Planck Stars: Carlo Rovelli & Francesca Vidotto
In summary, Rovelli and Vidotto show that a star that collapses gravitationally can reach a further stage of its life, where quantum-gravitational pressure counteracts weight. The duration of this stage is very short in the star proper time, yielding a bounce, but extremely long seen from the outside, because of the huge gravitational time dilation. Since the onset of quantum-gravitational effects is governed by energy density --not by size-- the star can be much larger than Planckian in this phase. The object emerging at the end of the Hawking evaporation of a black hole can then be larger than Planckian by a factor (m/mP)n, where m is the mass fallen into
  • #36
100x the sun output is too small. Remember, that we'd get only a small solid angle of it. I don't think we'd capture it. That's the usual out put of a star not much bigger than the sun.
As I said, I think the distribution should follow the distribution of crater size or volcanic explosions. Something log-log. It should be better to look at the CMB. Or perhaps this was responsible for reionization.
  • #37
MTd2 said:
That's a tiny energy, considering that the explosion is isotropic. We would just get a tiny area angle of all explosion...
For comparison, I looked up "supernova" and http://en.wikipedia.org/wiki/Supernova#Energy_output apparently the normal output of Type 1A is 1.5 x 1044 joules. That is isotropic and we are talking about 1028 joules.
So suppose we ignore the difference in wavelength and just compare energy. The factor is 1016.
So the Planck star explosion would have to be 108 times closer in order for us to get the same energy as we do from a Type 1A supernova.
Of course the visible energy production of a supernova is at least hundred-fold more spread out in time. The GRB lasts on the order of one second, a supernova lasts several days. So that would give the Planck star GRB at least a hundred-fold advantage. So as a conservative estimate, let's say that to be detectable the Planck star explosion has to be a MILLION TIMES closer than a detectable SN-1A.
So as a rough estimate, if you can see a SN-1A at a distance of a BILLION light years, then you can see a Planck star GRB at a distance of a THOUSAND light years.
That is certainly very rough. Maybe I can come up with a better estimate later. But it gives some idea.
I'm glad you raised the issue! I'll keep working on it.
  • #38
About the energetics and beaming of GRB's
==quote http://en.wikipedia.org/wiki/Gamma-ray_burst#Energetics_and_beaming ==
Observations suggest significant variation in the jet angle from between 2 and 20 degrees.[68]
Because their energy is strongly focused, the gamma rays emitted by most bursts are expected to miss the Earth and never be detected. When a gamma-ray burst is pointed towards Earth, the focusing of its energy along a relatively narrow beam causes the burst to appear much brighter than it would have been were its energy emitted spherically. When this effect is taken into account, typical gamma-ray bursts are observed to have a true energy release of about 1044 J, or about 1/2000 of a Solar mass energy equivalent[68]—which is still many times the mass energy equivalent of the Earth (about 5.5x1041 J). This is comparable to the energy released in a bright type Ib/c supernova and within the range of theoretical models. Very bright supernovae have been observed to accompany several of the nearest GRBs.[27] Additional support for focusing of the output of GRBs has come from observations of strong asymmetries in the spectra of nearby type Ic supernova[69] and from radio observations taken long after bursts when their jets are no longer relativistic.[70]
Short (time duration) GRBs appear to come from a lower-redshift (i.e. less distant) population and are less luminous than long GRBs.[71] The degree of beaming in short bursts has not been accurately measured, but as a population they are likely less collimated than long GRBs[72] or possibly not collimated at all in some cases.[73]
Numerous other models have also been proposed to explain short gamma-ray bursts, including the merger of a neutron star and a black hole, the accretion-induced collapse of a neutron star, or the evaporation of primordial black holes.[80][81][82][83]
==endquote==
We have to remember that Planck star GRB are MUCH more powerful than conventional evaporation of primordial BH because the conventional model only allows a gamma flash when the mass is almost gone. E.g. 200 ton remnant. Planck star explosion happens when there is still something like 200 Million tons.
Planck star model predicts explosions which are MILLION-FOLD more powerful than conventional primordial BH end-of-life explosion.
We have also to remember that SHORT GRB are a different phenomenon from the longer GRB. Short and very short GRB are recognized as a separate category and separate explanations are offered as to what the mechanism could be.
  • #39
But Marcus, the point I am trying to raise it is not only the power, but the frequency. How this would affect the CMB. Think about crater distribution size. And think about these explosions should be tremendously more common in the beginning of the universe.
  • #40
MTd2, you can try to produce some numbers to show that primordial BH final explosions should have an effect on the CMB. That would be counterintuitive for me because simple intuitive reasoning suggests (to me) that they would not. But then at least we would have some concrete numbers that we might discuss.
