Need help with Finding absolute magnitude
  • Thread starter Thread starter Michael c17
    Absolute Magnitude
To find the absolute magnitude (Mv) using the given period (P = 7), the relevant equation is Mv = -[2.76(log10(P) - 1.0)] - 4.16. The user is seeking assistance in evaluating this equation but lacks a suitable calculator. Forum members suggest using online calculators or smartphone apps that can handle logarithmic functions. It's clarified that the user needs to evaluate the expression rather than solve an equation. The discussion emphasizes the importance of understanding the calculation process and available tools.
Michael c17
Need to solve this equation
Mv = - [2.76 (log10(P) - 1.0)] - 4.16
P is = to 7 and I don't know how to get the absolute magnitude please help.
Michael c17 said:
Homework Statement:: Need to solve this equation
Relevant Equations:: Mv = - [2.76 (log10(P) - 1.0)] - 4.16
Please post the whole question as given to you. Define any variables that would only be obvious to someone versed in astronomy.
The "relevant equations " section is for standard equations, not any that only relate to the given problem. Maybe that is a standard equation.. I don't know.
And, per forum rules, please show some attempt, or at least provide your thinking so far.
I don't understand what your saying, there is the equation and 7 is P I just need someone to plug it in and give me Mv since I don't have a calculator that can do that. Sorry I'm not versed in your forum rules. I'm just trying to find the absolute magnitude of a star using only the period in days which is 7.
That's a key piece of information right there, that Mv (##M_v##?) is one variable, not two.
You confused me by saying you needed to solve the equation. What you are asking for is merely to evaluate an expression.
I find it hard to believe there exists any calculator that cannot do this. Just google online calculator and you will find several.
If you mean that you cannot do the whole expression in one hit, just do it in stages.
Likes Steve4Physics
@Michael c17, have you a smart-phone? My (low-end) phone has a calculator which includes 'advanced options' with log₁₀, brackets, trig' functions, etc. Check yours if you have one.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
