Ohm's Law - Finding Source Voltage
To determine the source voltage in a DC series circuit with resistors of 12 ohms, 9 ohms, and 3 ohms, and a voltage drop of 6V across the 12-ohm resistor, Ohm's Law (V=IR) is applied. The current through the circuit can be calculated using the voltage drop across R1, which gives a current of 0.5A (6V/12Ω). This same current flows through all resistors, allowing the total voltage drop across the circuit to be calculated. The total resistance is 24 ohms, leading to a source voltage of 12V when applying Ohm's Law to the entire circuit. Understanding the relationship between voltage, current, and resistance is crucial for solving such problems.
Brian82784
TL;DR Summary: Ohms Law Source Voltage DC series Circuit
Hello,
I'm trying to figure out how to determine source voltage of a DC series circuit. The only information given is
Resistor 1 = 12ohm
Resistor 2 = 9ohm
Resistor 3 = 3ohm
And the voltage drop across R1 is 6V.
The answer is 12V for the DC battery. But I can't figure out how to get to 12.
If I put 12V down as the battery size, and combine all three resistors 24ohm and use ohms law I can't come up with 12V.
R total = 24ohm
12V source battery
24 divided by 12 = 2Amps
Now if I go to R1 and knowing that the circuit amperage is 2, I get a voltage drop of 2A * 12ohm = 24V not 6V.
Where am I going wrong?
Reminder: V=IR :wink:
So this gives you the current through R1, and hence that same current flows through all 3 series resistors. :smile:
Brian82784 said:
Resistor 1 = 12ohm
So what is the current?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