The point I think I've explained is that if there are primordial BH which are bursting NOW within a radius say on the order of 1000 light years, then using the Rovelli Vidotto Planck star model they would be visible as a type of GRB called "short GRB" or by some people (Cline et al) "very short GRB."
So there is at least that observational possibility. It clearly cannot be dismissed. A certain known type of Gamma Ray Burst can be studied to see if some of them are in line with Planck star model explosions.
You are arguing that there is ALSO a possibility to study past Planck star explosions in the MICROWAVE BACKGROUND THAT DATES FROM AROUND YEAR 370,000.
The reason we don't see EM radiation from earlier than that is that the gas that filled space was effectively OPAQUE, including to visible light and also to gamma radiation.
But the REDSHIFT from year 370,000 up to present is only about z=1000, or z=1090 more exactly. So a GRB explosion AFTER year 370,000, which produces, like R&V say, GeV photons would, after redshift, be sending us MeV photons . That is not microwave. It would be part of the X-ray astronomy background. Not CMB. A different kettle of fish altogether.
Again, Rovelli Vidotto suggest a representative wavelength for the Planck star gamma burst could be 10-14 cm. After a redshift of z=1000 that is still not millimeter microwave!
It is still very short: 10-11 centimeter.
For a primordial BH to last until after 370,000 before it blows up, it must (according to Planck star model) start with an initial mass of over 5 million tons. This is not all that different from the 200 million tons a BH needs in order to last up until the present day---what I was calling "a fifth gigaton" (200 million is a fifth of a billion). So as a first approximation I'm using R&V estimates of wavelength and photon energy
  • #41
Plenty of more room at the bottom?
The paper on Planck Stars clearly states that the onset of quantum-gravitational effects is governed by energy density -not by size-.
Let's take the above statement into the low mass regime. For example the electron rest mass would have an energy density comparable to the Planck density only at a size ~10^-42 m. This is about 10^-7 of the Planck length.
If we assume that particle mass can only be described properly in a quantum-gravitational setting, would this imply that, there will be "plenty of more room at the bottom", paraphrasing Feynman? With this I mean, could the scale relevant for physics be extended from the usual Planck scale of 10^-35 m to the much lower scale of 10^-42 m ?
Of course I know that an electron is not a black hole, but does it really make any difference? It is a matter where classical gravity meets the quantum world.
berlin
  • #42
Berlin said:
...If we assume that particle mass can only be described properly in a quantum-gravitational setting, would this imply that, there will be "much more room at the bottom"?
berlin
Hi Berlin! I was interested by your comment! I don't feel I understand your idea of "much more room at the bottom". Could you use a few more words and make it more obvious?
  • #43
I edited my response, see above.
berlin
  • #44
A propos of density and length scales, you may be familiar with John Baez physics FAQ explanations which are often particularly nicely written and clear. Here's his website's entry on Compton wavelength
==excerpt http://math.ucr.edu/home/baez/lengths.html#compton_wavelength ==
2 - The Compton wavelength of the electron
The Compton wavelength of a particle, roughly speaking, is the length scale at which relativistic quantum field theory becomes crucial for its accurate description. A simple way to think of it is this. Trying to localize an electron to within less than its Compton wavelength makes its momentum so uncertain that it can have an energy large enough to make an extra electron-positron pair! This is the length scale at which quantum field theory, which describes particle creation, becomes REALLY important for describing electrons. The Compton wavelength of the electron is the characteristic length scale of QED (quantum electrodynamics).
It's easy to guess how big the Compton wavelength is using the knowledge that it depends only on the mass of the electron, relativity and quantum mechanics. Mass has dimension M. Length has dimension L. Time has dimension T. In relativity we have a constant, the speed of light, with dimensions L/T, and in quantum mechanics we have a constant, Planck's constant, with dimensions ML2/T = energy times time = momentum times position. These two constants enable us to express units of mass in terms of dimensions of inverse length. I.e.:
M = (ML2/T)(T/L)1/L = ℏ/c 1/L.
So in particular the Compton wavelength should be about
LCompton = ℏ/mc.
This is about 4 × 10-13 meters.
In fact, this is usually called the "reduced" Compton wavelength. What people usually call the Compton wavelength is 2π times as big, about 2 × 10-12 meters. That's because the wavelength of a wave is really not the reciprocal of its frequency: it's 2π divided by the frequency. But I'm not worrying much about factors of 2π...
==endquote==
But it would be good to go back and see how we got onto the topic of DENSITY in the first place!
Look at Rovelli and Vidotto equation (1). It is a quantum corrected version of CLASSICAL Friedman equation. Basically it tells you approximately how classical behavior is modified at high MACROSCOPIC density. It is not describing things at a microscopic particle level.
So it does not apply to an individual particle, like an electron. And the density of an electron is not well-defined as far as I know.
