- #71
sylas
- 9
Xnn said:Not sure if how significant other forcings are.
Neither is anyone else; there are significant uncertainties in other forcings. CO2 is the simplest forcing to evaluate and is known to quite high accuracy. Other forcings are known, but with larger bounds of accuracy. The bounds are sufficient to conclude with strong confidence that greenhouse effects are the largest forcing, and that CO2 is the largest contributor to that. But the lack of certainty in other forcings still means a large spread of uncertainty about total forcing.
I've given a widely repeated diagram in [post=2215403]msg #66[/post] of thread "Estimating the impact of CO2 on global mean temperature", outlining estimates and uncertainties for forcings. It can be found also as figure 2.20, on page 203 (chapter 2) of the http://www.ipcc.ch/ipccreports/ar4-wg1.htm" . The estimates are quantified, with 90% confidence bounds, in table 2.12, page 204.
Felicitations -- sylas
PS. As an added wrinkle... a forcing is a change from one time to another. The table I've shown is giving the forcings from 1750 to the present. But if you want to look at the last 30 years, then the picture changes again, generally making the greenhouse effects and CO2 in particular even more significant for the immediate rate of change. The immediate rate of change also is affected by changes in heat uptake in the ocean, which will impact rates of change in much the same way as a forcing.
