- #1,086
bruha
- 378
- 469
But I found in standard phone camera (Huawei P30 lite) with mode PRO is possible this adjusting as well..
![Er... what? o_O o_O](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Devin-M said:I should be receiving a 2x teleconverter + equatorial mount in a few days.
chemisttree said:Definitely going to be cloudy on that fine day!
yeah but the Moon is very bright washing out the rest of the skyDevin-M said:my equatorial mount comes on the 25th which happens to coincide with the only suitable day for observing this week (according to clearoutside.com )...
Devin-M said:finally some results... about 33 mins of exposure time... flame nebula...
55x focal 600mm f/9 (nikon 300mm f/4.5 + tc-301 2x teleconverter, image cropped) 30 sec 1600iso + 80 flats + 40 darks on nikon d800 full frame dslr w/ sky watcher star adventurer 2i pro pack equatorial mount, bortle 5
Seems you didnt have too much difficulty getting it polar alignedDevin-M said:finally some results...
30 s subs are pretty straightforward. 2-4 minute subs without guiding will be more of a challenge.davenn said:Seems you didnt have too much difficulty getting it polar aligned
It's a nightmare here in the southern hemisphere, something I have yet to achieve well
Just to avoid confusion, the ASIAIR Pro can control the mount, depending on the mount (even if @chemisttree isn't using that feature). It also has the ability to control an electronic focuser, if you happen to have an electronic focuser (and depending on the focuser [it may only support the ZWO EAF, presently]).chemisttree said:It just controls the camera. It is separate from the mount.
I'm not quite sure what you are asking. But I'll take a stab at an answer.bruha said:Thanks, still question--if connected to mount and a I (handy) move its, it can display azimuthal position and polar aligment..![]()
It's so nice to see that I am not the only one who likes to build stuff.collinsmark said:My solution is a little different. It's not as graceful, but a bit more flexible. It's based around a mini-PC.
The mini-PC is from a company called "Minis Forum" (weird name, right?). I bought the one I got because it's small, light, powered by a 12 V jack, has USB3.0 ports, supports WiFi, and comes installed with Windows 10 Pro. There might be other mini-PCs or PC sticks that do just as well or better these days.DennisN said:It's so nice to see that I am not the only one who likes to build stuff.
What kind of mini-PC is it`? And what OS is it running on?
Edit: Ah, I saw in your next post it uses Windows 10.
Does the mount’s app have a polar align function?Devin-M said:Last night I drove 40 miles into the mountains to my bortle 2 site, got polar aligned and began trying to focus. That’s when I realized the motor in my “star watcher star adventurer 2i pro pack” equatorial mount was randomly stopping every minute or so and also disconnecting from the phone app until I restarted it (even though the lights remained on). This kept happening so I wasn’t able to get a good focus with the Bahtinov mask. After pulling my hair out for over an hour in the 32f temps, I finally decided to try switching the AA batteries. To my relief, it began working normally. The batteries had been fresh but stored them in the mount for a week so I suspect some sort of trickle discharge over that time occurred. As soon as I got it working the clouds rolled in so I wasn’t able to take any pretty pictures. Later back at my house I did some more testing and found out the behavior will also happen if the camera isn’t very well balanced after pointing it at the target. I’ll post a couple test pics later which sort of illustrate the tracking quality. I was able to do a few 2 minute exposures of nothing in particular.
This isn't too surprising to me. If the scope is not well balanced, the motors will have to work against gravity (and resulting friction) to move the scope. Simply put: a well balanced scope makes your mount's batteries last longer.Devin-M said:I did some more testing and found out the behavior will also happen if the camera isn’t very well balanced after pointing it at the target.