  • #45
I don't think it matters much that it is macroscopic. To reach the Planck density with electrons for example, as defined in the paper, you need on average (Planck mass)/(electron mass) ~10^22 electrons squeezed into the space of (Planck length)^3. For every known particle mass this number is well above one. This looks strange to me. Maybe this would even mean that there is more than one bit stored in this volume, I don't know. Just naïve thinking perhaps. Maybe just GR where you cannot play with volumes like I do here..
berlin
  • #46
Berlin said:
... To reach the Planck density with electrons for example, as defined in the paper, you need on average (Planck mass)/(electron mass) ~10^22 electrons squeezed into the space of (Planck length)^3...
I don't think the paper talks about "reaching Planck density with electrons". I had always assumed that matter as we know it would not exist at such extreme energy density. So there would be no question of so-and-so many "electrons" contained in a given volume.
But I think I see what you are driving at. You know that the concept of "particle" becomes poorly defined in CURVED spacetime. The concept is more at home in flat. To me that suggests that in highly curved geometry it becomes increasingly difficult to distinguish between the matter and the geometry itself. Does that seem plausible to you? It is obviously just a guess!
Or perhaps there is a kind of supercondensate state of matter in which all particles are in the same quantum state, indeed all TYPES might become the same type of particle. Assuming something that we want to call particle exists at extreme (planckian) density.
I just wanted to indicate some possibilities, but I recently saw some research that is closer to your idea. It described a bounce in which fermions persist through the bounce. This may be more to your taste! So I will get the links. It's quite recent stuff.
  • #47
Berlin, here are the two recent papers I was thinking might relate better to your picture of the bounce density:
http://arxiv.org/abs/1402.5719
Singularity avoidance in classical gravity from four-fermion interaction
Cosimo Bambi, Daniele Malafarina, Antonino Marciano, Leonardo Modesto
(Submitted on 24 Feb 2014)
We derive the dynamics of the gravitational collapse of a homogeneous and spherically symmetric cloud in a classical set-up endowed with a topological sector of gravity and a non-minimal coupling to fermions. The effective theory consists of the Einstein-Hilbert action plus Dirac fermions interacting through a four-fermion vertex. At the classical level, we obtain the same picture that has been recently studied by some of us within a wide range of effective theories inspired by a super-renormalizable and asymptotically free theory of gravity. The classical singularity is replaced by a bounce, beyond which the cloud re-expands indefinitely. We thus show that, even at a classical level, if we allow for a non-minimal coupling of gravity to fermions, black holes may never form for a suitable choice of some parameters of the theory.
5 pages
http://arxiv.org/abs/1402.5880
Fermi-bounce Cosmology and scale invariant power-spectrum
Stephon Alexander, Cosimo Bambi, Antonino Marciano, Leonardo Modesto
We develop a novel non-singular bouncing cosmology, due to the non-trivial coupling of general relativity to fermionic fields. The resolution of the singularity arises from the negative energy density provided by fermions. Our theory is ghost-free because the fermionic operator that generates the bounce is equivalent to torsion, which has no kinetic terms. The physical system is minimal in that it consists of standard general relativity plus a topological sector for gravity, a U(1) gauge field reducing to radiation at late times and fermionic matter described by Dirac fields with a non-minimal coupling. We show that a scale invariant power-spectrum generated in the contracting phase can be recovered for a suitable choice of the fermion number density and the bare mass, hence providing a possible alternative to the inflationary scenario.
Comments: 6 pages
There was some earlier work by Ed Wilson-Ewing where matter was included in a LQG bounce and he found that the bounce occurred at much lower density. So as the above CLASSICAL work suggests might be the case, when matter is included in a Loop gravity bounce it might indeed turn out that the bounce occurs not at some percentage like 40% of Planck density but several orders of magnitude sooner, as Ed W-E found. I don't think I am able to evaluate this work.
  • #48
marcus said:
I don't think the paper talks about "reaching Planck density with electrons". I had always assumed that matter as we know it would not exist at such extreme energy density. So there would be no question of so-and-so many "electrons" contained in a given volume. QUOTE]
Aha! I guess we reach the real point of discussion. If you don't know the state of matter at those density's, you don't really have a physical theory describing it! So how can Rovelli et al. conclude that the bounce takes place at that specific density? They refer to a paper of Ashtekar et al. which I do not understand. I have to check if the prediction about the radiation is based on the above assumption, but if so, it is may be poorly justified.
Thanks for the references. Only time for a quick look, but both do not seem to use any LQG scale physics. What would Rovelli has to say?
berlin
  • #49
Hi Berlin,
I think it would help this thread to bring in some sense of the history of showing the Loop QC bounce happens (in combination with various matter fields). Obviously it has to be checked by computer runs in a wide variety of cases to get an idea of how robust the conclusion is that there is a bounce.
