Multiple electric generators on the same drive shaft
  • Thread starter Thread starter Questioneverything
Using multiple generators on a common drive shaft offers both advantages and disadvantages. A single generator is generally easier to control due to having one control circuit, while multiple generators provide redundancy in case of failure. The effectiveness of either setup depends on the source and variation of shaft power. Controlling individual generators can better match torque variations, but synchronizing multiple units can complicate operations. Ultimately, the choice between a single generator and multiple units hinges on specific operational needs and reliability considerations.
Questioneverything
What are the pros and cons of having multiple generators on a common drive shaft?
As the torque on the drive shaft varies, is it more effective / efficient to switch on and control individual generators to match the shaft torque or to have a large single generator and vary the load to match the shaft torque ?
Welcome to PF.
That will depend on the source and variation of shaft power.
One single unit is easier to control, with one control circuit.
Three separate generators would give redundancy in the case of a failure.
There are exceptions, but usually to control a single generator is simpler than to sync between independent control circuits.
Hi, Thanks for your reply and comments.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
