Physics 101 mechanics help -- Bullet fired by a rifle barrel
The discussion focuses on calculating the acceleration and position of a bullet fired from a rifle, with the speed equation given as v = (−5.00 ✕ 10^7)t² + (2.80 ✕ 10^5)t. The acceleration is derived as a = dv/dt, resulting in a = 2(5*10^5)t + 2.8*10^5, indicating the bullet's acceleration is 2.8*10^5 m/s² at t=0. There is confusion regarding the sign change in the derivative, prompting a request for clarification on the calculations. The thread emphasizes the importance of checking derivatives and completing all parts of the problem for accurate results.
EishaR
A repeating rifle fires 2 LR bullets such that as they travel down the barrel of the rifle their speed is given by v = (−5.00 ✕ 107)t2 + (2.80 ✕ 105)t,where v is in meters per second and t is in seconds. The acceleration of the bullet just as it leaves the barrel is zero.
Determine the acceleration (in m/s2) and position (in m) of the bullet as a function of time when the bullet is in the barrel. (Use the following as necessary: t. Round all numerical coefficients to at least three significant figures. Do not include units in your answers. Assume that the position of the bullet at t = 0 is zero.)
a (t)=
x(t)=
(b)Determine the length of time the bullet is accelerated (in s).
(c) Find the speed at which the bullet leaves the barrel (in m/s).
(d) What is the length of the barrel (in m)?
y v = (−5.00 ✕ 10^7)t2 + (2.80 ✕ 10^5)t,
a) a= dv/dt = 2(5*10^5)t+2.8*10^5
2(5*10^5)(0)+2.8*10^5=2.8*10^5m/s^2
EishaR said:
Homework Statement:: A repeating rifle fires 2 LR bullets such that as they travel down the barrel of the rifle their speed is given by v = (−5.00 ✕ 107)t2 + (2.80 ✕ 105)t,where v is in meters per second and t is in seconds. The acceleration of the bullet just as it leaves the barrel is zero.
a (t)=
x(t)=
Relevant Equations:: y v = (−5.00 ✕ 10^7)t2 + (2.80 ✕ 10^5)t,
For the first part, check your derivative. You must attempt the other parts also.
How did −5.00 ✕ 10^7 turn into +5.00 ✕ 10^5?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