The papers on this go back to 2001, and especially back to 2006 when Ashtekar, Pawlowski, Singh introduced an improved version of LQC dynamics. For perspective, here's a paper that was posted yesterday, with Singh one of the authors, but warning: don't try to read it, too specialized and technical!. However in the first few paragraphs it reviews the history and gives references [1 - 4] to some of the circa 2006 papers:
http://inspirehep.net/record/1282592
Numerical simulations of a loop quantum cosmos: robustness of the quantum bounce and the validity of effective dynamics
Peter Diener, Brajesh Gupt, Parampreet Singh
Feb 26, 2014 - 46 pages - 26 figures
A key result of isotropic loop quantum cosmology is the existence of a quantum bounce which occurs when the energy density of the matter field approaches a universal maximum close to the Planck density. Though the bounce has been exhibited in various matter models, due to severe computational challenges some important questions have so far remained unaddressed. These include the demonstration of the bounce for widely spread states, its detailed properties for the states when matter field probes regions close to the Planck volume and the reliability of the continuum effective spacetime description in general. In this manuscript we rigorously answer these questions using the Chimera numerical scheme for the isotropic spatially flat model sourced with a massless scalar field. We show that as expected from an exactly solvable model, the quantum bounce is a generic feature of states even with a very wide spread, and for those which bounce much closer to the Planck volume. We perform a detailed analysis of the departures from the effective description and find some expected, and some surprising results. At a coarse level of description, the effective dynamics can be regarded as a good approximation to the underlying quantum dynamics unless the states correspond to small scalar field momenta, in which case they bounce closer to the Planck volume, or are very widely spread. Quantifying the amount of discrepancy between the quantum and the effective dynamics, we find that the departure between them depends in a subtle and non-monotonic way on the field momentum and different fluctuations. Interestingly, the departures are generically found to be such that the effective dynamics overestimates the spacetime curvature, and underestimates the volume at the bounce.​
Here you see they are checking in some specific cases. The bounce has been checked also in NON-isotropic and in spatially NON-flat cases, with different kinds of matter, both with and without inflation (which involves introducing an additional field). There seems to be no way all at once to verify that it happens in all possible cases. One would have to somehow vary all the parameters in every possible way in one grand number-crunching simulation. :smile:
You asked about Rovelli. AFAIK he has worked primarily on the full LQG and Spinfoam theory, rather than the application to cosmology. In the Planck star paper, Rovelli and Vidotto simply borrow the bounce, which many years' work by Loop cosmology people have made plausible, and apply it in the context of black holes.
To paraphrase in effect, I think they say something like this: look this has been tested both numerically and in the solvable equation version for many years in case after case, with quantum states of geometry that are peaked and spread-out, with closed, flat, and open spatial geometry, with various stand-ins for matter, and it looks increasingly robust, so let's SUPPOSE that the Loop cosmology people (Ashtekar, Agullo, Nelson, Singh, Wilson-Ewing, Vidotto, Pawlowski, etc) are right and that when you quantize cosmology Loop-style and run it back to the start of expansion you see a BOUNCE. So let's suppose that and take it over and apply it to black holes!
  • #50
Oh, you were also asking about the two CLASSICAL papers I mentioned in post #47 (by Alexander, Bambi, Marciano, Modesto…). What should one conclude? They even get a bounce in some classical setting. Yes I think that is very encouraging. In a quantum theory when you get some result, it's highly supportive if some other people find that a similar result can arise in a non-quantum version of the problem.
Regarding black holes, one of the papers says: "...The classical singularity is replaced by a bounce, beyond which the cloud re-expands indefinitely. We thus show that, even at a classical level, if we allow for a non-minimal coupling of gravity to fermions, black holes may never form for a suitable choice of some parameters of the theory…"
Berlin said:
... What would Rovelli have to say?
Two of the authors of that paper have co-authored/postdoc't at Marseille. I imagine CR would be pleased by the supportive classical results but to answer your question I really don't know what he would say.
Here are a dozen or so LQG papers solo or coauthored by Leonardo Modesto, most about the Lqg black hole:
http://arxiv.org/find/gr-qc/1/AND+au:+modesto_L+ti:+loop/0/1/0/all/0/1
And some Marciano solo or co-author papers:
1105.3480 Towards a Loop Quantum Gravity and Yang-Mills Unification (with Alexander on that one)
1011.5676 Coherent states for FLRW space-times in loop quantum gravity (PRD)
1010.1258 Big Bounce in Dipole Cosmology (PRD)
1003.0352 Towards inhomogeneous loop quantum cosmology: triangulating Bianchi IX with perturbations (MG12 proc.)
0911.2653 Triangulated Loop Quantum Cosmology: Bianchi IX and inhomogenous perturbations (PRD, with Rovelli)
Of course I don't know, but I'd think he would have to be pretty happy, especially about the one about black holes with fermion matter being non-singular and developing a bounce, the one titled:
  • #51
But formation of these smaller black holes, either 200 tons, 1 ton, 20kton, 50Mton, are all counter intuitive since it conflicts with the isotropy and jeans instability. That is, the universe was too homogenous for stars to form. For such small masses, an incredible density and inhomogeneity in very small places would be required.
