Newton's laws of motion -- Force of gravity on a skydiver
The discussion centers on calculating the force of gravity acting on a skydiver, using the formula force = mass x acceleration. A mass of 75 kg and an acceleration due to gravity of 9.8 m/s² results in a force of 735 N. Participants clarify that the force of gravity remains constant regardless of whether the skydiver is in free fall or after landing, as it only changes with a change in mass. The conversation emphasizes understanding the principles behind Newton's laws of motion. Overall, the calculations and concepts discussed reinforce the consistency of gravitational force in this context.
kara123
A 75 kg skydiver jumps out of an airplane. Calculate the force of gravity acting on him when he jumps and after he has landed. Explain any differences
Fnet=ma
I think you would do force of gravity= mass x acceleration
acceleration of gravity= 9.8 m/s
mass 75 kg
75kg x 9.8 m/s
=735 N
i don't know if that's right but i have no idea how to calculate it after he lands, any help would be greatly appreciated!
Looks good to me. Question for you: Does the force of gravity change when he lands?
kara123 said:
... i have no idea how to calculate it after he lands, any help would be greatly appreciated!
It's a trick question. Knowing that, take a shot at it.
it does not so it would remain the same after he lands then. The force of gravity would only change in this situation if the mass changes?
Right! As @russ_watters said, it's kind of a trick question.
Likes russ_watters
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
