- #71
DrChinese
- 1,903
JesseM said:But why do you think wm's example violates this assumption of realism? In his example, if one experimenter can pick for his measurement setting a one of three possible angles a = A, a = B, or a = C, then if you know the angle of the vector S sent out by the source, you can determine in advance the value of A.S if the experimenter picks angle A, and the value of B.S if the experimenter picks B, and the value of C.S if the experimenter picks C. Of course these values may be any real number between -1 and 1 depending on the angles involved, whereas in the experiments Bell is dealing with, "local realism" means that if you know the hidden state of the particle, then you can determine in advance whether each of the three detector angles will yield either the result -1 or +1, with no other possibilities.
It is not that he violates it, it is that he has not included it. You can see that his "formula" is simply the early part of Bell's paper. So nothing has happened! It is as if he showed 1+1=2 and says that proves classical reality. He is trying to assert that classical local hidden variables is equivalent to the predictions of QM, which we already know is completely wrong.
In other words: his formula may have some issues with it, but no one is really doubting that Bell's (2) and (3) can be made to work together as long as you limit it to considering a and b. Bell himself says exactly that! And then he introduces c, and that leads immediately to the Inequality.
So when you include the reality assumption, you get the Inequality. The Inequality is violated in nature; therefore one of the assumptions is wrong. The assumptions are locality and realism; and one of these needs to be thrown out.
P.S. Besides, you can't do what you are saying about A.S, B.S and C.S. - this is precisely what Bell shows. The reason is that these 3 cannot be made to be internally consistent. I.e. the relationship A.S to B.S, A.S to C.S, and B.S to C.S won't work.