The only thing I can imagine it is that inflation was turbulent. That is, at smaller scales, it presented some kind instability. This instability would super compress matter.
Considering that energy dissipation is null, the komologorov velocity microscale (the compression element) goes with 3/4 of the temperature . The density of energy for formation of a black hole goes with 1/T, that -1 of the temperature. So, black hole formation falls with -1/4 of the temperature. But, given that we are talking about an exponential decrease of temperature, the great majority of black holes will be of small size. Even the total mass of black holes formed.
So, if something is seen exploding today, maybe a signature on CMB is not unlikely.
  • #52
Maybe you don't understand, MTd2. The formation of primordial BH has nothing to do with STARS.
I am talking about primordial BH with masses like 200 million tons. If primordial BH were formed with masses significantly smaller than that they would most likely already have evaporated (at least according to the Rovelli Vidotto calculation.)
I do not find it "counter-intuitive" that primordial BH would have formed, at a time when the universe was very dense, due to random density disturbances producing small regions of over-density.
  • #53
So, you won't have problem to see that smaller masses will be vastly more abundant (even the total mass should be bigger for sets with smaller massses) than those with bigger masses.
  • #54
Hi MT, check out my earlier post #40, which includes this:
marcus said:
...For a primordial BH to last until after 370,000 before it blows up, it must (according to Planck star model) start with an initial mass of over 5 million tons...
Remember we are using the Planck star model.
If a PBH initial mass is less than 5 megaton then it dies before year 370,000 while universe is still opaque and we never see its light.
Just as we never see ordinary CMB light emitted before 370,000, or any kind of light from before that time.
If a PBH initial mass is greater than 5 megaton then it releases a GRB after year 370,000 and the radiation is several GeV gamma! Redshift between then and now is no more than a factor of 1000. So the radiation that gets to us is between several MeV and GeV. This is not microwave.
Therefore no significant contribution to CMB, which is microwave background.
MTd2 said:
..., maybe a signature on CMB is not unlikely.
Instead, the contribution from past PBH explosions, as I've been explaining, is to the X-ray and gamma-ray background. That is pretty noisy, as we can see from the recent papers looking for emission lines that could represent Dark Matter decay. There are people assiduously studying the X-ray sky and it is a very good thing to study! And of course there is a lot of interest in the gamma-ray sky especially in GRB.
But this is very different from the studying the Cosmic Microwave Background. We should not even be talking about the CMB, but you seem to be coming back to it rather often! :biggrin:
  • #55
Thank you Marcus for digging up the bounce literature and surely nice that so recently as yesterday a new paper came out. What troubles me about the idea of Planck density is the amount of information stored in the Planck volume. I always had the naive idea that a Planck Volume could only contain one bit of information. I would like to see a bouncing model based on information or entropy arguments in stead of a specific approximation model like the papers you showed ('massless scalars' for example). Also there seems to be large diffeences in bouncing scale depending on the non-gravity particles and forces considered.
Berlin
  • #56
Marcus, you are forgetting the contributions from the end of inflation up to 370ky
  • #57
No, MTd2, I am not forgetting those. Universe opaque to light of any kind including x-ray and gamma, before 370,000
I sympathize but it is not quite that simple is it? Often people associate the bits with the AREA, the number of Planck area units, rather than the number of Planck volumes.
And that would go as the SQUARE of the mass that has fallen into the hole
I would like to see a bouncing model based on information or entropy arguments...
Berlin, for that you have to read the Rovelli Vidotto paper itself. Their argument is new and based on information/entropy. They make a big point that the even at the smallest point of the bounce the "star" is still large enough to contain all the information which has fallen in and which it must deliver at the end, when it explodes back into the rest of the world.
Are they right? I don't know. I can just wait and see if this new idea and new argument (so far just sketched, I would say) is born out by subsequent longer papers, e.g. one I believe is in prep by Rovelli with Matteo Smerlak.
  • #58
If I understand correctly, information density is like energy density - unbounded. It wouldn't make much sense to allow a mass singularity without an information singularity.
  • #59
But it would let its mark by making sounds, that is, disturbing the energy distribution on CMB,
  • #60
Are you sure? Then would you like to show the numbers? The surface we see was at a distance of 42 million LY at that time (year 370,000). We see resolution on the order of one degree.
Roughly speaking one degree spread on that surface corresponds to about 1 million LY.
