Photoelectric exp - calculate intensity of incident light
In a photoelectric effect experiment, a photoelectric current of 100µA is generated with 550nm light on a 1.0cm² cathode, leading to an intensity calculation. The initial attempt yielded an intensity of 3.61x10^-19 W/m², which was incorrect due to unit discrepancies. The discussion emphasizes the relationship between photoelectric current, the number of electrons ejected, and incident photons. Participants highlighted the importance of ensuring the result's units align with the expected intensity units of W/m². The correct intensity of the incident light is ultimately calculated to be 2.26 W/m².
desmond iking
In an photoelectric effect experiment , a photoelectric current of 100µA is obtained when lights of 550nm is incident on metal cathode of surface area 1.0cm^2 ... calculate the intensity of the incident light. The ans is 2.26w/m^2
intensity= power /area
intensity= (voltage x current) /area
intensity= ( (hc/λ) x I ) / area
= (6.63x10^-34)(3x10^8)(100x10^-6) / (550x10^-9)(1.0x10^-4) = 3.61x10^-19 (W/m^2 )
why am i wrong?
[/B]
How is the photoelectric current related to the number of electrons ejected? What is the relation between the number of electrons ejected and the number of the incident photons?
If you check the unit of your result, it is not W/m2.
Likes desmond iking
can you please tell me what's the unit of my 3.61x10^-19 should be? i am confused now.
The problem is not with the units. If you check the unit of your result and it is not what it should be then your solution is wrong. Your solution is wrong, as its dimension is not energy/(time area).
Read the first two sentences of my previous post.
ehild
13K
