- #71
wimms
- 496
Robin, I do assume that you know what you are talking about. Can't you realize that your position isn't easily acceptable? If you want others to understand, please try to explain it in more detail why it is that you are right. I posted this shocks function to express my point, not to teach you anything "new". And point is: energy that goes into springs already IS taken away from forward force. Springs compress only when vertical force is present. And shocks really transfer that vertical energy to the ground, they resist vertical compression. The only function of suspension is to doze vertical energy in controlled manner. The only energy loss is in the friction. Do you agree here? I'm not arguing that spring energy is recovered for forward motion. I'm only arguing that it already wasn't available for forward motion.Originally posted by Mr. Robin Parsons
wimms, the energy transferred to the shocks is lost, why, thereafter, you seem to decide that I somehow need to have the reasons for the "use of shocks" explained to me, well you've lost me as to why you are doing this. (not entirely, I can/could 'speculate', easily)
Heck wimms, I had training from people in the automotive industry, batteries, shocks, tires, exhaust systems, braking systems, ignition systems, transmissions, electrical systems, etc. etc.
Chassis is not lifting from that. If you lock clutch, engine would stall. Engine is not lifting, it is twisting around gearbox and some of supports under the hood. At best, its jammed against the chassis. Its not same thing.If you are still missing the point, try practicallity, goes like this, get a rear wheel drive car, automatic tranny, open the hood so you can see the motor from inside the car, get into the car, start the car, place your foot solidly on the brake-and hold down firmly, shift car into drive, place your other foot on the throttle, press gently to slightly accelerate the engine, note the lifting of he engine by the torque that is generated.
Again, please understand that locking wheels changes scenario completely. Then, energy has only one place to go - lifting chassis. When wheels are free, energy goes into accelerating chassis, not lifting it. Although the effect you support is probably there, it is so small that its irrelevant. At 5G accelerations, inertial effects dominate.
Fine. You got me here. I assumed we talk about tons of torque, like nm. But to compare things, we need to bring them to common metric. Let's approach from torque of engine. http://www.amatoracing.com/carspecs.shtmlBTW the "Boss pin" is the pin that connects the connecting rod to the piston, and it is subjected to tons of force inside a very normal car engine. Just because you seemed to think that such forces would be unbearable by the components of cars, they aren't they are, kinda normal.
It offers 6,250 lbft or 8500nm of torque. To give 50tons on rods, cam radius should be about 17cm. Sure, forces at pins are huge, maybe even larger (17cm sounds kinda excessive).
After some thought it seems that dragsters don't have any tranny. Rear diff ratio is 3.2, and wheel radius is 0.5m, basically adds ratio of 2:1. Notice that these ratios apply to increase torque at wheels. This translates into 8500x3.2x2=54000nm of torque at tire patches. a=F/m, and /975kg offers 5.7G linear acceleration.
To lift chassis, the only torque we have is 8500nm. If wheels are locked, then whole chassis has to accelerate at some rate about rear axle. We need to account for engine working rpm range, let's assume max torque is achieved at 2000rpm, 210 radians/sec. If engine can't make it, it'll either stall or fail. Something has to give. With free wheels, they'd spinup.
From standstill to max torque its angular acceleration of 210rad/sec2 at least. Now find how much torque is needed to give such angular acceleration to the whole chassis.
We've found that angular inertia of chassis is about 19 tons. To give such inertia angular acceleration of 210rad/ss, we'd need torque 3,990,000nm! http://hyperphysics.phy-astr.gsu.edu/hbase/n2r.html And that's without accounting for need to overcome gravity.
At 8500nm, angular acceleration of chassis about rear end is at best 0.45rad/ss, and that's when all energy goes there. No engine can work at such low rpm. It either stalls, or engine block blows up. When wheels are free, most of energy goes to linear acceleration, thus even less is avail to lift chassis. Even if you do not agree with 19tons of chassis angular inertia, by using plain 975kg and 1meter distance of COG from axle, needed torque is 204,750nm, which is much more than available.
See? Key points I make:
- torque at tire patch is 3.2x2=6.4 times bigger than at ring gear
- angular acceleration needed accordingly 6.4 times higher at ring
- linear inertia of chassis is 19 times less than angular inertia about rear axle
- engine has not enough torque to flip chassis over at its working rpm range
- engine has enough torque to produce linear acceleration of over 5Gs.
- tires spin up and work as slipping clutch
- energy spent on acceleration is not available for angular lift of chassis about rear axle
- COG height and acceleration force is enough to account for front lift
