- #36
- 14,373
- 6,866
I don't have one, because I have derived it by myself. Please find the error (if any) in my derivation.Dickfore said:please give a reference for this conclusion.
In interacting quantum field theories, point like particles don't exist. Also the classification of a particle as "elementary" is not fundamental but only refers to the way how it winds up in perturbation theory from some non-interacting elementary particles whose choice is more due to convenience than tp principle.TrickyDicky said:What is exactly the justification of the assumption that elementary particles be point-like in QFT?
Demystifier said:I don't have one, because I have derived it by myself. Please find the error (if any) in my derivation.
Dickfore said:But it says that the non-relativistic treatment gives a factor that is twice as big for the spin-orbit coupling term.
Demystifier said:Please see the attachment.
TrickyDicky said:
As yet, no other authors on the arXiv cite Jabs' paper.
Dickfore said:Also, I was asking a different question. Does the non-relativistic treatment give the correct factor for the spin-orbit interaction?
TrickyDicky said:Yes.
DrDu said:Are you sure? I remember the derivation of the SO interaction to involve calculating the magnetic field in the momentary rest frame of the spin. As the spin is accelerated, there is an additional Thomas precession term which is of purely relativistic origin.
As I have written in the text, Eq. (3) is valid for ARBITRARY coordinate transformations, not only for rotations. If you were familiar with topics such as general relativity or differential geometry, you would probably know it.Dickfore said:No one asked you how the E-field transforms under rotations, but under Galilean transformations. So, Eq.
(3) is not valid.
DrDu said:I found an excellent source for the relativistic contribution to SO-coupling on my shelf, although it is in German:
W. R. Theiss, Grundzuege der Quantentheorie, Teubner, Stuttgart, 1985
The magnetic field seen by the spin is due to the Lorentz transformed Coulomb field of the nucleus. The Thomas precession makes up ( at least in lowest order of v/c) for a contribution of different sign which compensates half of the effect size. So it is not a small higher order correction.
Addendum: The Thomas precession would even lead to SO splitting if the spin where bound to the nucleus not by a Coulombic force but by some other force which does not interact with the magnetic moment of the spin, e.g. gravitationally.
PhilDSP said:Would the need for considering those effects be by-passed if we assume the form of the Dirac equation is correct and can subsequently demonstrate that the energy equation [itex]E^2 = p^2c^2 + m^2c^4[/itex] can be rigorously derived from purely non-relativistic considerations?
TrickyDicky said:Can you show that derivation?
PhilDSP said:It will take a while to write up properly and is in some ways involved enough to warrant a paper in itself. That probably makes it off-topic in this forum much as I would appreciate feedback.
Demystifier said:As I have written in the text, Eq. (3) is valid for ARBITRARY coordinate transformations, not only for rotations. If you were familiar with topics such as general relativity or differential geometry, you would probably know it.
Exactly! Notice that invariance (covariance) of an equation means that if it holds in one reference frame, then it holds in ALL reference frames.TrickyDicky said:It won't hold for situations where the curl of the magnetic field doesn't vanish though.
So, that implies relativity. As for "other" transformations, what else would you suggest?TrickyDicky said:In such cases either the Lorentz group or a more general group of transformations is required.
Isotropy of what? Maxwell sure did it, but then people thought of something called aether. I wonder why?TrickyDicky said:So as long as one assumes isotropy it is possible to formulate electrodynamics consistently without relativity considerations, after all Maxwell did it, didn't he?
Dickfore said:Isotropy of what? Maxwell sure did it, but then people thought of something called aether. I wonder why?
TrickyDicky said:Spatial isotropy, a spherically symmetric charge distribution would allow Galilean invariance for the Gauss' law. Spatial isotropy is a reasonable assumption in our universe.
This is simply wrong. Just as vector may have to do with arbitrary coordinate transformations (not only rotations) in 4 dimensions, it may have to do with arbitrary coordinate transformations in any number of dimensions, including 3.Dickfore said:When you classify something as a 3-vector (as you did in your "derivation"), it has to do with rotations in 3D-space only!
In the conclusion they say:Dickfore said:I suggest you have a look at the document linked in post #25.
Dickfore said:But, a spherically symmetric charge distribution means there is a well defined center. Where is the center of the Universe?
Demystifier said:This is simply wrong. Just as vector may have to do with arbitrary coordinate transformations (not only rotations) in 4 dimensions, it may have to do with arbitrary coordinate transformations in any number of dimensions, including 3.
It is a common misconception among physicists that general coordinate transformations are only relevant in general theory of relativity. But this is wrong. In 3 dimensions, they are relevant even in non-relativistic physics.
TrickyDicky said:If we add the usual assumption of homogeneity I don't think you need to have a center.
Demystifier said:In the conclusion they say:
"The following 3 assumptions are inconsistent:
1. Galilean invariance
2. Continuity equation.
3. Magnetic forces between electric currents."
Fine, but this means that if we do not require one of these items, then we still have a consistent theory. In particular, for the consistency of the Gauss law (which is what we are talking about) you don't need magnetic forces so you don't need to require 3. And then 1. and 2. are consistent.
To remove confusion, let me remind you about the history of our discussion:
- In #19 you said that one cannot formulate consistent non-relativistic electrodynamics.
- In #20 I asked why not.
- In #21 you said because Gauss's Law is not covariant w.r.t. to Galilean transformations.
I think you made a mistake in #21. I agree now that one cannot formulate consistent non-relativistic electrodynamics, but I don't agree that Gauss's Law is not covariant w.r.t. to Galilean transformations. However, since we agree on the central statement that one cannot formulate consistent non-relativistic electrodynamics, I think we should not longer argue on the auxiliary statement that Gauss's Law is not covariant w.r.t. to Galilean transformations.
granpa said:I'd very much like to know which law isn't invariant.
This is fun: No, in an expanding universe is not broken, no privileged points.Dickfore said:But the center of the charge distribution is a privileged point, so homogeneity is broken.
That's a good objection. More precisely, that means the following. The 3-velocity transforms as a vector under arbitrary space transformations, but it does not transform as a vector under arbitrary space-time transformations. Galilei transformation is a space-time transformation (because the transformation x'=x-vt mixes space and time), so the 3-velocity does not transform as a 3-vector under Galilei transformation.Dickfore said:Acceleration remains invariant under Galilean transformations:
[tex]
\mathbf{a}' = \mathbf{a}
[/tex]
but velocity transforms as:
[tex]
\mathbf{v}' = \mathbf{v} - \mathbf{V}
[/tex]
where [itex]\mathbf{V}[/itex] is the relative velocity of the reference frame K' w.r.t. K.
Since these two do not transform in the same way under Galilean transformation and both a 3-vectors, it means that your "rule" is wrong.
How about a bar magnet? Velocity is zero, so you are surely in a non-relativistic regime. But, there is a non-zero magnetic field around a bar magnet.Demystifier said:But do it for nonrelativistic physics, in which magnetic field does not exist (because it is an effect of the order v/c, which vanishes in the nonrelativistic limit).
TrickyDicky said:This is fun: No, in an expanding universe is not broken, no privileged points.
