Periodic vs. oscillatory motion
Periodic motion refers to motion that repeats at regular intervals, while oscillatory motion is a specific type of periodic motion characterized by movement around a central point or mean position. Simple Harmonic Motion (S.H.M) is a form of oscillatory motion where acceleration is directly proportional to displacement. The discussion highlights confusion in distinguishing between oscillatory motion, periodic motion, and S.H.M, emphasizing their interrelatedness. Clarifying definitions and separating the concepts can help in understanding the distinctions better. Understanding these terms is crucial for accurately answering related questions.
abdsaber000
To and fro motion of a particle about a mean position is called:
(oscillatory motion and periodic - oscillatory motion and S.H.M - harmonic motion and periodic)
none
I'm hesitated between the first and second choice
Welcome to PF. :smile:
Does your textbook give definitions of each? If not, have you looked online (like at Wikipedia) to see what the common definitions are?
yeah my textbook gives it a definition, the defintion mentioned in the question the definition of the oscillatory motion , but i know that oscillatory motion is a special case of periodic motion . in addition that in S.H.M the acceleration is directly proportional to the displacement. but the S.H.M has also a mean position like the oscillatory. that's why i can't decide which is answer is correct.
It is unclear where one choice ends and the next begins.
Please put each choice on a separate line.
If the above mixes in definitions of the terms, please make that clearer too.
I would think any regular oscillation has to have a mean position.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
