I Passive radiative cooling of surfaces below ambient air temperature
Passive radiative cooling allows surfaces to achieve temperatures below ambient air by emitting thermal radiation in specific wavelengths, facilitating water condensation from the atmosphere. This phenomenon occurs when a cooling foil emits heat to the clear night sky, which is cooler than the surrounding air, enabling dew formation. The process does not violate thermodynamic laws, as the surface remains in contact with the air and the night sky, allowing for heat exchange. Optimal conditions for this cooling effect are found in arid regions with significant temperature drops at night. Understanding radiation heat transfer is crucial for further exploration of this technology.
greypilgrim
Apparently, it's possible to cool surfaces below ambient air temperature by passive (no input of energy required) radiative cooling to harvest water from the atmosphere:
https://www.science.org/doi/10.1126/sciadv.abf3978
There's also a Nature paper about this effect, but behind a paywall:
https://www.nature.com/articles/nature13883
This looks like a textbook example of a device violating the zeroth law of thermodynamics, but apparently it's not. Why?
Science news on Phys.org
The key is in this quote from the first paper you linked:
A conventional radiative cooling foil that is used for dew harvesting emits thermal radiation in the wavelength range where the atmosphere is mostly transparent (8 to 13 μm) and can therefore directly emit heat radiatively to space. This effect cools the foil below the dew point temperature of air, causing water to condense upon it, which is termed “dewing” (20). Fortunately, most regions affected by high water scarcity have a natural advantage of abundant sunshine and hence a clear sky, which are optimal conditions for radiative cooling (21).
The surface is losing heat by radiation to the night sky while gaining heat by convection. It can only gain heat by convection when it is cooler than the surrounding air. A practical means of harvesting water is then a matter of optimizing the details. It helps that in a desert climate, the day to night temperature change is about 40 deg F.
Thus, there are not violations of the laws of thermodynamics.
But still, thermodynamics states that two systems in contact will reach the same temperature in thermodynamic equilibrium. So what's not the case here: is this not equilibrium, or is the surface somehow not in complete contact with the surrounding air because it's partially transparent?
The surface is in convective contact with the air.
The surface is in radiative contact with the night sky.
The night sky is at lower temperature than the air.
Therefore, the surface temperature will be between the air temperature and the night sky temperature.
Good search terms to learn more are radiation heat transfer.
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
