Motor Powering Generator Efficiency
In summary, when determining the efficiency factor for a generator, it is important to consider the size and type of engine used, as well as the industry standard efficiency range of 70-80%. It may not be practical to use an extremely efficient alternator, as the cost may outweigh the benefits. A high speed gas engine with an electronic converter may be the most efficient option, as the size and weight decrease with higher RPMs, and the conversion of electrical output is over 90% efficient. Traditional thinking of running at 1800 or 3600 RPM for 60 Hz output may not be the most efficient approach.
dingpud
199
What do I look for to determine the efficiency factor to know how many watts I can get out of a generator given a specific known HP sized engine?
Example:
12.6 HP gives 9395 Watts from the standard HP to Watts conversion... however on a Markon generator, the spec sheet says that a 12.6 HP engine will provide 7500 Watts.
I am sure that number is composed of data from days of testing, calculations, safety factors, etc. I wanted to see what I could calculate for a 9.9 HP engine but wasn't sure where to start. Is there an industry standard / assumed 80% efficiency factor?
Any thoughts?
Markon link for reference: https://www.cumminsgeneratortechnologies.com/www/en/referenceapplications/apu/MARKON_Brochure.pdf
You reach a price point for alternator efficiency. An extremely efficient alternator [~90%] would not be cost efficient. It is more practical to use a bigger motor.
The most efficient system is for a high speed gas engine with a converter to deliver the electrical output as needed. This is because the size and weight for a given generator power go down with RPM. Conversion of the electrical output from the generator by electronic converter is over 90% efficient. The older gensets running at 1800 or 3600 RPM so they could put out 60 Hz is really old school thinking.
FAQ: Motor Powering Generator Efficiency
What is motor powering generator efficiency?
Motor powering generator efficiency refers to the amount of energy that is converted from mechanical power to electrical power by a motor-powered generator. It is a measure of how efficiently the generator is able to convert the input energy into usable electrical energy.
How is motor powering generator efficiency calculated?
The efficiency of a motor-powered generator is calculated by dividing the output power (in watts) by the input power (in watts) and multiplying by 100 to get a percentage. This calculation takes into account the power lost through friction, heat, and other factors.
What factors affect motor powering generator efficiency?
There are several factors that can affect the efficiency of a motor-powered generator, including the type of motor and generator being used, the quality of the components, the operating temperature, and the load on the generator. Improper maintenance and aging components can also decrease efficiency.
How can motor powering generator efficiency be improved?
To improve the efficiency of a motor-powered generator, it is important to use high-quality components, properly maintain the generator, and operate it at optimum temperature and load. Using a motor and generator that are well-matched and properly sized for the application can also increase efficiency.
Why is motor powering generator efficiency important?
Motor powering generator efficiency is important because it directly affects the amount of usable electrical energy that is produced. A higher efficiency means less energy is wasted and more energy is available for use, leading to cost savings and reduced environmental impact.
