for the passage, but there are three references at the chapter end.
These authors simply state that the rotation was "generally counterclockwise in Boston" and that in Australia "the drainage there was clockwise".
They also do a calculation where they estimate the Coriolis acceleration to be about ##7 \times 10^{-6} g##.
  • #39
If you are referring to the two tubs from Getting Smarter Everyday and V..., the experiment was a copy of that done by Shapiro ( 1962 ) and colleagues.
In a very controlled experiment, with temperature effects, surface air motion, filling motion, ... eliminated, it appeared that the 1962 experiments did show the rotation of the Earth did have an affect upon draining water. Same as what @Mister T had written about. And that the rotation rate of the vortex measured with a floating crosshair was consistent with that due to the Coriolis affect. If the tubs and setup in the videos were of the same caliber as that, then a similar affect should be noted. I do not think anyone has ever come out claiming Shapiro's setup and results were faked, inconsistent, inconclusive, ..., but that they are a show of micro forces on water movement.
In an uncontrolled experiment, such as with a bathtub, sink, the Coriolis force is overwhelmed by other factors. Toilets usually have directed flow when flushed and the swirl will always be in one direction everytime. Bathtubs and sinks may or not have a 50 % of swirl in either direction, perhaps due to leveling, drainage hole, induced swirl, etc.
At the equator, 50% chance of direction or no vortex at all.
If one, refers to the video in post # 1, you can if you want, travel to that location and for a $ or $$, whatever they charge, ask for a demonstration from an ingenious entrepreneur - fascinating for a street exhibit it would seem, at least he is demonstrating as aspect of science.
What does Straight Dope have to say about Shaprio.
https://www.straightdope.com/column...-counterclockwise-in-the-northern-hemisphere/
You can find the original paper in Nature, still under copyright access.
https://www.nature.com/articles/1961080b0
a better description,
https://www.technologyreview.com/s/429479/verifying-a-vortex/
  • #40
It goes without saying that a sufficiently large mass will be affected by Coriolis (because, storms), so the 1962 study is certainly corroborating that. (which unfortunately will only add fuel to the myth.)
But the urban legend deals with toilet bowls and sinks. I'd prefer to see the experiment done on that scale to make an iron clad pronouncement of debunkage.
[EDIT] Ah. I see your last link has done that.
"For the first 12 to 15 minutes, the float remained motionless. Then it began to rotate almost imperceptibly, counterclockwise, reaching a peak speed of approximately one revolution every three to four seconds.
Proving that the Coriolis effect can be detected in a bathtub-size tank, albeit under carefully controlled conditions, was a remarkable achievement. At MIT’s latitude of 42°, the effect was “only thirty-millionths that of gravity, which is so small that it will be overcome by filling and even temperature differences and water impurities,” reported one of many newspapers and periodicals covering the experiment. "
(Strange, it never actually says what size the container is in his experiment)
  • #41
The answer seems to be that once a vortex is established one way or the other, it becomes self sustaining in either hemisphere.
Coriolis is one of several factors involved in starting the spin, and it does bias things depending on latitude.
We never see clockwise cyclones (or lesser low pressure weather systems) in the northern hemisphere though. they always anticlockwise,
  • #42
Yes, but the myth contends that it is statistically much more likely to get established in the direction of Coriolis Force. (Actually, that's being generous - the myth contains that it always does, but I'll put that down to hyperbole.)
  • #43
bland said:
It's not true to say that you cannot test this yourself. I remember as child over 50 years ago watching the water spiral down the bathtub drain and forcing it to spiral in the opposite direction by swirling it by hand, then gradually it closed up and resumed it's normal direction. I did not need a giant wading pool to see this.
Strangely though and as I mentioned earlier I did this same kid experiment and got a different result!
Once the vortex is up and running it stays that way unless you mess with it again to turn it around,
  • #44
But that's not a valid test. There are a host of confounding factors that need to be eliminated.
Doing the test on only one tub is as problematic as performing the test only once.
For all you know, every other bathtub on your block might drain in the opposite direction from yours.
  • #45
All this is true, however I still have to give myself some plaudits for attempting a scientific if ultimately flawed experiment as a child! And while I accept that this has been debunked long ago, the falsity of this early spinning hypothesis has not yet entered the general consciousness. Much like the equally false explanations for the tides! Both of these these are such popular misconceptions I am surprised that they have not during the past 50 years been corrected in the popular consciousness.
Well there you go. I found the opposite, it did become self sustaining at first but *always* (for me at least) gradually blocked up and then reversed! I guess I'll have to put it down to the magical southern hemisphere bath elfs.
Likes sophiecentaur
  • #46
And plaudits from me too. That was kind of oblivious of me. :oops:
  • #47
The title of the thread reflects the popular view on what will happen. The results of the most carefully done experiment showed that results can be the same as the large scale effects with weather systems. This can hardly be too surprising because the sums predict a Coriolis Force and classical Physics is not likely suddenly to change its mind as the scale decreases. What we are (should be) discussing is a signal to noise problem and when the noise is reduced sufficiently and the signal is raised enough, we detect the effect.
The 'noise' associated with domestic sanitary ware is too high.
  • #48
sophiecentaur said:
The noise associated with domestic sanitary ware is too high.
:)) This deserves to be taken out of context and be the quote of the week!
Likes DaveC426913 and sophiecentaur
  • #49
Agree. But laypeople, who promote the trash in the OP, are interested in results. They're not going to care about what 'wouldn't' or 'shouldn't' happen; I want to hit them with 'here is the empirical evidence, now shuddup'.
  • #50
I sympathise with you but what could you tell them about Quantum Physics or Relativity that would fit that requirement? I think "Correct but probably too small to measure accurately in your bathroom" should do.
  • #51
To which the inevitable retort is: "So you admit it is true!"
  • #52
Which one of us is the devil and which one is the advocate here?
There is nothing to admit. The sums correctly predict that it works (mostly) in the case of weather systems but, even then, only when the conditions are right. If it were always true, everyone would be in a permanent cyclone / depression and that is not topologically possible. In fact, the situation in the atmosphere never produces the sort of conditions for a true bathtub effect because they are always triggered by linear motion of air masses and rising / falling air. It is also possible to get air moving the wrong way. I foundhttp://www.kdlt.com/2015/04/09/do-all-tornadoes-rotate-the-same-way/and several others, which tells us that clockwise tornados can sometimes form in the northern hemisphere, going against the coriolis effect even at that scale.
I'm sorry Dave (to coin a phrase) but I think it's all just too hard to present to your dumkopf lay friends in a cut and dried assertion. You and I, of course, are fine with it all.
