Motion under influence of a resistive force
The discussion focuses on the motion of a body influenced by a resistive force defined by F = -m*γ*vα. The equation of motion v'' = -γ*vα was solved, leading to a time equation t = (1/γ)*(V01-α)/(1-α), indicating that for γ > 1, time is finite but can yield negative values. The participants explore the implications of different values of α, noting that α = 0 results in positive finite time, while α = 2 leads to negative time, which is deemed physically unrealistic. The conversation also touches on the outcomes for α = -1 and α = 1, prompting further analysis of the velocity versus time relationship. The discussion highlights the complexities of resistive forces in motion and the conditions under which they yield meaningful physical interpretations.
Ananthan9470
No template because originally posted in wrong thread
Consider the 1d motion of a body under the influence of the force given by F = -m*γ*vα. m is mass, γ is a constant of appropriate dimension, v is velocity and α is dimensionless constant. The value of α for which the motion will come to a stop in finite time is to be calculated. I solved the equation of motion given by v'' = -γ*vα and got an equation for t given by t = (1/γ)*(V01-α)/(1-α); V0 is the initial velocity. According to this, for all γ>1, time is finite. But the sign of t is negative. Why is this happening? Am I doing something wrong?
Your solution for t is correct. What do you get for t if ##\alpha = 0##? Is this a finite time? Is it positive?
For ##\alpha = 0## it is positive but what about something like α = 2? It is turning out to be negative unless I am mistaken. right?
Yes. That's the region that is not physically realistic.
What do you get when ##\alpha = -1##? Is that a finite time? What do you get for v vs t in the special case when ##\alpha = 1##?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
