Point-like particles, Lorentz invariance and QM/QFT
In summary: However, according to the relativistic QM, particles like the electron do not have an intrinsic magnetic moment, they only have a magnetic moment due to the presence of an external field.
  • #71
Dickfore said:
What are you talking about? You keep invoking some extra condition that have nothing to do with the problem at hand.
Well those extra conditions happen to be fulfilled by the current model of universe.
And in fact to come back to the OP the homogeneity condition is required for the point-like particles QFT assumption.
  • #72
I'm out of this thread.
  • #73
A not so polite way of conceding. But thanks for your contribution.
  • #74
Dickfore said:
How about a bar magnet? Velocity is zero, so you are surely in a non-relativistic regime. But, there is a non-zero magnetic field around a bar magnet.
The velocity of magnet is zero, but it does not mean that the velocity of microscopic particles (electrons in atoms) which create this magnetic field is zero.
  • #75
DrDu said:
I have no idea what you mean, but spin orbit coupling is not especially a quantum mechanical effect but could in principle also be observed in classical systems.
See e.g. here:
https://www.physicsforums.com/showthread.php?t=161632&page=2
Thanks for the link. Jackson has a right-to-the-point treatment of Thomas precession starting at page 548 in "Classical Electrodynamics" and identifies it as a correction to the 'classical' (i.e. naive) equation of motion for electron angular momentum. His characterization of the situation is
In 1926 Uhlenbeck and Goudsmit introduced the idea of electron spin and showed that, if the electron had a g factor of 2, the anomalous Zeeman effect could be explained, as well as the existence of multiplet splittings. There was a difficulty, however, in that the observed fine structure intervals were only half the theoretically expected values. If a g factor of unity were chosen, the fine structure intervals were given correctly, but the Zeeman effect was then the normal one. The complete explanation of spin, including correctly the g factor and the proper fine structure interaction, came only with the relativistic electron theory of Dirac.
I believe Jackson is referring to Dirac's 1928 paper and his electron equation or the various different forms of it. The point being that the need for the Thomas precession correction disappears in the Dirac treatment.
  • #76
ytuab said:
As far as I know, Dirac equation is equal to "special relativity".
Substituting relativistic x and t into usual accelaration equaion (of Newtorian mechanics).
Ant if we use the force F of v=0, we can get your relativistic momentum and energy.
(And the solution of Dirac equation uses four vector momemtum, energy, time, position variables, which are based on SR.)
In addition to the fact that the Dirac equation is highly billed as being relativistic, Dirac shows in his 1928 paper that it is invariant under the Lorentz transformation. But it may be worth investigating exactly where and why SR is invoked and where it is not required.
The gamma matrices contain fixed numeric values don't they? They don't vary with regard to a Lorentz transformation. A very large part of the motivation of the development of the Dirac equation revolves around the split of the momentum into components for each spatial dimension. Symmetry is invoked for the manipulation of the spatial components and consideration of spin, not from a relativistic viewpoint but from a geometric viewpoint.
  • #77
As far as I know, Dirac respected Einstein's special relativity.
Dirac knew about Maxwell's electromagnetic theory after knowing the special relativity according to this book.
(The Strangest Man by Graham Farmelo. )
The gamma matrix and Pauli patrix are fixed values. But their eigenfunctions (= spinor) vary with regard to Lorentz transformation.
For example, when the spin points to z direction at first, its direction may change under Lorentz transformation.
Sigma matirix (gamma matrix) is fixed, so their spinors (= eigenfunctions) need to change under Lorentz trandformation.
As you know, Klein-Gordon equation (= Lorentz invariant) is completely equal to the special relativity.
And Dirac equation also satisfies Klein-Gordon equation.
According to the QFT, the "forms" of Dirac equation need to be the same under Lorentz trandformation, because it is based on the Lorentz invariant equation of the special relativity.
Under the Lorentz transformation,
[tex](-i\hbar\gamma^{\mu} \partial_{\mu} + mc) \psi (x) \quad \to \quad (-i\hbar\gamma^{\mu} \partial_{\mu}' + mc) \psi' (x')[/tex]
To satisfy this relation, the spinor (=psi) needs to satisfy the next relation of
[tex]\psi' (x') = S \psi (x) \quad S = \exp (-\frac{i}{2} \omega_{\mu\nu} S^{\mu\nu})[/tex]
(Of course, "kx" = momentum or energy x space or time of psi also need to satisfy SR.)