I wonder if the "sounds" you are talking about are short wavelength turbulence that will dissipate as noise, or whether any of them actually could have an imprint on the grand scale of the real CMB structure that is studied.
Have you done the numbers?
  • #61
Nugso:
If you haven't read it, Feynman's book WHAT DO YOU CARE WHAT OTHER PEOPLE THINK?, 1988 or so, is a rather irreverent look at science...and some people Feynman meets assocated with it including Neil Armstrong and Sally Ride a/w the Challenger disaster commission investigation. You won't learn an awful lot about science, but if you like Feynman, you'll laugh out loud at some of his antics.
  • #62
A wide ranging discussion...good stuff...
Marcus, very nice descriptions and simplified of the Rovelli paper...thank you...
[But, ah, ahem, how do I say this... we don't do "nursery rhymes" in physics forums...[post #33] or do we?? I thought this is a SERIOUS forum requiring some measure of decorum. Seems you are on the left wing coast, maybe 'moonbeams causing minor affectations out there? ...whatever, can't we possibly apply a different title, maybe "physics ditties" or maybe "geek rhymes"...or "symphonic physics poems"... if you insist on musical accompanyment...Have you possibly relocated maybe, too close to Hollywood? :smile:]I had four thoughts as I read through the discussions:
Hawkings Jan 2014 paper, which I assume is what MTD alluded to early in this discussion, cosmological big bounce relationship to the paper, which you covered, ADS/CFT type [volume area] information correspondence [just mentioned] and finally the Chandrasekhar and Tolman–Oppenheimer–Volkoff limit of neutron degeneracy pressure...which I recall are quantum based calculations...
So be really interesting if this paper turns out to be correct what 'settled science' may be revised! I find the apparent discordance with Beckenstein bound and holographic especially interesting, if there is one, since that result [a bit per Planck area] seems to pop out from several different mathematical and theoretical approaches.
Here is a brief snippet of that 2/2014 Hawking paper for those interested:
http://arxiv.org/abs/1401.5761
Information Preservation and Weather Forecasting for Black Holes
S. W. Hawking
(Submitted on 22 Jan 2014)
….gravitational collapse produces apparent horizons but no event horizons behind which information is lost. This proposal is supported by ADS-CFT and is the only resolution of the paradox compatible with CPT. The collapse to form a black hole will in general be chaotic and the dual CFT on the boundary of ADS will be turbulent. Thus, like weather forecasting on Earth, information will effectively be lost, although there would be no loss of unitarity.
This seems it might be a key test of what they Rovelli/Smerlack et al are doing:
For example:
http://en.wikipedia.org/wiki/Holographic_principle
The holographic principle is a property of quantum gravity and string theories which states that the description of a volume of space can be thought of as encoded on a boundary to the region—preferably a light-like boundary like a gravitational horizon.
the above along the lines expressed by Berlin...
Leonard Susskind seems to believe information bits can be explained by strings...
Here is one prior post I made that expresses my reservations so far:
Leonard Susskind in his book THE BLACK HOLE WAR (his controversy with Stephen Hawking) has some really interesting insights on information and horizons...like the horizon of a black hole is "stringy"...it can be described in terms of quantum strings...and so hidden information is proportional to the total LENGTH of a string!...and Hawking radiation can be viewed as string bits breaking loose from just outside the horizon...due to quantum fluctuations...a perspective akin to virtual particles causing the Hawking radiation.
I thought we generally believed so far strings are extended objects rather than the point particles of the Standard model...is it possible such 'extended objects' density can be unbounded as Chronos suggests??
  • #63
Naty, thanks for the variety of thoughtful comment! You touch on many points. As for the rhyme, call it a "mnemonic" if you like. It helps me remember that initial mass of 1/5 gigaton leads to lifespan equal to present age of (expansion phase of) universe---plus the all-important fact that natural processes (like a bounce) proceed with extreme slowness deep in the hole's potential well.
Like many rhymes it can serve as a memory aid, if you're so inclined.
I wanted to try a sample calculation going back to redshift z+1=20,000. Let's see what size starburst would have happened then. I just put 20000 in for S in Jorrie's "Lightcone" calculator, and a zero in for the number of steps so the table will be just a one-liner:
[tex]{\scriptsize\begin{array}{|r|r|r|r|r|r|r|r|r|r|r|r|r|r|r|r|} \hline a=1/S&S&T (Gy)&R (Gly)&D_{now} (Gly)&D_{then}(Gly)&D_{hor}(Gly)&V_{now} (c)&V_{then} (c) \\ \hline 0.000&20000.000&0.000001873&0.0000&46.177&0.002&0.003&3.21&659.18\\ \hline \end{array}}[/tex]It turns out that corresponds to year 1873 of the expansion.
