Physics 12 Momentum and work, energy question
In summary, a boy of mass 45 kg traveling in a car with a velocity of 14 m/s without a seat belt is stopped by the windshield in a distance of 0.024m when the car suddenly stops. The force he exerts on the windshield can be calculated using the change in kinetic energy and is approximately 2.6*10^4N. However, this calculation does not take into account the varying force during impact and may overestimate the actual force exerted.
gdhillon
Q:A boy of mass 45 kg is traveling without a seat belt, in a car with a velocity of 14 m/s.
When the car stops suddenly, he is stopped by the windshield in a distance of 0.024m.
What force does he exert on the windshield?
i set the impulse of the vehicle (mv)= to FD (because (delta)E=W=Fd) and got a force of 2.6*10^4N. That seems to high of a force to me.
Calculations: p=mv ∇E=p=45(14)=630N*s ∇E=Fd 630=F*.024 solving for F i got 26250
Momentum is not the same as energy. The units are not the same. So ∇E=p is false.
However, you could use kinetic energy. Set the change in kinetic energy to the work done making the change (F x d).
mass * velocity cannot be equated with force * distance; the first gives momentum, the second energy.
Since the question provides a distance and asks for the force acting over that distance, energy is the right quantity to consider. The answer should be much higher.
(However, it is not true that the force will be constant over the impact distance. The question ought to ask for a lower bound on the peak force.)
FAQ: Physics 12 Momentum and work, energy question
What is momentum in physics?
Momentum is a physical quantity that describes an object's motion. It is defined as the product of an object's mass and its velocity. In other words, it is the measure of how much an object keeps moving in a particular direction.
How is momentum calculated?
The formula for calculating momentum is momentum (p) = mass (m) * velocity (v). It is measured in units of kilogram-meters per second (kg*m/s).
What is the conservation of momentum?
The conservation of momentum is a fundamental law in physics that states that the total momentum of a closed system remains constant. In other words, the total momentum before and after a collision or interaction between objects will be the same, as long as there are no external forces acting on the system.
What is the relationship between work and energy?
Work and energy are closely related concepts in physics. Work is defined as the force applied to an object multiplied by the distance it moves, while energy is the ability to do work. In other words, work is a transfer of energy from one system to another.
How is kinetic energy related to momentum?
Kinetic energy is the energy an object possesses due to its motion. It is directly proportional to an object's mass and the square of its velocity. Momentum, on the other hand, is directly proportional to an object's mass and velocity. Therefore, an object's kinetic energy is related to its momentum, as an increase in momentum will result in an increase in kinetic energy.
