Andre
- 4,294
- 73
A neat idea to test the extremes, I tried the dining area for that,
(all shots converted RAWs from the defaults, no post processing)
First with the Tokina 12-24mm at 12mm (equivalent to 19mm FX format):
The aperture was 5.5 and it was focussed manually more in front to optimize depth of field as can be seen on the center crop and the little bottle down and slightly right off center.
Then from the same tripod position the 70-300mm zoom at 300mm (FX equivalent 480mm) F5.6 again:
The center crop is not too crisp, but that was to be expected.
I also wanted to know if I should use the 100mm macro lens some more for shots that were taken with the 70-300mm. So I wanted to know how those two compared under the same condition, for that I made this shot, close at minimum range for the 70-300mm with both lenses (F6.7):
Interestingly you have to zoom to 90mm to get the same image as the 100mm macro. The reason for that is that the macro lens does not change it's length during focussing, so what it actually does, is changing its focal length.
Anyway, compare center crops of both lenses:
Can you tell, which is the better lens? I can't
Surprisingly, the 70-300 seemed to have produced the sharper result albeit by a tiny notch
Maybe the 100mm needs some micro adjusting