Now the lifespan of the hole goes as the cube of the initial mass. In conventional Hawking model, one second corresponds to 228 metric tons. In the RV version that initial mass gives 0.65 seconds. The RV lifetime is 65% of the conventional (the thing bursts before it is completely evaporated).
(1873 years/.65 second)^.33333 * 228 tons = 1,025,000 tons
By comparison, again with the RV model, lifespan of 370,000 years implies initial mass of
(370000 years/.65 second)^.33333 * 228 tons = 5,971,000 tons ≈ 6 million tons
Very roughly, if you increase redshift by a factor of 20 (in this range of years) then the size of the gamma ray burst is decreased by around a factor of 6. From 6 million down to one million. That is how it works out in the early years preceding the emission of the CMB ancient light that we study today.
My intuition, and perhaps that of others as well is that since we observe the CMB with resolution of about one degree of angle, corresponding to about 1 million lightyears on the surface of last scattering, and these possible gamma bursts from primordial BHs are comparatively small, they would not leave an imprint at the million light year scale on the surface of last scattering. In other words they would not leave a visible imprint on the microwave sky.
Just wanted to buttress that with some numbers.
It would in any case have to be a mechanical disturbance, the gamma ray LIGHT would presumably be blocked by the opacity of universe before year 370,000. And any that was recent enough not to have been blocked would not be redshifted enough to blend in with CMB. It would still be x-ray or gamma. So we are just considering mechanical disruption of the surrounding gas by a comparatively small explosion (nowhere near the size of astrophysical GRB).
I don't know of any professional author who thinks primordial black hole (PBH) explosions could have left a detectable imprint on the microwave background. This may be why.
  • #64
I'm going to reiterate my yearly plea to first learn the basics before discussing advanced physics concepts. That it would prevent all sorts of false claims from being ascribed to a paper that most assuredly does not make them.
That learning the basics will prevent very simple mistakes, like believing a black hole can hawking radiate and evaporate in the early universe (it's actually the opposite).
That physicists don't use units like kilotons. That there is no sense of talking about astrophysics size black holes as a dark matter candidate. That terms like information singularity have no operational meaning in physics. That talking about turbulence and super compressing matter in the context of inflation is word salad.
Gentlemen, I'm sorry to be rude but you are badly mangling a lot of physics In this thread.
  • #65
Haelfix said:
...like believing a black hole can hawking radiate and evaporate in the early universe (it's actually the opposite)...
Good point! If the surrounding temperature is too high the thing can't evaporate. Since we are talking about primordial BH of around a billion kg (i.e. million metric tons) I will have to check to see what their Hawking temperature is compared with the universe temperature at the relevant redshift.
BTW What's wrong with using the mass equivalent of energy as a measure of energy?
Or what is wrong with expressing the mass of a black hole in kilograms?
A metric ton is simply 1000 kg. A million tons is a billion kg. Megaton is easier to say than Gigakilogram, or Teragram, or billion kilogram.
  • #66
According to the Rovelli Vidotto model, what are the lifetimes of a sample of PBH (as long as the surrounding temp is not so high that the thing has trouble evaporating?) and also,what are their Hawking temperatures?
First, for a one Megaton (i.e. billion kg) PBH the temperature is
hbar*c^3/(k*8pi*G*10^9 kg) = 1.227e14 kelvin = 122.7 trillion Kelvin .
the conventional Hawking lifetime of such a thing is (10^6/228)^3 seconds in years = 2674 years
and the RV lifetime is 65% of that .65*2674 years = 1738 years
Recall that was roughly the lifetime I got when I wanted one that would blow at redshift 20,000 (as a kind of benchmark). At that time the universe temp is about 20000*2.76 Kelvin.
so the PBH is going to have no trouble evaporating. Its temp is in hundreds of trillions of K and the surrounding universe is cold by comparison: less than 100 thousand K.
Now suppose we want a PBH which bursts right around year 370000, when the universe became transparent to light and the CMB that we now see was emitted. That is going to be SIX Megatons. Because
(370000/1738)^.3333 = 6. does anybody have questions about this? The lifespan goes as the cube of the mass.
On the other hand the TEMPERATURE is inversely proportional to the mass. So we just have to divide the benchmark temp by 6:
122.7/6 = 20.5.
So that sample PBH has a temperature of around 20 trillion Kelvin. And for nearly all its 370,000 year lifetime the surrounding temperature is much MUCH lower. For instance it is only 3000 Kelvin in year 370,000.
So that sample PBH also will have no trouble evaporating.
  • #67
So a good undergraduate unit for discussing mass is the kilogram. In twenty years of physics The only time I've ever seen tons utilized is when we discuss nuclear explosion yields, which is some bizarre historical accident and essentially a ridiculous unit.
For discussing astrophysics masses, an appropriate unit would be a solar mass. For microscopic black holes, something like the mass of a proton or something expressed in electron volts.
