POTENTIAL DIFFERENCE AND ELECTRIC FIELD HOMEWORK
The discussion revolves around confusion regarding the application of formulas related to potential difference and electric fields in homework. The user expresses difficulty in solving a problem and believes an example would clarify their misunderstanding. They are uncertain about their calculations and seek confirmation on the correct approach. The forum encourages users to share their attempts to facilitate better assistance. Providing an example could enhance understanding of the concepts involved.
tuyenb
What is the magnitude of the average electric field inside the battery? Your answer should be in SI units.
See first picture please
I tried following the formula but it wasn’t correct. I’m sure I could get it if I had an example as I’m sure this must be a simple question for other people I was just unsure if I was doing it correct.
Per forum rules, please post your attempt.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
