- #36
wimms
- 496
COG never shifts. Its a center of mass of the vehicle. Its weight that shifts, like every time you walk, your weight shifts from leg to leg. Your COG remains at same spot of your body.Originally posted by Mr. Robin Parsons
Although the COG shifts towards the rear when the car lifts, it is the torque application (wheels/axles to frame/chassis) that is lifting the car. Hence the manner of drive, axle, shaft, belt makes little (But not absolutley "NO") difference in the way it will cause lift.
The energy isn't really "lost", per say, but is not being used to drive the car forward as much as it is being used to lift the front end, counteracting gravity.
There is almost no energy consumed on lifting the car as it almost doesn't lift. The energy that seems to go to lifting the car front against gravity in reality goes to pressing rear wheels against ground. Its a weight shift, purely due to inertia and COG being above ground. Front end of car almost becomes weightless as full weight of car goes to rear end.How do you get the energy back when the front end drops back onto the ground? - meister
Originally posted by russ_watters
Where does it go if not toward driving the car? It must go somewhere, it can't just disappear.
Without the weight shift, rear wheels would simply spin too early.
There is no energy to be gained when front drops back to ground, as all that would be gained goes into front wheels contacting ground. The rest is simply weight shift back.
