yossell said:
Kev,
thanks for your helpful post and for taking the time to explain things to me.
To be fair, it seems to me that there's unclarity in the notation and it's not clear to me that starthaus is necessarily making that mistake, even in the posts you point to - though I admit, I may be misunderstanding things.
Your welcome
You are right that there is some ambiguity in the notation. It becomes tedious thinking thinking of new symbols (GR is already full of subscripts and superscripts) for acceleration at the apogee, acceleration in radial freefall, acceleration when orbiting, etc. so we sometimes use the same symbols to mean different things and clarify what we mean in the surrounding text. Starthaus is a mathematician and only focuses on the symbols and ignores the surrounding text and this causes a lot of the problems.
yossell said:
In some contexts, it's natural to read dr/ds as referring to a function rather than the value of the function at a point.
This is also true. Sometimes we mean dr/ds=0 at a point and sometimes we mean dr/ds=0 means a function which is true for all s. We (Espen, Altabeh and myself) usually make it clear which usage we mean in the surrounding text, but Starthaus seems to be unable to grasp this. You seem to uderstand this because you have ackowledged that there are two interpretations. Starthaus claims there is "no such thing as when dr/ds=0" when you using dr/ds as a function, but all we mean is that we are considering the special case and we are careful to be aware that any conculsions we draw from making that assumption, are only valid at that point in time.
yossell said:
Then dr/ds = k, or dr/ds = 0 can be read as saying that the *function* is k everywhere or 0 everywhere. Understood in this way, the inference from dr/ds = 0 to d^2 r/ds^2 = 0 is correct. So what (I take) starthaus to be getting at in, say, post 57 seems, at least as it stands, fine.
In post #57 Starhaus is responding to an equation by Espen about purely radial motion (where the Starthaus fallacy dr/ds=0 \Rightarrow d^2r/ds^2 is false. Espen was in turn responding to a quote by me where I specified "the initial coordinate acceleration of a test mass released at r" where the word "initial" was the indication that we were talking about the motion at a point and not implying that dr/ds is 0 everywhere.
Take this series of exchanges between Espen and Starhaus:
espen180 said:
I corrected the error I made in my previous attempt and made a new derivation from scratch.
Please see section 4 (Pages 5&6) in this document for the derivation and result.
Download
starthaus said:
(30) is wrong.
(37) is as wrong as before.
espen180 said:
Going back to this post, do you disagree that \frac{dt}{d\tau}=\left(\frac{d\tau}{dt}\right)^{-1} ?
starthaus said:
Of course not, I am simply saying that both (30) and (37) are wrong, you need to figure out why.
If we look at equation (30) in Espen's document we see that the equation given by Espen is:
\frac{d^2r}{dt^2} = - \frac{GM}{r^2} \left(1-\frac{2GM}{rc^2}\right)
Now in the surrounding text Espen says
"To simplify the case, we study the situation where we drop a test particle from rest at r and study it's acceleration immediately after dropping it "
The word
immediately is Espen's indication that he talking about the motion at a point rather than at any arbitary time after releasing the particle. i.e. he is talking about the motion in the limit that s goes to zero if the particle is released at time s=0.
Espen further clarifies equation (30) by stating it is the
"acceleration measured by a stationary observer at infinity" making it clear that he talking about coordinate acceleration. In the context given by Espen, equation (30) is correct. Starthaus says it wrong because he has not taken the time to read the surrounding text carefully.
The equation given by Espen is the same as the one given by myself in the first post of this old thread
https://www.physicsforums.com/showpost.php?p=2710548&postcount=1 and Starthaus spent nearly 400 posts trying to prove it wrong and by common consensus he failed. The equation is correct in the context it was given in.
Although analysing the acceleration at a given point might not seem very useful, it is a very good starting point for determining the proper acceleration of a stationary particle at rest at r as measured by an accelerometer. The proper acceleration measured by an accelerometer of a stationary particle is equal in magnitude (and opposite in direction) to the
initial acceleration of a particle released from r as measured by a local stationary observer at r, in the limit that s goes to zero, if the particle is released at time s=0.
The acceleration of a particle with purely radial motion is not zero at the apogee when dr/ds=0 and this is the important point Starthaus does not seem to get. Check post #264 and you will see he is still defending the Starthaus fallacy, despite counterproofs by myself, Altabeh and George.
