Physics centripetal acceleration/ mass
To find the mass of a planet based on a moon's orbit, the centripetal force must equal the gravitational force acting on the moon. The moon's orbital period is 1.8 days, and its radius is 420 million meters, leading to a calculated orbital speed of approximately 16,968.5 m/s. The centripetal acceleration was determined to be 0.69 m/s². A key tip for solving these problems is to use the relationship between centripetal and gravitational forces, which simplifies the calculations by allowing the use of the period instead of velocity. The expected mass of the planet is on the order of 10^27 kg, similar to that of Jupiter.
astru025
A moon orbits a planet of unknown mass with a period of 1.8 days. If the radius of the moon's orbit is 420,000,000 meters, find the mass of the planet.
For the speed of the moon I got: v=2 x pie x r / v
2 x pie x 420000000 / v = 1.8 days or 155520 seconds since speed is m/s.
v= 16968.5 m/s.
For the centripetal acceleration of the moon I got this: a= v^2/ r
16968.5 ^2 / 420000000 = .69 s
Now for the mass of the planet I am not quite sure how to figure out. If I know the speed and centripetal acceleration for the moon how do I use this to get the mass of the planet orbiting the moon??
My attempt but was un successful:
v^2= G (Me/r)
16968.5 m/s^2= 6.67E-11 ( Me/420000000)
1.03E10
Looks pretty good! The first bit confuses me because you use v for velocity and also for period (usually T), but I agree with your velocity number. I also agree with the a = .69, but the units are m/s², not seconds. I don't quite see how you are getting the mass in the last part. It appears you forgot to square the velocity.
Astru, I would like to offer you a hot tip. Whenever you see the word "orbit" in a problem, immediately write down "centripetal force equals gravitational force" or Fc = Fg. Then replace the Fg with your big G formula and Fc with either the formula with v in it or the one with T in it. In this case, you are given the period, so use the one with the T and don't bother to calculate the velocity. (If you only have Fc = mv²/R, then replace the v with 2πR/T to get Fc = 4π²mR/T²)
You'll soon have an equation where you can cancel the mass of the moon and solve for the mass of the planet in terms of period and radius - only one calc instead of three so less chance for error! For me, the mass works out to roughly 10 to the 15th kg.
You forgot to square the speed, haven't you?
The parameters are pretty close to those of Jupiter's satellite Io. So I expect you'll get a mass close to Jupiter's mass. Order of magnitude 10^27 kg.
  • · Replies 28 ·