Primordial black holes of relevance to astrophysics have lifetimes that are many times the age of the universe. Primordial black holes of relevance to particle physics have essentially disappeared early on in the lifetime of the universe.
For dark matter candidates, microlensing experiments have essentially ruled out primordial black holes that are lighter than a certain threshold and gamma ray experiments provide a lower bound as well, which leaves a very small window on possible sightings. In any event, none of those types of pbhs would decay in the early universe, as it was simply too hot and they were absorbing Cmb photons at the time. Instead their lifetimes are roughly the age of the universe, for instance asteroid size objects and the like.
  • #68
To summarize what I've been saying about lifespans of PBHs (primordial black holes) in early universe (according to Rovelli Vidotto "planck star") model.
First keep in mind that for PBH, in this discussion, a convenient mass unit is 109 kg, which I'm calling a megaton (that is, a million metric tons).
To visualize that mass, it is the mass of a cube 100 meters on a side which is standard density (density of water). So the mass of a small asteroid, or a standard density cube the size of a football field.
Code:
Mass of PBH     Lifespan        when they burst
1 megaton       1700 years         redshift ~ 20,000   distances 1/20000 of size now
6 megaton      370,000 years       emission of CMB ancient light  redshift 1090
200 megaton   13.9 billion years   present-day era
For further reference, to make the mass additionally concrete, 1000 megaton is the mass of a standard density cube which is 1 kilometer on a side. Roughly speaking the mass of a medium size asteroid. A PBH of that mass would not be expected to burst for a very long time. Since lifespan goes as the CUBE of the mass, and it is FIVE times the mass of PBH which lasts until present era, the 1000 megaton PBH would last 125 times the present age of expansion.
Haelfix said:
So a good undergraduate unit for discussing mass is the kilogram. ...
For dark matter candidates,..
In any event, none of those types of pbhs would decay in the early universe, as it was simply too hot and they were absorbing Cmb photons at the time...
Hi Haelfix, I'll keep in mind your concern about units. In fact I am looking for a convenient unit of mass that could be visualized by high school students and lay-people and works in the context of the PBH I want to discuss, facilitates comparison with asteroids and cubes which reader can visualize.
I've found when you say billion and trillion too much, listener's eyes glaze over. So I'm trying out megaton.
Most of these people weren't even born yet when the old 1950s cold war buzz prevailed about "kilotons of TNT equivalent" so I don't think they will be bothered by thinking too much about TNT high explosive if we don't make a point of suggesting it. Just think about asteroids and big ice cubes. :smile:
You mentioned "dark matter candidates". We are not talking about "dark matter candidates" here. I've been interested in hearing about the sterile neutrino as a possible DM candidate. But that's another topic.
The PBH being discussed here spend most of their lifespans in a universe that is much lower temperature than they are, so they are free to evaporate. Your concern about the surrounding temperature being higher than the relevant BH hawking temperature is unnecessary in these cases.
You mention absorbing CMB photons. These were emitted when the universe temperature was about 3000 Kelvin, so you are referring to an early universe period after that, when the ambient temp was 3000 or LESS, and CMB photons already exist. The PBH we are talking about are hotter than 3000 Kelvin by many orders of magnitude. So ambient temperature would hardly interfere with evaporation.
Thanks for your comment. Needless to say, it's very helpful to have additional discussion!
  • #69
Sorry, earlier comments in this thread were about dark matter. Mtd2s question was concerning the effect of PBHs on the cmb spectrum.
The answer is those black holes do not evaporate in the early universe. The only type of PBH that has sufficient mass range to appreciably influence the CMB are essentially dark matter candidates, who's mass range puts them around the age of the universe or so.
  • #70
Haelfix said:
Sorry,..
No problem! In fact we did comment about PBH as dark matter earlier in thread, and then disposed of that.
What I'm interested in PBH as candidates for, and what Rovelli and Vidotto are talking about, is PBH as source of short gamma ray bursts, which are observed. According to Cline et al they don't have an isotropic distribution in the sky, suggesting they originate in our galaxy.
As I recall few come from the direction of galactic center and most actually come from the sector *opposite* galactic center which should have some cause LOCAL to the galaxy, perhaps something to do with the arm structure of the galaxy.
There is a suggestion that these short or very short bursts, unlike longer bursts, are not BEAMED. They arise IOW from a spherically symmetric explosion--so by a significantly different mechanism from the larger more distant longer-duration GRB.
Anyway we are not talking about "dark matter candidates" at this point.
I'm not sure what you mean by "influence the CMB". I don't think there is ANY reasonable chance that what we are discussing could influence any observable feature of the CMB ---and have been trying to convince MTd2 of this whenever he has brought up the possibility :^D
So I am glad that you agree with me on that, at least in general terms.
