Let's not waste time and take it for granted that you can obtain:
\frac{d^2r}{ds^2} = \frac{-GM}{r^2}\right)
by assuming K is contant wrt (s) and differentiating (dr/ds) wrt (s).
Unless you prove a flaw in my calculations in #380, I have demonstrated I can obtain the same result by assuming K is a constant wrt (r) and differentiating (1/2)(dr/dt)^2 wrt (r).
This proves that for radial motion, K is constant wrt (s) AND (r).
This means that your claim in your blog document "General Euler-Lagrange Solution for Calculating Coordinate Acceleration", (which is actually the solution for radial motion only - you messed up the titles) that:
\alpha \frac{dt}{ds}= k
where, obviously k may be a function of r and possibly t but not of s
is a fallacy, because I have shown k is
not a function of r for radial motion. Are you going to correct your blog?
From further qualitative analysis I have come to the conclusion that
for radial motion only when (H = 0) that:
K is contant wrt (s,t and r)
and (\phi) is constant by definition under these conditions,
and for circular motion only. when (K = constant) that:
H is constant wrt (s,t and \phi)
and (r) is constant by definition under these conditions.
This leaves open what happens when a falling particle has both non-zero radial and non-zero angular motion at the same time. My initial hunch is that in relativity, energy and momentum are not individually conserved as in Newtonian physics, but are conserved as a pair in the form of momentum-energy. I think the same thing is happening here. The angular momentum and energy are conserved as a pair.
One thing to recall is that when we take the partial derivatives of L with respect to a given variable, obtain K and H we are by definition treating the "other variables" as constants and so we have not proved anything about what happens when we allow the other variables to vary.
starthaus said:
I am not "peddling" anything. :LOL:
And I am not back peddaling.
If you are going to pick on spelling, try and get it right. it should be "pedaling" or sometimes "pedalling" (American?) but not with two d's.