By the way, if you don't use the special relativity, how can you get the next relation (= origin of K-D and Dirac Eq.) ??
[tex] \vec{p}^2 - \frac{E^2}{c^2} + m^2 c^2 = 0 [/tex]
So Dirac equation is dependent on the special relativity. :smile:
(The spin relation can be gotten also from Schrodinger equation, I think. The difference is that Dirac's is 4 x 4 matrices. )
  • #78
Yes, that's exactly what we were discussing a little earlier in this thread. (We're working on that)
[tex] \vec{p}^2 - \frac{E^2}{c^2} + m^2 c^2 = 0 \ \ \ -> \ \ \ \vec{p}^2c^2 + m^2 c^4 = E^2[/tex]
  • #79
TrickyDicky said:
As we know nonrelativistic quantum mechanics doesn't have the Lorentz invariance property and yet it makes a number of powerful predictions and gives rise to all the fundamental quantum properties (HUP, tunnelling effec, harmonic oscillator, superposition, wave-particle duality etc).
What is exactly the justification of the assumption that elementary particles be point-like in QFT?
I fail to understand your question. First, in non-relativistic quantum mechanics elementary particles are point-like as well. An electron in the Schrödinger equation does not have size. Therein the position eigenfunctions in non-relativistic quantum mechanics are Dirac deltas. The consideration of point-like particles is based in experimental data.
Second, QFT theory would continue to work for today typical applications even if in the next decade elementary particles are found to be non point-like.
  • #80
You are right in the usual interpretation of QM but dirac deltas are simplified models, theoretical idealizations of point charges that can be mathematically represented by the dirac delta, and this is not directly related to Schrodinger's equation.
Experimental data is compatible with non point-like particles too.
Well, it depends on how you define typical applications. The internal consistency of the Lorentz symmetry of QFT theory demands point-like interacting particles if a field is represented as a canonical system with an infinite number of degrees of freedom and particles are quantized excitation of propagating fields.
  • #81
Any physical model is simplified. Moreover, extended models of electrons have been studied since Poincaré times and abandoned due to experimental difficulties and/or internal inconsistencies.
Dirac deltas are directly related to the Schrödinger equation if you expand the ψ in the position basis.
Yes in the sense that current data constraints our physical exploration of electrons up to 10-22 meters. No in the sense that no experiment up to date suggests that electrons have internal structure and finite shape. As a consequence our better models of the electron define it as a structureless point-like particle. And the same for the other elementary particles.
For example current application in particle accelerators. If tomorrow a theory of non-point-like particles was needed, this theory would reduce to QFT in some well-defined limit compatible with the scales accessible to current experiments.
  • #82
Sure, but it would be a non-Lorentz invariant theory, that would be Lorentz invariant(or as you say it would reduce to QFT) only at the infinitesimal limit that for particles is perfectly compatible with the accuracy limits of current experiments(except the Opera experiment in case it is confirmed).
  • #83
But this simplification is well known, and the position eigenket is known to be just a fair approximation not strictly correct: from the HUP we know the lower limit to how well localized a particle can be is not zero as it would be the case if it was a point-like particle, this limit is actually about the particle's compton wavelengh's order.
  • #84
There exist Lorentz invariant models of non-point-like objects. E.g., String theory models [*].
[*] I am not endorsing string theory by any bit of imagination.
  • #85
Right, but they need a bunch of non-observed dimensions.
  • #86
HUP works in QM, where position eigenstates are well-defined.
The problem that you are referring to is specific of the Dirac (and Klein-Gordon) early (and inconsistent) formulations of RQM. A problem which was somehow inherited by QFT (where position is downgraded to unobservable parameter).
The origin of the problem is other. For the Dirac theory the problem is associated to the fact that in his inconsistent formulation the position operator is not hermitian [*], with the non-Hermitian part giving a non-localisation term of the order of the compton wavelengh's order.
This problem is not present in modern approaches as the Stuckelberg-Horwitz-Piron theory where relativistic position eigenfunctions in a generalized 4N-dimensional Hilbert structure are well-defined.
[*] A consequence of Dirac incorrect linearisation procedure.
9K
