- #36
harrylin
- 3,875
- 93
Loro said:Here is a paradox that came to my mind during my fluid mechanics course last term. I don't know the solution to it:
We have this experiment in which we hold two sheets of paper parallel to each other and blow between them. They are brought closer to each other:
The air outside is stationary, and the air between the sheets moves, so from the Bernoulli theorem it follows that the pressure is higher outside and lower inside - this implies that the forces on the sheets point inwards and bring them closer to each other.
Now let's consider this experiment in the reference frame of the air moving between the sheets of paper:
Now the air in between is stationary, and the air outside is moving, so it would mean that the pressure is higher inside, and lower outside and so now the forces on the sheets point outwards and draw them apart.
What is wrong with this reasoning in the moving frame? To be honest I'm not exactly sure if this situation can really be treated as an irrotational flow (and if the Bernoulli theorem is applicable).
I think that your last remark is the essential one: Bernouilli is about a change of pressure when a fluid changes speed, due to conservation of its total energy.
The picture that you refer to is about a pressure difference between the fluid and the environment, and that is not directly applicable. However Bernouilli can be used for that kind of situations too, for example by introducing a Venturi. See http://en.wikipedia.org/wiki/Bernoulli's_principle
Harald
