Periodic Boundary Conditions Unit Cell vs Transmission Line Model
The discussion revolves around the challenge of establishing an analytical relationship between a dielectric-filled unit cell with periodic boundary conditions and a transmission line model. The user has attempted to analyze this using HFSS, finding that the two models do not correlate, particularly for complex dielectric constants. The need arises from modeling a stack of unit cells to study transmission loss in a plasma sheath. Participants are encouraged to share their findings and screenshots to clarify their reasoning for the negative outcome. The inquiry highlights the complexities of modeling advanced dielectric materials in electromagnetic simulations.
katto01
The problem is:
1. Assume ONE BOX W*W*H1 filled with a dielectric material with dielectric constant eprs. The vertical walls are assigned periodic boundary conditions and the other two faces are Floquet Ports (One TE mode and one TM mode).
2. Assume a transmission line that is L1 long with a characteristic impedance of Z1, and a propagation constant beta.
Q: Is there an analytical relationship between the two? I.e. can one represent the unit cell by a transmission line?
I tried to check this in HFSS, (FEM for the box and Circuit for the TL) and it looks like the answer is NO.
I hope I'm wrong because I need to do the analysis of a stack of 161 unit cells each having crazy dielectric constant (negative, less than 1 etc.). It's my modeling of a plasma sheath for which I need to find the transmission loss.
Can you post some screenshots of your work so far, and say why you think the answer is "No"? Thanks.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
